 Old 10-08-2011, 12:43 PM   #1
aanguia1's Avatar
Posts: 291   (View Stats)
aanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the world
Groaned at 32 Times in 8 Posts
Default CS airbox pic included
I installed the airbox about 2k miles already and it seems like the intake moves way too much causing this
Ignore the gloves and stuff since I took it out and had with my tools before it gets even worse but has anyone else gotten this?
Guys at corksport, I followed the directions step by step to make sure nothing gets messed up but what should I do? I've tried adjusting the intake up and down but no luck
Sent from my LG-P999 using Tapatalk
aanguia1 is offline   Reply With Quote
 Old 10-08-2011, 09:12 PM   #2
dexter_5000's Avatar
Posts: 407   (View Stats)
dexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the world
rubber insulate the edges make it an even tighter fit.
dexter_5000 is offline   Reply With Quote
 Old 10-09-2011, 10:56 AM   #3
aanguia1's Avatar
But the MAF wire goes goes thru the same hole as the intake I'm paranoid about the wire tearing due to the intake moving alot
 Old 10-09-2011, 02:05 PM   #4
get some electrical shroud for the wire then.
 Old 10-09-2011, 05:08 PM   #5
Jake5713's Avatar
Posts: 1,775   (View Stats)
This is a fitment issue corksport should probably address
I am here: http://maps.google.com/maps?ll=44.739693,-93.107609
-Jake
Jake5713 is offline   Reply With Quote
 Old 10-09-2011, 06:26 PM   #6
Rustysocket's Avatar
Posts: 263   (View Stats)
Rustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the world
Anyone else had any issues?
2011 MS3 Liquid Silver with Tech Package - Corksport SRI // TRZ RMM
Ethanol Free Fuel database - http://pure-gas.org/
Rustysocket is offline   Reply With Quote
 Old 10-09-2011, 10:13 PM   #7
aanguia1's Avatar
So I got some for the wire but still paranoid about the intake moving and chewing the shroud along with the insert of the box....
This sucks I feel like I've wasted 100+ for something that's gonna get fuked up....I may be venting so I guess ill just wait till I get a response from corksport....
 Old 10-10-2011, 01:10 PM   #8
CorkSport's Avatar
Posts: 3,416   (View Stats)
What year is your car? I looked on your user CP but it didn't say.
-Derrick
WWW.CORKSPORT.COM
 Old 10-10-2011, 01:24 PM   #9
aanguia1's Avatar
Sorry its a 2010 ms3 have CS SRI+TIP and the airbox...
(Can't edit description on cp due to only being able to use my phone)
 Old 10-10-2011, 01:42 PM   #10
aanguia1's Avatar
More detailed pics....
 Old 11-02-2011, 07:47 PM   #11
neotide87's Avatar
Posts: 1,388   (View Stats)
neotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the world
hmm wow what is the update on this? just curious.
2007 Mazdaspeed 3 Sport SSM
Corksport SRI / HPFP Internals / Front Arm Bar // Cp-e RMM 75d // JBR RSB / IM & TB Gaskets / Bypass Valve Hose // Cobb AP / Shifter Weight // SU Shifter Bushings // Sure TIP // Viper 5901
neotide87 is offline   Reply With Quote
 Old 11-02-2011, 08:36 PM   #12
Jake5713's Avatar
Maybe corksport should come out with a bracket
Was looking at this but not so sure now
I am here: http://maps.google.com/maps?ll=44.739914,-93.108182
-Jake
 Old 11-02-2011, 08:59 PM   #13
Is @CorkSport aware of the issue?
 Old 11-02-2011, 10:09 PM   #14
aanguia1's Avatar
Yes they are, I submitted a ticket, got some tips but unfortunately it didn't fix anything.
I ended up trading the whole system in for a SURE aeros (Sri) and a SURE sidewinder (tip)
I would rather stick with an Sri that has a bracket than to fuk up my maf......
 Old 11-04-2011, 02:56 PM   #15
Gwynne's Avatar
Posts: 288   (View Stats)
Gwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the world
@aanguia1 -- I am sorry to hear that you were having fitment issues with the CorkSport Cold Air Box
We thoroughly tested this on our 2010 Mazdaspeed 3 and have sold many since its release in August of 2010. Yours is the first ticket we have received on the product.
I know that our sales manager, Kelly reached out to you with some suggestions on how you may be able to correct the problem:
1.Check to make sure the airbox is installed as far back as possible. The front brackets has some adjustability to it, so make sure it is positioned back.
