 Old 08-23-2019, 03:55 PM   #1
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Originally Posted by pacunning View Post
Bump, did you get this resolved? I’m also having issues, I’m at 80%WGDC and only able to hit 24.5 psi. Checked 2 times for boost leaks, none found. I feel kinda odd adjusting the preload to be honest. I have a CS EBCS set up in bleed mode and CSt4
Change your setup to 3-port interrupt instead of 2-port bleed.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
MS6 AWD trans bearings / preload question Boltz MazdaSpeed 6 - Engine, Transmission & Driveline 15 01-25-2014 04:25 AM
Adjusting preload IWG shawn. MazdaSpeed 3/6 - Big Turbo Builds 7 08-05-2013 09:02 AM
Adjusting WG spring preload on turbo? p057 MazdaSpeed 3/6 - Turbo Induction 10 10-30-2012 05:55 PM
Page generated in 0.23037 seconds with 21 queries
