Like Tree20Likes
 Old 05-06-2013, 04:48 PM   #81
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Weren't there a bunch of early Gen1 OEM TMM failures?
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 05-06-2013, 04:50 PM   #82
I had to cut away a good amount of the TMM insert on an 08.5. I sent pics of the modification to CS. Post these up if you guys like.
Nliiitend1 (05-06-2013)
 Old 05-06-2013, 05:43 PM   #83
I'm a caveman
gtlaw's Avatar
Posts: 758   (View Stats)
gtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the world
Groans: 68
Groaned at 22 Times in 16 Posts
I don't know if this helps but here it is installed unmodified and my car hasn't been to the dealership since I bought it in may of 08
my s3 takes such good pictures you can actually see a part number molded into the rubber on the right
2015 MUSTANG GTPP
gtlaw is offline   Reply With Quote
The Following 4 Users Say Thank You to gtlaw For This Useful Post:
AustinK (05-07-2013), El_Diablo (05-07-2013), mituc (11-07-2013), Nliiitend1 (05-06-2013)
 Old 05-10-2013, 09:52 PM   #84
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
To those who have installed the PMM and have put some miles on it...how many miles until the mount settled, and what difference did you observe when you first put it on to when it settled...is the difference noticeable?
Thanks!!!
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 05-10-2013, 10:43 PM   #85
Playaj's Avatar
Posts: 1,232   (View Stats)
Playaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the world
Groaned at 9 Times in 7 Posts
Sure would like to know if the mount would fit on my Genone, I would order immediately.
2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's
to be installed :
3 Port EBCS
HTP 3" intake/ MAF/ TIH
Autotech internals
Corksport Pmm
Test pipe
SBC Rear Camber Arms
Playaj is offline   Reply With Quote
 Old 05-11-2013, 08:15 AM   #86
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
Look back two posts Dood. They've already said its an oddity since gen 1's seem to use two styles of tmm. If yours looks like the one above you may be clear. I'd suggest being patient.
sent with smiles and mouth hugs
Mods: stock
 Old 05-11-2013, 02:28 PM   #87
Playaj's Avatar
Yeah read that dood. Just letting them know I would buy now if they had it. I'm sure they wanna hear customer feedback, wouldn't you?
to be installed :
3 Port EBCS
Autotech internals
Corksport Pmm
Test pipe
 Old 05-13-2013, 01:17 PM   #88
CorkSport's Avatar
Posts: 3,416   (View Stats)
Yeah, we're at a bit of a standstill with the Gen1, you're pretty much going to have to look at your own mount which involves removing it. I wish I had better news but there doesn't seem to be much rhyme or reason on what cars used what mount from Mazda.
Cheers,
Joel
WWW.CORKSPORT.COM
 Old 05-13-2013, 01:23 PM   #89
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
ordered a tmm insert for my gen 1 last thursday. My gen 1 tmm bolt backed out and sheared a few months ago, and i replaced with a stock mount off of a 2012. So installing the insert should be a piece of cake.
The Following User Says Thank You to 2.0t03speed For This Useful Post:
AustinK (05-14-2013)
 Old 05-16-2013, 11:23 PM   #90
MS309's Avatar
Posts: 673   (View Stats)
MS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the world
Thanks!!!
have had the pmm installed for about 1000+ kms, it is for sure more settled in now. when I first had it on there I personally noticed a lot of engine noise in the cabin, now its quited down and much more tolerable in daily driving. is the difference noticable ? I think so, as it is with any mount once it breaks in.
also i feel if you run a catless downpipe the engine noise is slightly more amplified in the cabin.
'11 CWP Speed3
More torque than your right arm.
MS309 is offline   Reply With Quote
The Following 2 Users Say Thank You to MS309 For This Useful Post:
mrmonk7663 (05-16-2013)
 Old 05-16-2013, 11:25 PM   #91
mrmonk7663's Avatar
This is what I was hoping to hear Thanks.
 Old 11-07-2013, 12:54 AM   #92
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Ok, so my OEM transmission mount looks like this (this is the factory mount which I replaced because I thought it was failing, actually it was the PMM):
So it looks pretty much like yours. Do you happen to have any picture of the bottom side of your mount? The top side seem to be the same, and the part number printed on your mount is exactly the same as mine: B37F-39-070 (incoming WIN?).
I think I'm going to bite the bullet and order this insert, if it doesn't fit then I'll just order a gen2 OEM TMM for it ($220 here).
