Like Tree16Likes
  • 1 Post By JgamB
  • 2 Post By Oni
  • 2 Post By Barett@CorkSport
  • 1 Post By Easter Bunny
  • 3 Post By JgamB
  • 3 Post By JgamB
  • 2 Post By JgamB
  • 2 Post By CorkSport
 Old 06-10-2015, 01:22 PM   #1
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
Default CS exhaust manifold heat shield
Mazdaspeed Exhaust Manifold Heat Shield
It'd be cool if it fit aftermarket manifolds, I'm betting it sells well.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following User Says Thank You to mxlplx71 For This Useful Post:
Awal (06-10-2015)
 Old 06-10-2015, 01:31 PM   #2
Helrich's Avatar
Posts: 306   (View Stats)
I'm guessing this wouldn't have any positive effects on BATs for TMIC setups.
2016 MX-5 Club
2012 MS3 -- RIP in peace
 Old 06-10-2015, 01:34 PM   #3
What would make you say that?
 Old 06-10-2015, 01:38 PM   #4
Police - Grammarhead
Vansquish's Avatar
I'm with him on that, actually. The OE heat-shields do a pretty good job of insulating the engine bay. They are also small enough that they allow air to flow through the intercooler and down past the downpipe and out to the bottom of the car.
Corksport's heat shield appears to block off a lot of that opening, as it appears to stretch the full width between the firewall and the head.
 Old 06-10-2015, 01:45 PM   #5
Helrich's Avatar
Because there's no mention of it on their store page, and I figured that would be a strong selling point if it did help.
I'm primarily thinking that the heat shield would heat up and eventually radiate up into the IC anyways.
2016 MX-5 Club
 Old 06-10-2015, 01:46 PM   #6
Vansquish's Avatar
True, but at least with the OE shields there's some airflow that can help mitigate that.
 Old 06-10-2015, 01:50 PM   #7
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
CS doesn't make any clams about this reducing under hood temps... it may catch few eyes at your next car meet though.
The stock one seems to be better... I can see heat rising from the CS logo.
2018 Audi RS3
2007 Acura TSX 6MT
 Old 06-10-2015, 04:25 PM   #8
Barett@CorkSport's Avatar
Posts: 85   (View Stats)
Barett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the world
The exhaust manifold heat shield was designed with aesthetics in mind, therefore we are not making any claims in performance.
If heat control performance is your only concern then this may not be the product for you, but of you are ok with a small compromise for a huge improvement in the look of you engine bay then this will make you very happy.
The OEM heat shield will most likely be the best performing (other than a custom blanket) because it is form fitted and double layer. I wouldn't worry about a chance for flow impedance caused by the CS heat shield because the pressure differential from outside of the car's front, to the engine bay, and then under the car is far more influential in controlling engine bay temperatures.
We have also seen plenty of pictures of peoples cars without any time of heat shield so we went forward with the project so that there is another option other than OEM or bare.
And to finish up, the CS heat shield is designed for the OEM exhaust manifold. We looked into designing it to fit other aftermarket manifolds, but it would have been nearly impossible to do so with the many different designs available. Also, no aftermarket manifolds retain the OEM mounting locations.
I hope this helps!
Barett Strecker
Product Development Engineer
CorkSport Mazda Performance
barett@corksport.com
360-260-2675
2009 MS3 with most of the CS goodies you can buy...and some you can't...
Barett@CorkSport is offline   Reply With Quote
The Following 8 Users Say Thank You to Barett@CorkSport For This Useful Post:
Awal (06-10-2015), g00s3y (06-12-2015), JgamB (06-10-2015), maisonvi (06-11-2015), mazdaspeedmyk (06-12-2015), mxlplx71 (06-10-2015), Raider (06-24-2015), SarcasticOne (06-10-2015)
 Old 06-10-2015, 04:49 PM   #9
mxlplx71's Avatar
Groans: 128
@Barett@CorkSport; will it work with the stock heatshield under it?
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 06-10-2015, 04:50 PM   #10
No it won't
Barett Strecker
360-260-2675
The Following 2 Users Say Thank You to Barett@CorkSport For This Useful Post:
Awal (06-25-2015), mxlplx71 (06-10-2015)
 Old 06-10-2015, 06:39 PM   #11
JgamB's Avatar
Posts: 2,566   (View Stats)
I ordered one. I'm FMIC and my OCD to get rid of that fugly OEM heat shield was overwhelmed by my sense of aesthetic appeasement.
