| CorkSport To say that CorkSport is passionate about Mazda Performance is understatement. It is the essence of what we do. Our mission to offer unparalleled customer service and support, an uncompromising commitment to the community, and deliver top quality performance parts is demonstrated with each product we develop to help fulfill your vehicles performance potential. At CorkSport we believe it doesn’t have to come in a fancy package or be the most expensive product on the market to be the best. |
| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
(Thread Starter) | Not Ranked : 0 score This part is something which is really a new part! We made a replacement firewall heat shield to get rid of the ugly foam and aluminum foil version Mazda made. It is made from aluminum and ceramic coated to be able to withstand the heat generated from the turbo. Link for the Mazdaspeed 3 Heat Shield -Derrick |
| The Following 12 Users Say Thank You to CorkSport For This Useful Post: |
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Not Ranked : 0 score I'll have to get one, my stock is tore up
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
| Not Ranked : 0 score how many horsepower does this add?
(Thread Starter) | Neutral : +1 score |
| The Following 7 Users Say Thank You to CorkSport For This Useful Post: | CMajor (08-09-2016), KiwiFlavor (07-28-2016), mooseaidz (07-28-2016), MSP6 (07-31-2016), RazoE (07-31-2016), sharksinspace (07-28-2016), WetzMS3 (07-28-2016) |
![]() Join Date: Oct 2011 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 601
Groans: 106
| Not Ranked : 0 score No side shots to see clearance to manifold? |
(Thread Starter) | Not Ranked : 0 score We kept the same profile as the OEM unit with a small difference for wastegate actuators in the OEM location. We made a little more clearance there. |
| Not Ranked : 0 score @moosecakez; probably already has this on the way to his house.
| The Following 4 Users Say Thank You to WetzMS3 For This Useful Post: | KiwiFlavor (07-28-2016), macdiesel (08-08-2016), monkey.bones.007 (07-28-2016), stockms3 (07-09-2017) |
Groans: 106
| Not Ranked : 0 score Data on the temperature delta across the heat shield between this and the oem? |
| The Following User Says Thank You to JSmith For This Useful Post: | Voltwings (08-23-2016) |
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP | |
| The Following 13 Users Say Thank You to WetzMS3 For This Useful Post: | BLKspd5 (08-08-2016), CMajor (08-09-2016), Code Monkey (08-08-2016), DingoDave (09-04-2016), ericrapp0507@gmail.com (08-23-2016), g00s3y (07-28-2016), KiwiFlavor (07-28-2016), mooseaidz (07-28-2016), PapaBruno (08-11-2016), riflex (08-02-2016), Shwaykid (07-28-2016), xfeejayx (08-23-2016), Yatta (08-08-2016) |
![]() ![]() Join Date: May 2013 Location: Buffalo Grove, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 245
Groaned at 61 Times in 31 Posts
| Not Ranked : 0 score LOL THAT GIF DOE
__________________ DUMB MILLENNIAL RICER Last edited by mooseaidz; 07-28-2016 at 11:28 PM. Reason: MSF Database - Automerged Doublepost | |
(Thread Starter) | Not Ranked : 0 score 10 degrees exactly. It was a bit weird having a nice round number in the data. |
![]() Join Date: Jan 2012 Location: Mesa, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 620
| Not Ranked : 0 score Sweet, I can't help but notice my torn heat shield every-time I open the hood! |
![]() Join Date: May 2010 Location: Benton, AR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,028
| Not Ranked : 0 score Now that is a part I could use. My foam one has seen better days. Sent from my iPhone using Tapatalk
__________________ 2010 Mazdaspeed 3 Liquid Silver Metallic HTA 3076 | HTP 4" Intake, battery tray, under mount piping | CPE Exhaust Manifold, downpipe, FMIC & Stage 2 RMM | MD TMM and PMM | Tial MV-R ewg w/ Kozmic dump tube | VCTS delete/Ported IM | JBR OCC, EGR delete, BSD w/ oil pan baffle & RSB | SP63 Oil Cap Breather | Synapse SB BPV | UR CBE | Autotech HPFP | H & R Coilovers | Whiteline Endlinks | Manley Pistons & Rods | L19 Head Studs | Kozmic 6th Port w/ DW65c ITFP | Snow Performance Stg 2 Meth | JMF Manifold | SouthBend Stg 3 Endurance Clutch | Tuned with |
Groans: 438
| Not Ranked : 0 score Beautiful, I don't even use mine anymore it's so horrible looking. Will be getting this eventually.... When I have $120+ that I feel like pissing away...