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 11-07-2013, 01:23 AM   #93
blackms3_71's Avatar
Posts: 2,250   (View Stats)
so any word on the gen 1 tmm? can I just order the gen 2 one and trim it? @Joel@CorkSport;
 Old 11-07-2013, 11:28 AM   #94
CorkSport's Avatar
The main issue with the Gen 1 is that there is (from what we can tell and what Mazda cann tell us) no rhyme or reason for which first gen car got which TMM so we have no way of telling customers if they can order or not. So even if you had the right TMM on a 1st gen to use our insert, you wouldn't be able to tell unless you pulled it out. But it will work with all of the 2nd gens.
Cheers,
Joel
p.s. I'm sorry that isn't the greatest answer, it's just what we have to deal with from Mazda.
WWW.CORKSPORT.COM
blackms3_71 (11-07-2013)
 Old 11-07-2013, 11:47 AM   #95
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Are you going to make an actual mount at some point or just the insert
Damond Built Speed 6
 Old 11-07-2013, 02:06 PM   #96
CorkSport's Avatar
It's still up in the air. We starting designing and protoyping one, but with what we envisioned, it may just be too expensive.
WWW.CORKSPORT.COM
 Old 11-16-2013, 02:30 PM   #97
Playaj's Avatar
Hope this helps. I have a 2009 and my mount looks like the pic in this thread but more than just the Oem insert was jacked up. I got a pu tmm on here for less than $20 so I'm thinking about ordering the tmm insert and comparing it to my jbr tmm
to be installed :
3 Port EBCS
Autotech internals
Corksport Pmm
Test pipe
 Old 11-24-2013, 01:56 AM   #98
Goodrich27's Avatar
Posts: 678   (View Stats)
Goodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the world
This mother vibrated quite a bit at first, 200 miles later and it has died down ALOT not for everyone but def worth it in my book
Sent from my phone whilst bojanglen.
Go fasters:Manley H beams and Wiseco 87.5mm Forged pistons with stock compression, GTX3076 with Tial 38mm EWG, Full Race exhaust manifold w/2000* ceramic coating, MD meth injection TB spacer and Devils Own DC30 WMI with DO14 nozzle, Cobb 3 port ebcs, Ultimate Racing V2 Catless DP, Relentless Customs PNP IM with VTCS delete, TR11 core with HTP under route piping,ACT 6 puck, Corksport catless RP and CBE, CPE Stage II RMM,Cpe side mounts, perm plate with MD sealed and VTA OCC, HTP 4in Intake,ISC N1 coilovers, CS RSB, Tial BPV, Auto tech internals, Cobb ap v3, CPE injector seals,ngk step colder plugs, JBR throttle body TIG and coolant bypass, Corksport polyurethane exhaust hangers, Motorcraft unicorn juice, t6 rotella, Stoptech slotted and drilled front rotors with posi quiet pads.
Rice:corksport led fogs, Corksport eyelids, Corksport hood struts ,blacked out genpu rims, red evil M front and rear, red calipers, Corksport black mud flaps, Corksport shift knob, powder coat red valve cover, Intercooler pipes, and black gloss intake manifold A pillar gauge mount w/ AEM AFR, Oil temp, and Oil pressure gauges.
Goodrich27 is offline   Reply With Quote
 Old 11-25-2013, 02:24 AM   #99
mituc's Avatar
Groans: 111
Got the insert today and no, it did not fit on the gen1 TMM. The TMM bushing is wider on the gen1 it seems, the insert is shorter and not as wide as the space it is supposed to go into.
mrmonk7663 (01-09-2014)
 Old 01-09-2014, 04:54 PM   #100
getemslough's Avatar
Posts: 163   (View Stats)
getemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the world
just installed mt PMM like 2 hours ago... holy jesus in heaven... its like the motor is sitting in the seat next to you its so stiff! cant wait for this mount to settle. there is 10 times the NVH my rx8 had with 80 duro mounts and an ingalls stiffy... that being said the way a rotary engine works is a million times smoother than a reciprocating engine so the difference in NVH is to be expected. i hope it relaxes a good bit.
as far as performance... wow, just wow. i live on a 2 mile gravel road full of ruts and the ms3 used to feel like it was going to fall apart going in and out of my property. now it kinda just... glides... its weird. i always assumed the suspension in this car was super sloppy but now i'm convinced it was 500lbs of motor sloshing around.
cornering is greatly improved as well feels like the car goes where its meant to and it doesn't seem like a suitcase full of bricks is sliding around under the hood anymore.
wheel hop... what wheel hop. torque steer... whats that? seriously the tires just dig in and she shits and gets. my left arm literally doesn't have anything to do under acceleration now...
all in all, beautiful piece of work and function is amazing! 8 out of 10 for me after only about 20 miles. now if the NVH dies down a good bit i would say its a full 10 of 10er in my book.
buy this mount! great job corksport!