Awal likes this.
The Following 3 Users Say Thank You to JgamB For This Useful Post:
Awal (06-10-2015), ItsNox (06-18-2015), mazdaspeedmyk (06-12-2015)
 Old 06-10-2015, 06:50 PM   #12
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
holy geezus cow that music!
Mods: stock
JgamB (06-11-2015)
 Old 06-10-2015, 07:16 PM   #13
I wass looking at it as going from no heatshield to this one where there is bound to be some improvement to bats. However you both looked at it as an upgrade relative to the stock heatshield, a scenario I did not consider but would agree that it would likely not improve bats.
I would think that a universal heatshield could be made for most manifolds which mounted to the studs instead of some mounting points.
Code Monkey (06-10-2015)
 Old 06-10-2015, 08:18 PM   #14
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
@Barett@CorkSport; will you guys do the anodizing in any other colors? Red, blue, gold?
09 MGM MS3
 Old 06-10-2015, 08:30 PM   #15
Awal's Avatar
Posts: 645   (View Stats)
Awal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the world
Def a great option for the FMIC guys, I'd go this route if I wasn't TMIC. THE MZR DISI w/ the TMIC shroud off looks like a rats nest.
Next step, a CS wiring/HPFP/etc cover. I am not very big on parts that only focus on aesthetics, but the MS3/6-CX7 engine compartments with FMICs would certainly benefit from the clean look. And done in the right way/colour it would look much less 'modified'.
I guess the issue with a cover for that area would be fitting under the over-the-top FMIC piping.
All Go, No Show
2013 LSM W/ Tech
CORKSPORTFull Race RMM CORKSPORTPMM CORKSPORTTMM CORKSPORTTMIC(temporarily uninstalled for Warranty BS) CORKSPORTECU RELOCATION BATTERY BOX(temporarily uninstalled for Warranty BS) CORKSPORTSSP CORKSPORTSHIFTER BUSHINGS CORKSPORT3.5" POWER SERIES SRI/TIP(temporarily uninstalled for Warranty BS) CORKSPORTBPV(temporarily uninstalled for Warranty BS) CORKSPORTRSB @ Full Stiff CORKSPORTMid Chassis Brace CORKSPORTHood Struts + decals for 20whp CORKSPORTLicense Plate Frames
COBBAP v3 w/ Window Mount
AUTOTECHHPFP INTERNALS
ToBeInstalled:
CORKSPORTFull Catless TBE, Rear Trunk Brace, Adjustable FELs, Cold Air Box (modified for 3.5")
dbaDBA42962S Front and Rear Rotors
StopTechRear Braided SS brake lines
JBROCC & VTA OCC kit, EGR BO, Boost Tubes
Cooling MistWMI kit
StratifiedCustom Tune (as soon as TBE is on)
On Deck
wilwoodFastbrakes DP4front Caliper kit (w/ bp-10 pads and braided SS fr lines)
Hawk PerformanceHB478F.605 or HB478Z.605 rear pads
BilsteinB16s
Awal is offline   Reply With Quote
 Old 06-11-2015, 06:50 PM   #16
Oni
Oni's Avatar
Posts: 565   (View Stats)
So make your own manifold to go with it.....
Awal and Barett@CorkSport like this.
'12 Velocity Red Mica MS3
Cobb AP V3 // Autotech Fuel Pump Internals // HTP 3" // UR Catted V2 DP // UR Resonated TP // UR Resonated CBE // GrimmSpeed EBCS // CP-E TMIC // GFB Respons BPV // JBR Trilogy 88/80/80 // Corksport Hood Struts // Prosport EVO Boost Gauge w/ block8head vent pod // E30 Freektune
Installing Soon : Stratified GA // Bosch 3 Bar Map w/ PNP Harness
Oni is offline   Reply With Quote
The Following 3 Users Say Thank You to Oni For This Useful Post:
Awal (06-12-2015), Code Monkey (06-12-2015), WetzMS3 (06-18-2015)
 Old 06-12-2015, 08:45 AM   #17
FINE! Maybe we will...
