| CorkSport To say that CorkSport is passionate about Mazda Performance is understatement. It is the essence of what we do. Our mission to offer unparalleled customer service and support, an uncompromising commitment to the community, and deliver top quality performance parts is demonstrated with each product we develop to help fulfill your vehicles performance potential. At CorkSport we believe it doesn’t have to come in a fancy package or be the most expensive product on the market to be the best. |
![]() Join Date: Mar 2014
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 8 Times in 2 Posts
(Thread Starter) | Not Ranked : 0 score After installing the CSDP, I am having exhaust fumes leak into the interior of the car. Ive checked all the joints and cant find any leaks. At least I cant hear, feel or see any. I have no idea where they might be coming from. With the AC on recycle the interior air I have no issues, but with defrost of vent on it gets bad really fast. Anyone else have this issue ? Advice ? |
![]() Join Date: May 2010 Location: Benton, AR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,028
| Not Ranked : 0 score I'm pretty sure that means there is an exhaust leak. Also if you deleted one or more of the cats that does not help the situation. Did you use a new gasket for the Downpipe to turbo?
__________________ 2010 Mazdaspeed 3 Liquid Silver Metallic HTA 3076 | HTP 4" Intake, battery tray, under mount piping | CPE Exhaust Manifold, downpipe, FMIC & Stage 2 RMM | MD TMM and PMM | Tial MV-R ewg w/ Kozmic dump tube | VCTS delete/Ported IM | JBR OCC, EGR delete, BSD w/ oil pan baffle & RSB | SP63 Oil Cap Breather | Synapse SB BPV | UR CBE | Autotech HPFP | H & R Coilovers | Whiteline Endlinks | Manley Pistons & Rods | L19 Head Studs | Kozmic 6th Port w/ DW65c ITFP | Snow Performance Stg 2 Meth | JMF Manifold | SouthBend Stg 3 Endurance Clutch | Tuned with |
![]() Join Date: Dec 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 301
| Not Ranked : 0 score put some washing up liquid round the joints of the down pipe, it will start to bubble where the exhaust gas are escaping from |
| Not Ranked : 0 score forgot to say car needs to be running when doing this |
![]() Join Date: Jul 2011 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 473
| Not Ranked : 0 score Dude....use your brain. You replaced an exhaust piece and now you get bad fumes in the cabin immediately........its leaking....undo the connections and check your gaskets then reconnect.
__________________ Speed 6 Gone for 3+ years and still not happy about it 2007 Speed 3. JBR 3" WP. AP. Autotechs. Full Maize. CP-E Stage 2 RMM, Rubber Filled OEM TMM, Nator'd TP, Moog's and DM SSP Enki - "High mixes of corn = all the wastegate all the time for great justice." |
| The Following 5 Users Say Thank You to MSP6 For This Useful Post: | Code Monkey (11-09-2014), Easter Bunny (11-08-2014), He Hate Me (11-17-2014), JSmith (11-08-2014), nilashish (11-12-2014) |
(Thread Starter) | Not Ranked : 0 score Yeah , MSP6 I kinda knew it was leaking but there wasn't an obvious leak when I checked it in poor lighting setting. I will be sure to use my brain when I get it in my garage. And I'm pretty sure that I knew to check all of the connections too. You should be a mechanic / comedian full time. I was simply asking for the best place to start in case anyone had the same issue. |
| The Following 7 Users Say NO Thank You to sawdust777 For This Un-useful Post: | Easter Bunny (11-08-2014), faeker (11-08-2014), InkedInspector (11-09-2014), MazdaBoy2.3 (11-12-2014), nilashish (11-12-2014), Pointless (11-09-2014), Sploozel (11-11-2014) |
| Not Ranked : 0 score I only meant to be half an asshole.... Leaks can be seriously bad without being visibly noticeable at all, even with the best of lighting. My downpipe had damn near backed itself off my turbo and the only reason I noticed was my AFR's went whacky. I was pointing out that you hadn't done 30 things at one time. You removed and replaced 1 item, and now have an exhaust leak. Where do you think your culprit is? Also....if you're to survive here you'll need thicker skin. That was a friendly tap on the noggin to try and make you stop, slow down and think.
![]() Join Date: May 2012 Location: Austin TX
Rep Power: 342 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 343
| Not Ranked : 0 score Also check to be sure you put the spring bolts in correctly and didn't bottom them out, the springs need a little gap to do their jobs. Which cs dp is this? I have the one piece long dp (which I believe is discontinued) with 80mm outlet, I had some leakage when I still had the stock catback. Check the dp to midpipe and make sure the sizes match |
![]() Join Date: Dec 2013 Location: Austin, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 444
| Not Ranked : 0 score Are you pulling any codes? Usually turbo to downpipe you'd have around 20% Long Term FT and pulling lean bank 1 codes. I ran straight out the downpipe at one point and my AFRs were fine. Smelled like shit, but racecar. |
![]() Join Date: Aug 2012 Location: Tracy CA
| Not Ranked : 0 score I did the same thing but deleted the cats and since doing this, I do smell fumes from time to time. I figured it was because of the delete.
__________________ Too much for you |
![]() Join Date: Mar 2013 Location: Huntsville, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,402
| Not Ranked : 0 score Unburnt hydrocarbons stink. If you're sitting still or in a garage, you're going to smell it if you're catless.
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) |
(Thread Starter) | Not Ranked : 0 score Update: pulling no codes, small leak found bottom rear corner of turbo / downpipe gasket. and yes its the hardest one to get to. Going to replace the gasket and try again. For those who might at some point need to replace this gasket and find the $96 dealership price or even the $49 SU price a bit much, check out the Remflex RF18-020 for $22. It doesn't specifically list the car models but it looks exactly the same. I will know more tomorrow. |
| The Following 4 Users Say Thank You to sawdust777 For This Useful Post: |
![]() Join Date: Sep 2012 Location: Alabama
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 152
| Not Ranked : 0 score Remflex gaskets are the shit. I used one to seal up my Ebay dp to mid pipe. They are great for sealing uneven gaps. Didn't know they made one for the K04.