---2009 CWP---ATP GTX2867r---COBB AP V3---CS HPFP---CS BERYLLIUM/COPPER INJECTOR SEALS---SELF PORTED INTAKE MANIFOLD---CS 3.5 SRI---
---PROTOTYPE XSPOWER V3 IWG MANIFOLD (BETA TESTER)---CS CATTED DP---CNT CATBACK---RPM/CX FMIC PIPING---TREADSTONE TR8---
---GRIMMSPEED 3 PORT EBCS---3BAR MAP/RPM HARNESS---NGK 6510---JBR 51R TRAY---3P/HKS SSQV IV---CS RECIRC TUBE---KOZMIC OIL DRAIN---KOZMIC EGR DELETES---
---JBR TB/IM TIGS---CS PMM---CS RMM---CS OCC---CS SKID PLATE---
---CS STEERING WHEEL---CS SHIFTER BUSHINGS---SURE SHORTCUT---JBR SHORT SHIFT LEVER---SURE AGS 621g---SURE AGS EXTENDER---
---KONI STR.T---H&R SPRINGS---PROGRESS RSB---MOOG ENDLINKS---17X9+45 RPF1---5MMSPACERS---255/40/17 NITTO NT555---JBR FLAPS---
--GTX BUILD COMPLETE--
--FREEKTUNE 383/404 ON PUMP--
--METH COMING SOON--
getemslough is offline   Reply With Quote
The Following User Says Thank You to getemslough For This Useful Post:
SpencerC (01-09-2014)
 Old 01-09-2014, 06:04 PM   #101
SpencerC's Avatar
Posts: 2,159   (View Stats)
Thanks. Ignore my post under your other post. We appreciate the feedback. Heck, I might have to buy one myself!
 Old 01-14-2014, 03:21 PM   #102
mituc's Avatar
Groans: 111
@Playaj, did you try the gen2 TMM? Did it fit your gen1?
 Old 01-14-2014, 03:30 PM   #103
Playaj's Avatar
No didn't try it yet, I have the jbr tmm on but I seen jbr in the other thread say it wouldn't work
to be installed :
3 Port EBCS
Autotech internals
Corksport Pmm
Test pipe
 Old 01-14-2014, 04:57 PM   #104
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Yknow I hear people say torque steer is non existent with the installation of motor mounts but under hard accleration especially in the lower gears I will still get some violent torque steer, coming hard out of a turn comes to mind as I get full boost as I straighten out. And im fully mounted with jbr's stiffest.
Playaj (01-14-2014)
 Old 01-15-2014, 09:59 PM   #105
Atticaz's Avatar
Posts: 621   (View Stats)
Atticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the world
It’s finally here!! The passenger side motor mount you’ve all been waiting for. If you’re tired of slamming your engine into the firewall, or just want to put all of those horses you spent so much money on to the ground, the new Passenger Side Motor Mount from is exactly what you’ve been looking for. [...]
Scratch that my post. found my info.
2017 Mustang V6 - Soon to be Supercharged
2007 MAZDASPEED3 - SOLD
Atticaz is offline   Reply With Quote
 Old 02-26-2014, 09:56 PM   #106
well i figured id update everyone on my review. ive put around 2,000 miles on my motor mounts so far. the nvh has settled down quite a bit, so much in fact that no one that rides in my car notices it at all now.
everything is still just as firm and responsive. i am more than happy with with both the quality and performance of the mounts.
thanks again corksport!
SpencerC (02-27-2014)
 Old 02-27-2014, 09:53 AM   #107
SpencerC's Avatar
This is awesome. Thanks a million for the review! Super stoked to hear you love it!
 Old 03-17-2014, 02:22 PM   #108
mituc's Avatar
Groans: 111
Sorry guys to revive this discussion in this thread, but I'm pretty set to use my CS tranny mount insert and my question is what other parts do I need to change to use the gen2 TMM on a gen1? Can anyone tell?
 Old 03-17-2014, 02:46 PM   #109
you need both parts of the tmm the top portion that bolts to the frame, the tripod, and the grade 10 bolt that goes into the tripod
mituc (03-17-2014)
 Old 03-18-2014, 06:56 AM   #110
mituc's Avatar
Groans: 111
Ok, but the holes on the transmission are the same I wonder? Will the gen1 tripod fit on a gen1 transmission?
