Like Tree4Likes
  • 1 Post By Luke@corksport
  • 1 Post By zjnspeed3
  • 1 Post By Barett@CorkSport
 Old 09-15-2015, 07:08 PM   #1
doctavus's Avatar
Posts: 1,728   (View Stats)
Default CS Turbo 93 Results
***DISCLAIMER: This thread is solely for the purpose of giving an idea of what to expect on a 93 octane CS Turbo tune in the DFW summertime with our crappy 93 and super high BATs***
Mods: CS Turbo, HTP 3", Stratified 3-Port, 3-BAR, COBB FMIC, CP-E catted DP, CS single exit exhaust
IATs were 111 and BATs were 126. It's safe to say that during the winter these numbers should easily be 25-30 whp/wtq higher. This basically puts the CS Turbo right in the realm of a BNR S3. The S3 spools faster and has a lower boost threshold; the CS has a better top end.
The Following 15 Users Say Thank You to doctavus For This Useful Post:
Atticaz (09-16-2015), Barett@CorkSport (09-16-2015), breakfstincluded (09-17-2015), Code Monkey (09-15-2015), dale_gribble (09-18-2015), dinoxor (09-16-2015), Erick13Speed3 (09-17-2015), Justin@Freektune (09-17-2015), Matt H. (09-20-2015), MD1032 (09-16-2015), Mike@Stratified (09-17-2015), Monforte88 (09-15-2015), MS3Shadow (09-15-2015), tfusch4 (09-22-2015), Thepedigree13 (09-15-2015)
 Old 09-15-2015, 09:07 PM   #2
Thepedigree13's Avatar
Posts: 608   (View Stats)
Groans: 64
Those are decent numbers considering how hot it is down here. Makes me believe with E85 it would push a nice safe amount of power for those not looking to build, with a proper tune obviously.
~2013 BLACK MS3~
COBB: (APV3//Exhaust Hangers)
Thepedigree13 is offline   Reply With Quote
 Old 09-17-2015, 11:27 AM   #3
doctavus's Avatar
Actually, might be some more power left in it right now. Stock BPV probably leaving more on the table. I ordered a Synapse from Stratified last night. Will update when done with that.
 Old 09-17-2015, 11:53 AM   #4
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
It would not surprise me if after you install the upgraded BPV, you over-boost and need to turn down WGDC %...
www.tunedbynishan.com
The Following 3 Users Say Thank You to ms3blackmica For This Useful Post:
breakfstincluded (09-17-2015), doctavus (09-17-2015), Justin@Freektune (09-17-2015)
 Old 09-17-2015, 11:58 AM   #5
Police - Grammarhead
Vansquish's Avatar
For comparison, here's one from my BNR S3 V2 on 93 targeting only 20psi on my MS6 from yesterday here in Southern Indiana. During the run IAT started at 93º and dropped to 90º, and BAT started at 117º dropped to 111º and finished up at 118º by the end of the pull.
 Old 09-17-2015, 02:54 PM   #6
Luke@corksport's Avatar
Posts: 120   (View Stats)
Luke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond repute
I would really like to see someone make a solid 400whp on meth with the CS turbo.
Justin@Freektune likes this.
Luke@corksport is offline   Reply With Quote
The Following 2 Users Say Thank You to Luke@corksport For This Useful Post:
breakfstincluded (09-17-2015), Justin@Freektune (09-17-2015)
 Old 09-17-2015, 03:27 PM   #7
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
I would really like to see it done, but also through a CS Intake Manifold with aux ports :3
 Old 09-17-2015, 03:39 PM   #8
Brandon@corksport's Avatar
Posts: 170   (View Stats)
It will happen
Cheers,
Brandon Johnson
CorkSport Mazda Performance
(360)260-2675 ext. 106
BrandonJ@corksport.com
 Old 09-17-2015, 03:53 PM   #9
SuckSqueezBangBlow's Avatar
Posts: 266   (View Stats)
(Rubs hands together)
"Goooood"
 Old 09-17-2015, 04:05 PM   #10
davychronic's Avatar
Posts: 1,155   (View Stats)
davychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the world
Originally Posted by Brandon@corksport View Post
It will happen
When is this mani ready? We are all waiting impatiently for you to take our monies right meow.
06 MS6 GT Titanium Gray II Metallic
davychronic is offline   Reply With Quote
 Old 09-17-2015, 07:25 PM   #11
zjnspeed3's Avatar
Posts: 1,436   (View Stats)
I want intake manifold as well.. I didn't get one since I asked for it in the requests/jokes box when I ordered my CS injector seals.. Did you misplace it @Brandon@corksport;?
MS3Shadow likes this.
 Old 09-18-2015, 02:10 PM   #12
A certain someone (Barett) needs to get his meth injection going!
The Following User Says Thank You to Luke@corksport For This Useful Post:
ms3blackmica (09-18-2015)
 Old 09-18-2015, 03:09 PM   #13
Nishan
Quoted for truth.
Barett@CorkSport (09-18-2015)
 Old 09-18-2015, 03:19 PM   #14
sheston's Avatar
Posts: 1,847   (View Stats)
@doctavus; Interested in seeing a comparison between the stock BPV and the Synapse on the same map. I didn't see a hp increase but I was targeting more boost than I could achieve. The stocker seemed to hold a lot of boost
 Old 09-18-2015, 03:24 PM   #15
doctavus's Avatar
Ah man! I'm so excited though, lol.