Oni and Awal like this.
Barett Strecker
360-260-2675
The Following 9 Users Say Thank You to Barett@CorkSport For This Useful Post:
Awal (06-12-2015), Easter Bunny (06-18-2015), g00s3y (06-12-2015), JgamB (06-12-2015), mxlplx71 (06-12-2015), Raider (06-24-2015), Shwaykid (06-12-2015), WA_MS6 (06-12-2015), WetzMS3 (06-18-2015)
 Old 06-12-2015, 09:18 AM   #18
WA_MS6's Avatar
Posts: 459   (View Stats)
Sooo....2 more weeks? June 31st?
There already is a company that makes those; RD Motorsports. But I'm sure Corksport can manufacture something better than theirs.
2007 Black Mica Mazdaspeed6
AutoTech HPFP Internals
COBB AP w/ stage 2 ~ Shifter Weight
CorkSport Front Mount Kit
CP-e CBE Single Exit Exhaust
Koni Yellows
Last edited by WA_MS6; 06-12-2015 at 09:18 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-12-2015, 10:09 AM   #19
Awal's Avatar
Doesn't hurt to have everything match, it's the OCD in me.
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
 Old 06-18-2015, 10:57 AM   #20
you just pissed off everyone that pulled their manifold to install your turbo.
@Raider; at least all of the bolts have been spun recently.
CorkSport likes this.
Awal (06-18-2015), mxlplx71 (06-18-2015), Raider (06-24-2015)
 Old 06-18-2015, 05:37 PM   #21
JgamB's Avatar
According to my email it ships Tuesday next week and arrives Friday.
 Old 06-24-2015, 07:09 AM   #22
Those actually all came off up top without a fight. There was only 2 manifold ones that were a pain.
Easter Bunny (06-24-2015)
 Old 06-25-2015, 03:41 PM   #23
JgamB's Avatar
Look who arrived a day early @Barett@CorkSport;
The metrics for this test will be to see how much jealousy it induces when I pop the hood. It's sometimes difficult to assign values to vagaries such as this, but I see the pained look on the Gen1 guys faces over the hood struts. I will use that as a reference point
CorkSport, Awal and Castillo817 like this.
Awal (06-25-2015), Barett@CorkSport (06-25-2015), Easter Bunny (06-25-2015)
 Old 06-25-2015, 05:04 PM   #24
JgamB's Avatar
The Following 4 Users Say Thank You to JgamB For This Useful Post:
Awal (06-25-2015), CorkSport (06-26-2015), mxlplx71 (06-29-2015), SpeedRebirth (06-25-2015)
 Old 06-25-2015, 05:07 PM   #25
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Looks good.
JgamB (06-25-2015)
 Old 06-25-2015, 10:07 PM   #26
Awal's Avatar
Awesomeness. carry on.
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
The Following 2 Users Say Thank You to Awal For This Useful Post:
Barett@CorkSport (06-29-2015), JgamB (06-25-2015)
 Old 06-25-2015, 10:43 PM   #27
JgamB's Avatar
The only disappointing part of my purchase was no one at CS made any indication they noted how I found out about their products. Meeting @Barett@CorkSport; at a seedy truck stop restroom by dialing his number on the bathroom stall was completely omitted.
CorkSport and Awal like this.
Awal (06-25-2015), Barett@CorkSport (06-29-2015), Easter Bunny (06-26-2015)
 Old 06-26-2015, 08:50 AM   #28
CorkSport's Avatar
Posts: 3,416   (View Stats)
I will get that on the webpage as a drop down selector option right away.
Derrick
JgamB and Awal like this.
WWW.CORKSPORT.COM
Awal (06-26-2015), Easter Bunny (06-26-2015), JgamB (06-26-2015)
Exhaust Heat Shield 4RGED Exterior 2 08-16-2013 08:30 AM
Heat shield melting to manifold EL F00LI0 MazdaSpeed 3/6 - Turbo Induction 15 05-15-2011 03:27 PM
GI: Intake Manifold Heat Shield Gasket superskaterxes MazdaSpeed 3 - Engine, Transmission & Driveline 45 05-19-2009 06:37 PM
Page generated in 0.47126 seconds with 35 queries