 Old 03-18-2014, 07:05 AM   #111
yes the gen 2 tripod will fit i am using a complete gen 2 tmm with a corksport insert on my gen 1 trans.
The Following 2 Users Say Thank You to 2.0t03speed For This Useful Post:
kpuser1 (05-30-2014), mituc (03-18-2014)
 Old 03-18-2014, 12:51 PM   #112
mituc's Avatar
Groans: 111
Did you reuse the tripod bolts or had to order new ones with the new tripod? The guys from the dealer told me the bolts are different on the gen2.
They also confirmed that the transmission case is the same, so indeed the tripod should work.
Now, do you happen to know a part# of that metal small frame that comes on top of the TMM and bolts onto the car frame? Is it the battery box bracket, B37F-56-03Y? Will the gen1 battery box still fit?
 Old 03-18-2014, 12:56 PM   #113
i reused the gen 1 tripod bolts. The only bolt you have to bring over from the gen 2 is the grade 10 center bolt. i didn't have to change out any batter box bracket just the top and bottom half of the tmm and the center bolt.
mituc (03-18-2014)
 Old 03-18-2014, 01:15 PM   #114
mituc's Avatar
Groans: 111
So just to be clear, we need:
- the actual TMM;
- the 10 grade central bolt that fixes the TMM to the transmission;
- the transmission case bracket/tripod.
@CorkSport, I hope you see what you put us through so that we can use these awesome inserts, yes?
CorkSport likes this.
 Old 03-18-2014, 03:21 PM   #115
SpencerC's Avatar
Lol... We see.... maybe we will have an easier solution in the future.... hint...
mituc (03-18-2014)
 Old 03-18-2014, 11:29 PM   #116
mituc's Avatar
Groans: 111
Is there a time frame for this, should I wait, or you're still in the planning phase?
 Old 03-19-2014, 08:54 AM   #117
mituc's Avatar
Groans: 111
Ok, I just paid for a 3MPS BL TMM and bracket/tripod, about $370 in total, so I hope it worth the hassle just for using the $35 CS TMM insert. But knowing CS for so many years now I'd say it's an incoming epic WIN.
 Old 03-19-2014, 11:43 AM   #118
SpencerC's Avatar
...... I don't know what you are talking about?.........
 Old 04-04-2014, 03:54 PM   #119
mituc's Avatar
Groans: 111
Today I fitted the new Mazda 3 MPS BL (mazdaspeed3 gen2) TMM with the CS insert. The gen2 TMM alone is a lot better designed than the gen1. It also comes with a silicone insert itself and that's what the CS insert replaces.
The TMM fitting on the gear box bracket, that tripod, is also of a better design. It holds the mount better and prevents is from moving irregularly.
This TMM + the CS insert = pure WIN! There is NO, and I mean ABSOLUTELY NO increase in NVH over stock. I'm very picky about this stuff (NVH comfort in the car) and there is absolutely no change in NVH. The stiffness of the mounts naturally increases and the car behaves comparable with when I had a full set of urethane motor mounts installed on the car less the horrible NVH.
I wish CS did a similar insert for the PMM but because of how that oil filler bushing is designed that's not easy. Probably there are some viable solutions like what they find for the RMM: a beefier bushing to absorb the vibrations better than the current PMM does now..
Thank you @CorkSport!
The Following 3 Users Say Thank You to mituc For This Useful Post:
CorkSport (04-07-2014), kpuser1 (05-30-2014), Nliiitend1 (04-04-2014)
 Old 08-10-2014, 10:17 PM   #120
Yatta's Avatar
Posts: 1,862   (View Stats)
Well, just installed a PMM in my gen2 (used, with 10k miles on the mount per previous owner) and have to say, coupled with a CPE S2 RMM.
1. suspension seems to have no play, steering feels more responsive.
2. Vibrations - on cold start, higher, once warm same as with just the CPE S2 mount
3. Noise - in cabin noise is substantially higher, I should have taken a DB meter to it pre/post (I have one) but it is strange that vibes seem the same and noise isn't.
If you are considering this mount and haven't already replaced the stock unit, don't think about it, do it, if you have another PMM installed already you likely will be just as well with it, but being able to move the stock mount by hand and this mount, well, no way in hell.
Product Release! Mazdaspeed Protege / Mazda Protege Front Motor Mount CorkSport CorkSport 0 02-22-2013 10:10 AM
Page generated in 0.65678 seconds with 38 queries
