  • 1 Post By CorkSport
 Old 07-02-2013, 01:50 PM   #1
CorkSport's Avatar
Posts: 3,416   (View Stats)
Default Dual Product Release!! CorkSport Shift Knob and MazdaSpeed 6 Rear Differential Mount
After months of testing and making sure it couldn’t be broken, we are finally ready to release the CorkSport Mazdaspeed 6 Rear Differential Mount! With all the testing we have done on this part, we know it is the strongest available on the market, but don’t take our word for it. To quote Dennis Gardener, [...]
sl33py24 likes this.
The Following 8 Users Say Thank You to CorkSport For This Useful Post:
Chev954 (07-02-2013), Code Monkey (07-02-2013), cshunter (07-07-2013), deekspeed (07-02-2013), evil MS3 (07-02-2013), Kamaril (07-02-2013), Mazdazilla6 (07-02-2013), ZetaDrift (07-03-2013)
 Old 07-02-2013, 02:08 PM   #2
Kamaril's Avatar
Posts: 909   (View Stats)
Kamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the world
Groans: 77
the top of the knob is stamped with the gear pattern correct?
2011 MS3 BLACK MICA W/TECH PACKAGE
BNRSv3 - COBB 3 Port Boost Controller - BOSCH 3 Bar MAP Sensor - HTP 3" Intake (Candy Red)- CS Downpipe - CS LED Fog Lights - CS Interior LED Kit - CS Hood Strut Kit - COBB AccessPORT - JBR Adjustible Rear Sway Bar - JBR Solid Shifter Bushings - SURE Flow M3 W/ Res Delete - MangnaFlow 4x3.5" Stainless Exhaust Tips - AutoTech Internals - JBR 88a Dogbone RMM - H&R Lowering Springs - NGK Iridium Step Colder - Beachshoer's Pnp Intake Manifold W/ VTCS Delete - TurboSmart Plumb Black BPV - CX Racing FMIC - 18x8 Bronze MB Motoring Battles - Nitto Motivo 235/40/18 - Hawk HPS Brake Pads - Block8head Dual Gauge Pod - Prosport Evo Boost and Coolant Temp Gauges - Autodvdgps Touch Screen DVD Player W/ Navigation - CS Radiator Cover - CS Exhaust Manifold Cover - CS OCC
Stratified Tune In Progress
SCCA Member# 450495
Class - SMF
TRMotorsport C3 17x9 Hancook 255/245 RS-3
LIQUOR AND WHORES
Kamaril is offline   Reply With Quote
 Old 07-02-2013, 02:09 PM   #3
evil MS3's Avatar
Posts: 1,294   (View Stats)
Groans: 55
No
The Following 3 Users Say Thank You to evil MS3 For This Useful Post:
Kamaril (07-02-2013), ZetaDrift (07-03-2013)
 Old 07-02-2013, 02:43 PM   #4
DamagedGoods's Avatar
Posts: 304   (View Stats)
DamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the world
Has this mount been designed to clear your rear sway bar without adjustable end links?
2007 Mazdaspeed 6 - Bolted, Methed, Tuned
DamagedGoods is offline   Reply With Quote
 Old 07-02-2013, 02:47 PM   #5
CorkSport's Avatar
Works with all stock and aftermarket parts!
WWW.CORKSPORT.COM
Colin1337 (07-07-2013), SpeedRebirth (07-02-2013)
 Old 07-02-2013, 07:35 PM   #6
nextgenerationx1's Avatar
Posts: 536   (View Stats)
nextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the world
Groaned at 27 Times in 13 Posts
was about to pull the trigger n buy, but saw that its not stamped with the gear pattern, so i'm debating
06 Mazdaspeed 6
Precision 5858cea, PG turbo mani, 3" catless vband DP, 3" JBR intake, Cobb AP, Cobb EBCS
3 bar, TR8 intercooler, CPE 3" single exhaust/magnaflow muffler, NJSPEED P&P intake mani
KMD internals, CPE safe seals, GFB turbo fuse, Turbosmart 50/50
JBR tranny mount, AWR dogbone, Turbine Tech front/rear diff mount, Whiteline Rsb,
AWR rear adjustable endlinks, BC coils (suckie), OZ Ultraleggeras,
waiting to install Devils own meth kit,
ATVFREEK tuned!
PS: Forever BT slow
nextgenerationx1 is offline   Reply With Quote
 Old 07-02-2013, 07:47 PM   #7
evil MS3's Avatar
Groans: 55
Don't know where your gears are?
A little tapa tapa taparoo...
cshunter (07-03-2013)
 Old 07-02-2013, 07:55 PM   #8
Nope! i like the look, i don't like it looking so empty, idk maybe it will grow on me
06 Mazdaspeed 6
ATVFREEK tuned!
PS: Forever BT slow
 Old 07-03-2013, 08:01 AM   #9
cshunter's Avatar
Posts: 1,312   (View Stats)
I like the fact that it does not show where the gears are, and that it retains the look of a OEM style knob.