__________________ -kornybun |
(Thread Starter) | Not Ranked : 0 score The Remflex is the answer ! fits perfectly and seals easy with less torque. Tell the world. And that fixed the leak at the downpipe / turbo.....but I found another leak that no gasket can fix. I am thinkimg that this new issue should be a new thread but essentially, the friggin CSDP was broken at a tig weld. I had to remove the whole pipe and have it mig welded. I have had great success with every product from Corksport up until now and I wont smear their name, but the tig weld on this particular pipe was kindy crappy. Anyone know if the stock motor mounts are to blame for stressing the DP ? Either way I'm up and running with NO LEAKS ! |
| The Following 3 Users Say Thank You to sawdust777 For This Useful Post: |
![]() Join Date: Jul 2010 Location: Las Vegas, NV
Rep Power: 523 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,061
| Not Ranked : 0 score I bought a used CS DP, it was cracked at the welds to the flange. Got it rewelded before install and it's been fine for 2.5 years but I'm fully mounted.
__________________ 2007 MS3: BNRs3 PPT Tuned 350hp/360tq Stocked out and SOLD 2016 CX-5 GT AWD |
![]() Join Date: May 2011 Location: Valdosta GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,861
Groans: 126
| Not Ranked : 0 score Did you buy new or used? Motor mounts or not it shouldn't cracked that quickly if new. It's good you got it figured out though, and thanks for the info on the gasket.
__________________ '09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE |
(Thread Starter) | Not Ranked : 0 score No, I bought the pipe new and have had it on the car a while. No idea when the weld snapped but Im guessing probably around the same time I started smelling fumes, but then again the gasket was also fried. I ordered the CS motor mount inserts to head off any future stress to that pipe. |
| The Following User Says Thank You to sawdust777 For This Useful Post: | ASHMS3 (11-13-2014) |
![]() Join Date: Aug 2012 Location: Mundelein, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 322
Also should add that for exhaust leaks I built a tester similar to a boost leak tester that I slip over my exhaust tip. You can check for leaks on a cold car and won't burn your hands.
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! Last edited by Turbo_Steve; 11-13-2014 at 10:31 AM. Reason: MSF Database - Automerged Doublepost | |
| Not Ranked : 0 score If you're doing the gasket, just slab the shit out of it with RTV and put it back on. $9 fix. My downpipe gasket has been through all sorts of shit, and it still holds. |
![]() Join Date: Apr 2013 Location: Seattle, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,526
| Not Ranked : 0 score Glad you figured it out. I'm curious how long you have had the downpipe though.
__________________ SOLD: 2009 Metro Gray Mica Mazdaspeed 3 - CorkSport Stage II SRI - CorkSport High Flow Downpipe -CorkSport TMIC - CorkSport Short Shift Plate - CorkSport Shifter Bushings - CorkSport Rear Motor Mount - CorkSport Passenger Side Motor Mount -Cobb Accessport - CorkSport HPFP Max Flow Fuel Pump Internals - CorkSport LED Kit 1992 Red Mazda Miata - Flyin Miata Swaybars, Hard Dog Hard Bar, Koni Yellow Shocks, Flying Miata Springs, Spec Stage 1 Clutch, E-Code headlights Next?: 2016 Mazda Mx5? 2017 Mazdaspeed 3? [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to sawdust777 For This Useful Post: | SpencerC (11-14-2014) |
![]() | | #24 | ![]() |
| Not Ranked : 0 score Hopefully you submitted a warranty form here: https://app.smartsheet.com/b/form?EQ...dfd91666d9c770
![]() | | #25 | ![]() |
I appreciate the link and I just sent the form in documenting my issues. I do not have much documentation of the original purchase date or install date ( there was a significant delay in installation). Not sure what can be done at this point and I am not overly concerned with it either. I just was surprised that your product was not perfect as they usually are. Worry not, I am a loyal customer of Corksport and I am not going anywhere anytime soon. | |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score Spencer, CS has made everything right by me. I didnt intend to ask for, or really expect any gesture on their part but they went above and beyond. You guys have some of the best customer service I have ever seen ! BTW give Kelly at ext 103 a huge raise. She was fantastic ! |
![]() | | #27 | ![]() |
![]() Join Date: Aug 2008 Location: Medford, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 625
| Not Ranked : 0 score I have this same issue CSDP. I keep the A/C fan on recirc. I haven't had the time nor the patience to get in there and find out where it is coming from. I don't think mine is cracked though.
__________________ 08.5 CWP MS3 - Cobb AP *Stage 2* ATR with a street tune - JBR Power Path Stage II Short Ram Intake - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - TSW Nurburgring Machined 18x8.5 Wheels - FIREHAWK INDY 500 - SIZE: 235/40R18 - Cobb RSB - Motorcraft XT-M5-QS in the tranny! |
| Report: World Health Organization says diesel fumes cause cancer | Haltech | Automotive News | 0 | 06-13-2012 05:00 PM |
| Supplier fumes as carmakers take electric motors in-house | Haltech | Automotive News | 0 | 06-21-2010 08:50 AM |
| If 100% Meth spalshed or fumes on the dp or mani could it ignite? | gsrtype1 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 35 | 05-30-2009 07:31 PM |
| Nardelli: Chrysler is running on fumes | Haltech | Automotive News | 0 | 11-23-2008 10:10 PM |