How much boost were you hitting with the stock BPV?
I really am expecting some more power, but we shall see.
@speedfreak44;
Why the Groan on my post?
Last edited by doctavus; 09-18-2015 at 03:24 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-18-2015, 05:49 PM   #16
Barett@CorkSport's Avatar
Posts: 85   (View Stats)
Barett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the world
Quoted for truth.
I know I know I'm right there. I swear every time I mention meth around my car some other stupid little something breaks...it's like she knows I'm going to beat her harder.
doctavus likes this.
Barett Strecker
Product Development Engineer
barett@corksport.com
360-260-2675
2009 MS3 with most of the CS goodies you can buy...and some you can't...
Barett@CorkSport is offline   Reply With Quote
 Old 09-19-2015, 05:58 PM   #17
sheston's Avatar
@doctavus; I'm still on the stock K04, but since I bent a rod and built the motor, I push it as hard as it will go. On a cold day, I hit 27 + psi up to about 4000 or 4500 rpms. That didn't seem to change when I went with the Synapse.
I'm running 100% wastegate duty and targeting 27 psi to redline. I assume if the stock BPV were leaking, I would have seen an increase with the Synapse
 Old 09-19-2015, 07:17 PM   #18
speedfreak44's Avatar
Posts: 1,391   (View Stats)
Dude sorry about the groan my phone is retarded as shit
The line up:
The Following User Says Thank You to speedfreak44 For This Useful Post:
doctavus (09-19-2015)
 Old 09-19-2015, 11:30 PM   #19
doctavus's Avatar
LOL, totally understandable.
 Old 09-22-2015, 10:53 AM   #20
I figured every time I say something about that meth injection, it makes Barett need to get it done sooner. I need to see numbers!!
 Old 09-26-2015, 07:29 PM   #21
vesestilldrumming's Avatar
Posts: 50   (View Stats)
vesestilldrumming is a glorious beacon of lightvesestilldrumming is a glorious beacon of lightvesestilldrumming is a glorious beacon of lightvesestilldrumming is a glorious beacon of lightvesestilldrumming is a glorious beacon of lightvesestilldrumming is a glorious beacon of light
Groaned at 6 Times in 2 Posts
Anyone know the max boost psi for the CS turbo?
vesestilldrumming is offline   Reply With Quote
 Old 09-26-2015, 07:40 PM   #22
This should help
http://www.corksport.com/support/GEN...te%20Paper.pdf
 Old 09-26-2015, 07:50 PM   #23
I read that thread like 5 times and get nothing besides a k04 similar boost run from 20 tapering to 17 psi.
The Following User Says Thank You to vesestilldrumming For This Useful Post:
Kluethje (09-28-2015)
 Old 09-26-2015, 07:56 PM   #24
That is the white sheet off corksport's site, it points out that the turbo is efficient to I think 18psi but can handle up to 35psi. Its been awhile since ive read it.
 Old 09-28-2015, 08:48 AM   #25
Peak efficiency (~78-80%) will be around 2.25 pressure ratio (PR) which is ~18.4psi.
The efficiency will begin to degrade linearly down to 71-72% efficiency around 3.5 PR which is ~37psi. This is basically the maximum since the turbo shaft RPM will be approaching 150K.
You should be able to run 28-30psi all day long with reasonable BAT's, but this is also dependent on you supporting mods. Specifically your intake, intercooler, and piping.
Remember, the MAP sensor reads boost pressure at the intake manifold, not the compressor outlet. A restrictive intake, poor flowing intercooler (aka high pressure drop), and piping with sharp bends will make the turbo work harder to produce the desired psi at the intake manifold.
Brandon@corksport likes this.
Barett Strecker
360-260-2675
The Following 6 Users Say Thank You to Barett@CorkSport For This Useful Post:
breakfstincluded (09-28-2015), Chriss (09-28-2015), davychronic (09-28-2015), doctavus (09-28-2015), MS3Shadow (09-29-2015), Yatta (09-28-2015)
 Old 09-28-2015, 02:35 PM   #26
Thank you very much, that is exactly what I was looking for, just didn't know how to do that math.
 Old 09-28-2015, 02:39 PM   #27
No problem! The attached image is the compressor map for the GTX2867R. This isn't a perfect representation of the CS turbo, but is extremely close.
Both turbos have the same wheel trims (therefore the characteristics will be very close) with the CS turbo having only slightly larger wheel diameters.
Barett Strecker
360-260-2675
XS Power Turbo Manifold is here... Install pics & Dyno results to follow soon. Turbo_Steve MazdaSpeed 3 - Engine, Transmission & Driveline 995 04-18-2018 11:31 PM
Geneva: Alpina tunes its first crossover, XD3 Bi-Turbo results Haltech Automotive News 0 03-07-2013 10:10 AM
Delphi posts lower Q4 results, but expects improved 2013 results Haltech Automotive News 0 02-05-2013 11:40 AM
Reworked Turbo from PG results phantomspeed3 MazdaSpeed 3/6 - Turbo Induction 64 11-02-2011 11:23 AM
Bad Turbo Results in New Block batman MazdaSpeed 3 - Engine, Transmission & Driveline 31 02-22-2010 08:32 AM
Page generated in 0.49284 seconds with 34 queries
