| CorkSport To say that CorkSport is passionate about Mazda Performance is understatement. It is the essence of what we do. Our mission to offer unparalleled customer service and support, an uncompromising commitment to the community, and deliver top quality performance parts is demonstrated with each product we develop to help fulfill your vehicles performance potential. At CorkSport we believe it doesn’t have to come in a fancy package or be the most expensive product on the market to be the best. |
![]() | | #41 | ![]() |
![]() Join Date: Jul 2010 Location: Riverside,CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 917
| Not Ranked : 0 score
__________________ [SIGPIC][/SIGPIC] 2008.5 CWP Speed3 GT - SOLD / ![]() 1991 Ford Mustang LX 5.0 SSP 331 Stroker 9:1 compression - AFR 185 Heads ported to 205 specs - 1.6 Roller Rockers - Comp Turbo Cam - Edelbrock RPM Performer II Upper and Lower intake mani - 24# injectors - 70mm throttle body and EGR spacer - C&L Intake - BBK Headers - MSD Billet Distributor - MSD Coil - Ford Racing Wires - MSD Ignition - A/C delete - Built 3 spd With reverse manual valve body - B&M Shifter - Aluminum driveshaft - 3.55 gears - Moser 31 spline Axles - Nitrous Express 125 shot - 5 lug conversion With SN95 Brakes |
![]() | | #42 | ![]() |
| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
(Thread Starter) | Not Ranked : 0 score Good question, we didn't have them at the time of testing (we've been doing this research for quite some time). But the dimensions haven't changed so the results should be the same. The old one was good, the new one is probably even better! So no worries there. Cheers, Joel Last edited by CorkSport; 04-29-2013 at 07:35 AM. |
| The Following User Says Thank You to CorkSport For This Useful Post: | Easter Bunny (04-29-2013) |
![]() | | #43 | ![]() |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Not Ranked : 0 score I thought it was a well known fact CP-e got their parts from APR....
__________________ [01:31 PM] SoAgg159: my dick is called "quarter mile" it's about 1/4" long and i can give about 14secs of pleasure [07:06 PM] DarkHeartMS6: yeah. I actually hope i catch my wife with another dude. gives me an excuse to open the emergency door and bail. LOL [09:13 PM] Pu Manchu: i like to take my gf through the drive thru so i can prove that i can pleasure a woman |
| The Following User Says Thank You to forcedinduktion For This Useful Post: | Tokay444 (04-30-2013) |
![]() | | #44 | ![]() |
![]() Join Date: Sep 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 315
| Not Ranked : 0 score Can you tell why the KMD's dont hold FP at high loads (2.0+)?
__________________ 304whp/360tq Vdyno 1.01 CF Cobb AP, Sure 3" Full3 Aeros Intake, Autotech Internals, M2 DP, 3" CP-E Single Exit (w/resonator), 3.25" ETS, PnP'ed IM w/VTCS removed, 1/16"Sure TIG spacer Synapse BPV, AWR 70 Duro RMM, JBR 70 Duro TMM, Denso 1-Step Colder Plugs, TWM Shifter Bushings, SM OCC, Custom Shift Knob, Custom Shifter Weight, SURE Shorcut, H&R Springs, Tenzo DC-6 Wheels |
![]() | | #45 | ![]() |
![]() Join Date: Sep 2011 Location: Stockholm Sweden
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,687
Groans: 33
Good work CS! Nice to see comparisons like this that haven't been done yet (as far as i know/have seen)