2013 CWP That's slow
Previous: MILTUNED E85 K04
 Old 07-03-2013, 09:14 AM   #10
someguy's Avatar
Posts: 914   (View Stats)
Would be nice without the corksport stitching on it...very sleek.
 Old 07-03-2013, 10:06 AM   #11
DoMiNic's Avatar
Posts: 571   (View Stats)
DoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the world
Groaned at 8 Times in 7 Posts
I am really on the fence with the shift knob, looks great but stitching look like it will only last a couple months.. I assume there is a warranty on these.
TIP/AP-OTS-2/MS-SRI/JBR-88d-RMM/HPFP-Autotech/Ebay Downpipe/JBR-SP/Forged-BPV-v1.2/JBR-Boost-Tubes/WL-RSB/SPEC-CA/TWM-STS/JBR SB/TWM-Phantom-4in extension/Eibach-ProKit/Koni-Yellows/JBR-5mm-spacers/PCed-black-RX8s/Alpine-SWA-10S4/Alpine-M250/JBR-recirc-tube/DRAMA-E28-Tuned
Sold
08 FJ Cruiser Expo build in progress...
DoMiNic is offline   Reply With Quote
 Old 07-05-2013, 02:11 AM   #12
littleloogy's Avatar
Posts: 4,005   (View Stats)
Got the knob installed today. Feels great, the knob has a more natural feel to it. Not to heavy not to light. The stitching matches really well to the stock stitching on the boot. Looks way better then factory.
Sent from my brain
The Following 4 Users Say Thank You to littleloogy For This Useful Post:
ABolewski (07-07-2013), Cheapspeed (07-07-2013), cshunter (07-07-2013), Gibbo (07-05-2013)
 Old 07-05-2013, 02:35 AM   #13
warlord's Avatar
Posts: 756   (View Stats)
Nice shape and color. CS should have used a different style stitching though.
2014 IS350 (sold)
2013 MS3 Stage2 E85 (sold)
2011 MS3 Stage2 (sold)
warlord is offline   Reply With Quote
The Following User Says Thank You to warlord For This Useful Post:
littleloogy (07-05-2013)
 Old 07-05-2013, 08:30 AM   #14
6ixof1's Avatar
Posts: 700   (View Stats)
Damn damn damn good looking diff mount. I may have to swap out the sure and slap this sucker in and get a big ass Corksport vinyl. After the BBK kit me thinks.
Black Mica Mazdaspeed 6
The Mad Scientist Tunings
 Old 07-07-2013, 02:23 AM   #15
stuntz89's Avatar
Posts: 169   (View Stats)
stuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the world
I been waiting for that diff mount.... Cant wait till i get paid
#3527. On genpus for winter >=)
5zigen Hyper 5ZR for summer
Magnaflow CBE, CPE Catted DP, Corksport stage 2 SRI w/Corksport TIP, Turbosmart Dual Port BOV, 8000k HID Foglights,Block8head Vent pod w/52mm Prosport Boost Gauge, AWR RMM, AWR Passenger Side MM, JBR TMM, Bilstein HD Shocks Rear, Koni Sport Shocks Front, H&R Sport Springs, STI front lip, 35%Tint all around, Cobb AP, ACT 6 Puck Disc w/ ACT prolite Flywheel, Motul M300 Trans Fluid,PTP CDFP internals, Whiteline RSB, Corksport Rear Diff Mount, JDMGOODIE OEM Vent Visors, Mirimoto Mini HD Bixenon Projectors, ETS TMIC, Tuned by boost_creep ...
Tune in progress 8)
im on my way
h
stuntz89 is offline   Reply With Quote
The Following User Says Thank You to stuntz89 For This Useful Post:
memin (07-07-2013)
 Old 07-07-2013, 10:41 AM   #16
Colin1337's Avatar
Posts: 1,330   (View Stats)
Colin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the world
Def going to get that dif mount in a couple months, especially since it works with any rsb
Sent via banana
2005 CTS-V
KCCO
2006 Mazdaspeed6 SOLD
COBB AP /|\ 3' Magnaflow CBE /|\ Autotech FPI /|\ COBB SF Intake /|\ NGK plugs /|\ RMM /|\ Megan springs /|\ GReddy RS BOV /|\ Strapped diff /|\ eGay catless DP /|\ BSD 'kit" /|\ PTP oil pan baffle /|\ Custom FMIC /|\ Spin on oil filter conversion
1995 Miata SOLD
Tokiko Illumina Adjustables | FM springs | HardDog M2 rollbar w/Single diagonal | GV rep front lip | Flyin' Miata rear shock mounts.
Colin1337 is offline   Reply With Quote
Dual Product Release!! CorkSport Mazdaspeed 3 Passenger Side Motor Mount and Transmission Insert CorkSport CorkSport 143 04-13-2016 12:00 AM
Page generated in 0.36223 seconds with 33 queries