__________________ All good things must come to an end... |
Groans: 128
| Not Ranked : 0 score like to see a clearance pic on a ms3 with Corksport turbo wga
(Thread Starter) | Not Ranked : 0 score Our shop car has the CS turbo and the heat shield. We made the extra wastegate heat shield clearance specifically for our turbo so you will be good. Derrick |
| The Following User Says Thank You to CorkSport For This Useful Post: | mxlplx71 (07-29-2016) |
![]() Join Date: Jan 2012 Location: Georgetown, Ky.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 689
Groaned at 45 Times in 22 Posts
| Not Ranked : 0 score I'll be getting one soon!
__________________ 2010 Mazda Speed3 Autotech HPFP internals, Cobb AP V3, Corksport Springs, Skid Plate, TIP, TMIC, SRI, JBR 88 duro dogbone, RSB, Shifter bushings, Shift knob, 80 Duro TMM and PMM, OCC, Silicone Bypass Hose and Boost Tubes, Ulimate Racing axle back, Catless RP, Catted DP, Forge Motorsports V2 BOV, 6000k DDM low beams and fogs, iRotors cross drilled and slotted rotors, Akebono Ceramic pads, Tanabe Front Strut Tower Bar, Ruff Racing 355 wheels, 18x8, +40, 235/40-18 tires FREEKTUNED! 2003 Chevy S-10 2014 Toyota Camry 2011 Dodge Challenger R/T 1997 Geo Prizm |
![]() Join Date: May 2014 Location: Cincinnati, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 151
| Not Ranked : 0 score Does this heat shield fit with the CP-E exhaust mani? My OEM heat shield is gone and I wanted to run some wires and my vacuum line to the EWG behind the CS heat shield if it will fit. |
Yes it will work. Disclaimer on this picture. The person who installed the turbo smashed the lower heat shield and two upper heatshield brackets flat in a hack job putting the car together. There is more clearance with the manifold that what is shown. Without spending 30 minutes fixing everything this is the best picture I could get. ![]() -Derrick | |
| The Following 3 Users Say Thank You to CorkSport For This Useful Post: |
![]() Join Date: Oct 2012 Location: Colorado Springs, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 757
wouldn’t etching the logo be a better way; I have a vivid imagination and see a FLIR image of your logo on my firewall
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// | |
| The Following User Says Thank You to Yatta For This Useful Post: | CorkSport (08-08-2016) |
![]() Join Date: Apr 2014 Location: Fairfax, VA
| Not Ranked : 0 score can you guys just toss me one? want one but don't wanna pay $120 for it lol. i absolutely love the look of it though
__________________ 2007 Cosmic Blue Mica Mazdaspeed3 GT Mazdaspeed CAI, Autotech HPFP, Corksport TMIC, E-cutout, corksport test pipe, stratified tune In the works: Built engine- Bored .020 over, Eagle Rods, Wiseco 88mm pistons, Damond PCV plate, corksport injector seals, ported IM |
| Not Ranked : 0 score Is it made out of heat repellent unobtanium?
__________________ |
| The Following 4 Users Say Thank You to Tomas For This Useful Post: | CMajor (08-08-2016), ericrapp0507@gmail.com (08-23-2016), monkey.bones.007 (08-08-2016), WetzMS3 (08-08-2016) |
![]() | | #24 | ![]() |
| The Following 5 Users Say Thank You to WetzMS3 For This Useful Post: | CMajor (08-08-2016), KiwiFlavor (08-10-2016), monkey.bones.007 (08-08-2016), mooseaidz (08-10-2016), Tomas (08-12-2016) |
![]() | | #25 | ![]() |
__________________ DUMB MILLENNIAL RICER |
| The Following User Says NO Thank You to mooseaidz For This Un-useful Post: | WetzMS3 (08-11-2016) |
![]() | | #26 | ![]() |
![]() Join Date: May 2013 Location: CO
Rep Power: 2407 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,487
| Not Ranked : 0 score I needed this laugh. Fucking Mondays. crapatalk, yes it sucks for free. |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score 10 degrees higher. The OEM shield does a good job at insulating, it just looks terrible. Derrick |
| The Following User Says Thank You to CorkSport For This Useful Post: | Yatta (08-09-2016) |
![]() | | #28 | ![]() |
| Not Ranked : 0 score i agree it looks terrible, but if its functional.......... couldn't you guys incorporate some sort of fiberglass material on the underside to have better temperature control?
