 Old 04-15-2015, 01:51 AM   #1
Kor3y101's Avatar
Posts: 193   (View Stats)
Kor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond repute
Default Drain Valve, +5HP Decals!
So after close to a month now after installing my CS Catch Can, I finally decided to put my drain valve on it.
I've emptied it twice now as I've done nearly 1500KM and it let out a heap of oil and odd looking liquids so its clearly doing its job which I'm thankful of. But it was such a PITA to pull off the skid cover everytime then get oil all over myself while undoing the bung.
Of course when I installed it, I was out of time to try and get the damned drain valve in, that and I didn't have a TORX bit to fit it.
But I finally got around to doing it this afternoon, I managed to drain it, throw the new drain valve on it, and drill a hole through the skid cover so that the fitting pokes out, I also attatched a 2" length of the yellow PVC hose that comes with it so I can just throw a bottle under it and not worry at all, it is also installed in the recommended spot so I can reach my arm down from the top and turn the valve on/off.
Here's a pic I thought I'd throw up so you know what I mean, It's probably been covered before, but its a refresher for those new people who are yet to install it
ANNNDD! My 5HP each Decals! I had like 10 of these laying around, and after putting them all under my hood I decided I should display the name for all to see! haha
'12 Black Speed 3
CS RMM -~- CS SSP & Gearbox Bushings -~- CS OCC -~- CS LED light kit -~- CS Front and Rear Sway Bar -~- UnPlugged EGR Delete -~- CS Hood Struts -~- DVC30 WMI -~- JBR 3" Widepath -~- CS HPFP -~- GrimmSpeed 3 Port -~- HKS SSQV -~- CS TMIC -~- 500W Memphis Sub/Custom Wheel Well Box -~- 3" Xforce TBE -~- RayD Tuned
Kor3y101 is offline   Reply With Quote
The Following User Says Thank You to Kor3y101 For This Useful Post:
slw97 (04-15-2015)
Keep your Engine Running Cleaner and Better with the CorkSport Aluminum Oil Catch Can and Drain Valve Kit CorkSport CorkSport 24 08-31-2013 07:17 AM
oil continuing to drain into intake after occ and new pcv valve Kydizzle MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 10-17-2012 07:21 PM
Fumoto valve vs. magnetic drain plug pebenito MazdaSpeed 3 - Engine, Transmission & Driveline 3 05-10-2010 07:51 PM
Source of Battery Drain, Tire Valve Cap, Replacing A Brake Light: Mike Allen's Weekly Online Auto Clinic Haltech Automotive News 0 09-19-2008 02:30 PM
Page generated in 0.22746 seconds with 21 queries
