 Old 07-21-2014, 10:21 PM   #1
nb6179505's Avatar
Posts: 348   (View Stats)
nb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond repute
Default CS Stage 2 OTS
Guys question about running the stage 2 OTS. I have a straight piped no resonators no mufflers cbe with a cs tp, also stage 2 cs intake and cs hpfp and SU IC. Would I be okay to run stage 2 CS OTS map? I know you recommend a high flow cat...
Do you have notes on the OTS? I know Cobb OTS ease off the boost limiter in 1st and 2nd. Its on a 2012 MS3...
nb6179505 is offline   Reply With Quote
 Old 07-22-2014, 09:41 AM   #2
SpencerC's Avatar
Posts: 2,159   (View Stats)
You should be able to run a Stage II map, but make sure you do some data logs and watch your AFR, Boost and WGDC among other things to make sure everything looks ok. Some people have trouble running stage II on just a racepipe.
nb6179505 (07-22-2014)
 Old 07-22-2014, 10:48 AM   #3
nb6179505's Avatar
Do you have notes on boost targets?
 Old 07-22-2014, 12:16 PM   #4
SpencerC's Avatar
Boost targets should be within 1.5 psi of targeted boost.
First dyno pulls on Stage 1 and Stage 2 Cobb Maps PSmurf78 2010 MS3 - ECU Computer Tuning 11 05-14-2013 05:44 PM
Interesting look at Stage 1 + SF vs. Stage 1 + MSCAI2 maps, similarities and differences bast525
Cobb ATR Support
4 05-24-2009 07:52 PM
Page generated in 0.24052 seconds with 21 queries