![]() | | #29 | ![]() |
![]() Join Date: Mar 2014
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score The heat shield would work far better if it had some sort of radiant barrier on it, ie the gold foil stuff. Flat black is really the worst choice for a heat shield exposed to the massive infrared coming off of the manifold and turbine. |
![]() | | #30 | ![]() |
It adds more cost. Last edited by CorkSport; 08-09-2016 at 02:50 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #31 | ![]() |
![]() Join Date: Nov 2010 Location: Reading, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,158
Groans: 731
| Not Ranked : 0 score guess you missed the part in the very first post where it says it's a ceramic coating.
__________________ Mods: stock Eventually I'll pay for how I am....but it won't be by the hand of any of you faggot fucks here. |
![]() | | #32 | ![]() |
| Not Ranked : 0 score but even so, they said its still a 10 degree increase from stock.... if they incorporated a better heat resistant material on the underside they could bring the temps down. maybe slightly more cost but if its only like $20 more id buy it
![]() | | #33 | ![]() |
![]() Join Date: Apr 2012 Location: port orchard, w.a
Rep Power: 501 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
| Not Ranked : 0 score 10 degree increase then stock? meaning what? the air temp with this installed is 10 degrees hotter? isn't that worse then stock
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned |
![]() | | #34 | ![]() |
| Not Ranked : 0 score yep, thats what they said above. it is not as effective as a stock heat shield..... but it looks nicer! pros and cons
| The Following User Says Thank You to droflow For This Useful Post: | blackms3_71 (08-10-2016) |
![]() | | #35 | ![]() |
![]() Join Date: Nov 2011 Location: Crowley, TX
| Not Ranked : 0 score Can this one be added on top of and used in addition to the ugly stock one? |
| The Following User Says Thank You to redneck4Christ For This Useful Post: | Yatta (08-09-2016) |
![]() | | #36 | ![]() |
| Not Ranked : 0 score @CorkSport; can you make me a heat shield made of aluminum, ceramic coated chrome, with a fiberglass backing and tiger striped DEI tape on the front? Oh, also make it clear a top mount 35r on a speed 3 please. Thanks.
![]() | | #37 | ![]() |
__________________ 2007 Cosmic Blue Mica Mazdaspeed3 GT Mazdaspeed CAI, Autotech HPFP, Corksport TMIC, E-cutout, corksport test pipe, stratified tune In the works: Built engine- Bored .020 over, Eagle Rods, Wiseco 88mm pistons, Damond PCV plate, corksport injector seals, ported IM | |
![]() | | #38 | ![]() |
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// Last edited by MS3Shadow; 08-10-2016 at 08:26 AM. Reason: merge posts | ||
![]() | | #39 | ![]() |
| Not Ranked : 0 score Just opened my package today and I was surprised to find some candy along with a Miata post card. I asked for gen 2 speed post card, they emailed me said they didn't have one but they did not disappoint. It's the little things haha. I am inclined to add some sort of heat reflective material like you guys were talking about but overall it feels like a quality product. I'll post some pics when I get it installed Last edited by CMajor; 08-12-2016 at 02:29 AM. Reason: Adding to post |
| The Following User Says Thank You to CMajor For This Useful Post: | ericrapp0507@gmail.com (08-23-2016) |
![]() | | #40 | ![]() |
| maybe you take a picture of it installed on top of the oem one?
| Can anyone tell me the part number for the firewall heat shield | 86AmishMs3 | Mazdaspeed3/6 General Discussion | 12 | 07-09-2015 11:00 AM |
