  • 1 Post By MD1032
 Old 07-07-2015, 07:20 PM   #1
406Speed6's Avatar
Posts: 6   (View Stats)
406Speed6 has a little shameless behaviour in the past
Default Corksport Turbo Set Up
Dug around and idk why but the search bar is an asshole and never works properly for me....most likely user error but I am installing my new corksport drop in on Thursday and everywhere says the car needs to be retuned obviously but I want to know what map everyone is running from cobb when they first install until they get to the tuner or if there is a corksport base map. To late to call them so figured id ask around. Appreciate any help.
406Speed6 is offline   Reply With Quote
The Following User Says NO Thank You to 406Speed6 For This Un-useful Post:
Vansquish (07-15-2015)
 Old 07-07-2015, 07:28 PM   #2
nilashish's Avatar
Posts: 468   (View Stats)
You need a base map first before running your car
purchase tune>get base map>install turbo
The Following 4 Users Say Thank You to nilashish For This Useful Post:
406Speed6 (07-07-2015), MD1032 (07-08-2015), Thepedigree13 (07-07-2015), Vansquish (07-15-2015)
 Old 07-07-2015, 08:10 PM   #3
406Speed6's Avatar
appreciate it man first car without a carb so wasn't sure how the process worked until I got to the tuner.
 Old 07-08-2015, 07:31 AM   #4
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
In an emergency, you can limp around on an OTS map appropriate for your other mods where the WGDC table is zeroed. You need ATR to generate such a map.
CorkSport likes this.
2007 Mazdaspeed3 GT
 Old 07-08-2015, 05:16 PM   #5
iammike's Avatar
Posts: 1,415   (View Stats)
Essentially what my valet map is...except my valet map restricts the car to 3500 RPM and 70MPH. lol
Mike
 Old 07-15-2015, 11:05 AM   #6
Jetfire's Avatar
Posts: 39   (View Stats)
Jetfire is a splendid one to beholdJetfire is a splendid one to beholdJetfire is a splendid one to beholdJetfire is a splendid one to beholdJetfire is a splendid one to beholdJetfire is a splendid one to beholdJetfire is a splendid one to behold
Yes, look at the OTS Safe mode maps. WGDC at zero and running on spring pressure at about 14.7 psi slow boost build is what I am running until I can get my final mods in and sign up for a Strategic tune.
Jetfire is offline   Reply With Quote
 Old 07-15-2015, 11:10 AM   #7
Police - Grammarhead
Vansquish's Avatar
My valet map is limited to 40mph, zero WGDC, and 3500rpm. It's what I give to any shop that works on my car.
 Old 07-15-2015, 11:29 AM   #8
MD1032's Avatar
Groans: 143
The speed limiter doesn't work on my car for some reason so I set load targets really low instead.
2007 Mazdaspeed3 GT
So, about the new Corksport turbo... dale_gribble CorkSport 1859 08-01-2017 01:32 AM
Corksport turbo review hitANDrun21 CorkSport 117 01-16-2016 04:08 PM
Corksport Turbo EWG Jester2552 CorkSport 60 12-03-2015 06:53 PM
Corksport Turbo Xxblinddzxx Mazdaspeed3/6 General Discussion 9 08-25-2015 08:06 PM
Page generated in 0.29180 seconds with 25 queries