2.Check the intake is as far forward on the turbo inlet pipe while ensuring it has a good seal and enough surface for the clamp to grab on to.
My understanding is she never heard back from you about further issues.
We pride ourselves on our customer service so please do let us know if there is more that we can do to assist.
Gwynne
CorkSport Peformance
www.corksport.com
Gwynne is offline   Reply With Quote
The Following 2 Users Say Thank You to Gwynne For This Useful Post:
neotide87 (11-25-2011), SLOWHATCH (11-05-2011)
 Old 11-04-2011, 03:18 PM   #16
TriO's Avatar
Posts: 676   (View Stats)
TriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the world
might have just been caused by overly worn engine mounts
TriO is offline   Reply With Quote
 Old 11-04-2011, 04:01 PM   #17
aanguia1's Avatar
Originally Posted by Gwynne[MENTION=130
CorkSport;1111659]@aanguia1 -- I am sorry to hear that you were having fitment issues with the CorkSport Cold Air Box
Never questioned your customer service trust me I like your products and service I'm just saying what I did and it is true I didn't follow up and the reason for that was because after those tips I notice my MAF was getting damaged and I didn't wanna wit another week for your responses so decided to go a different route no offense
 Old 11-04-2011, 04:21 PM   #18
Gwynne's Avatar
Thank you @aanguia1. I just wanted to make sure that there was nothing more we could do to help resolve the problem. We appreciate your business and want to ensure your satisfaction.
Please don't hesitate to reach out if there is anything further we can do.
Gwynne
www.corksport.com
The Following User Says Thank You to Gwynne For This Useful Post:
 Old 11-04-2011, 08:39 PM   #19
triphop631's Avatar
Posts: 1,191   (View Stats)
triphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the world
Groans: 30
Wish I would have known this before I traded. I feel like I was misled now. Now I have an airbox that is sitting in my garage.
Sent from my PC36100 using Tapatalk
I haz Partz!!!!!!!!!!
triphop631 is offline   Reply With Quote
 Old 11-04-2011, 08:53 PM   #20
aanguia1's Avatar
It works but I just didn't likehow loud it was, it might be differ for you.
It might be a user error that's why I didn't mentioned this aside I have no mechanical skills so that's why I didn't really bother....
 Old 11-04-2011, 09:06 PM   #21
triphop631's Avatar
Groans: 30
They need to give people a longer silicon hose for people with the airbox. Half of the maf housing is in and half is out. I thought the point was to have the complete maf in there.
 Old 11-07-2011, 11:38 AM   #22
CorkSport's Avatar
The idea is to have the filter inside the airbox for the cooler air. We setup the 2010+ MS3 airbox so part of the MAF housing is located inside.
-Derrick
WWW.CORKSPORT.COM
 Old 11-07-2011, 02:13 PM   #23
triphop631's Avatar
Groans: 30
-Derrick
I got it to work, the silicon bends a little more then I would like but it is in there.
 Old 11-07-2011, 06:12 PM   #24
YABBAMZR's Avatar
Posts: 183   (View Stats)
YABBAMZR is the leader of the worldYABBAMZR is the leader of the worldYABBAMZR is the leader of the worldYABBAMZR is the leader of the worldYABBAMZR is the leader of the worldYABBAMZR is the leader of the worldYABBAMZR is the leader of the worldYABBAMZR is the leader of the worldYABBAMZR is the leader of the worldYABBAMZR is the leader of the worldYABBAMZR is the leader of the world
Any one notice any MPG lost with this box??
My BAT's are lower
but i also lost 2mpg went from 27-28 to 25-26 all highway miles.
Sorry for the semi off topic question
2010 black mica
~GTX2867~ Auto tech internals--UR DP--UR res TP--bosch 3 bar map--HTP 3.5" intake--GFB dual port bpv--Cobb fmic--Cobb AP--GS EBCS--
--JBR fully mounted --JBR OCC--JBR TB TIG--JBR 51r battery tray--JBR RSB--JBR rear camber arms
--Stratified extended shifter--
Freektuned
333hp/354tq @ gsd (without meth)
YABBAMZR is offline   Reply With Quote
How can the stock airbox be so bad? event MazdaSpeed 3/6 - Turbo Induction 54 07-22-2010 02:16 PM
Page generated in 0.40375 seconds with 29 queries