__________________ Mazdaspeed6 -06 Tuned with by Alex@StratifiedCP-E Atmosphere Kit GTX3076 Tial 0.82AR / EWG / 3,25" MAF / Catless DP Simons 3" Catback CP-E Diff Mount HDI FMIC HTP Battery Relocation Corksport: Rear Brace Bar - Front Strut Bar - Stubby Antenna - Interior + Underhood LED Kit JBR: TMM+PMM+RMM - Short Shift Kit /w Bushings - TIG Throttle - Coolant Bypass - EGR Delete - JBR OCC Stage 2 Whiteline Rear Swaybar SPC Camber Joints Turbosmart BPV Autotech Internals SURE Juggernaught Stratified Guardian Angel & Boost Dial NGK IX @ 0.025 Bosch 3 bar MAP w/ PNP Harness Block8Head Dual Gauge Pod Defi Racer Boost & Oil Pressure & Oil Temp Techna-Fit Clutch Line + Brake Lines ATE Super Blue Racing ProSport Oil Filter Adapter Mazda Spin-On Conversion + NPT/BSPT adapter Not installed yet: SP63 longblock, FreekTune 4" Intake, JBR TIG IM, DM Meth Spacer 290 AWHP / K04 370 AWHP / GTX3076 @ 23 psi | |
![]() | | #46 | ![]() |
(Thread Starter) | Not Ranked : 0 score Whoops, missed that, thanks. That's what I get for working on the weekend.... |
![]() | | #47 | ![]() |
![]() Join Date: Aug 2008 Location: Orange County NY
Rep Power: 2267 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,484
| Not Ranked : 0 score First off awesome blog, someone needed to step up and review the fuel pumps. I am a little confused though as I have personally seen cp-e's stock of fuel pumps. None of them had an apr sticker on them. I was down there a couple months ago and again last weekend. Are you sure this is this was bought from cp-e or one of it's vendors? I know for a fact that cp-e tests their pumps in house and after the test they put numbered cp-e sticker on as well as a certificate of testing. cp-e also puts a serial number on both the pump and certificate. All cp-e serial numbers are in sequential order and I can tell you for a fact they are no where near 3629 as in your photo. Part numbers are also different as the cp-e part number is MZR23HPFP. @superskaterxes; was right in questioning this. Please PM me or email me so we can get to the bottom of this.
__________________ cp-e-FMIC/cp-e-HPFP/cp-e-Xcel Nano Intake/cp-e-Nviscid TIP/cp-e-BOV Kit/cp-e-Stage2 RMM/cp-e-xFlex Passanger & Driver Motor Mounts/cp-e-catted DP/cp-e-Nexus cat-back exhaust/cp-e-tow plate/cp-e-Tripple Gauge Pod/Rally Armor-Mud Flaps/TWM-Base Bushings/TWM-Shift Weight/Street Unit-Washer Fluid Cap/Street Unit-Oil Cap/Konig-Milligram/Corksport-Rear Sway Bar/Corksport-Aluminum Skidplate/StopTech-Sport Brake Kit/GTSpec-rear v-brace/GTSpec-link reinforecement panel/GTSpec-rear lower tie bar/GTSpec-4 points ladder brace/Lamin-x-Headlight film/Lamin-x-Taillight film/TWM-Full replacement shifter/TWM-Big Type R knob & Hybrid Knob/TWM-Shift boot/3M-1080 Matte Dark Grey Wrap/3M-1080 Brushed Steel Wrap/Tial-BPV/DG Motorsports-CF front lip/DG Motorsports-CF Rear wing extention/Sonic Tuning-Coilovers/COBB Tuning-AccessPort/ |
| The Following 3 Users Say Thank You to Grumpyjap For This Useful Post: |
![]() | | #48 | ![]() |
![]() Join Date: Jun 2011 Location: Laurel, Maryland
Rep Power: 3780 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,647
Groans: 493
Just making sure everyone understands the path at which this pump took during its life.
__________________ //KILLAH BUILT, SPEED PERF6RMANC3, TUNED BY THE SUPERSKATER// 700HP CLUB Former World Record Mazdaspeed 60' 1.603 11.479@124mph 10second car with an 11second driver #DIX -Builds 700hp MS6, buys miata, sells said MS6! | |
| The Following 7 Users Say Thank You to Downmented For This Useful Post: | 86AmishMs3 (04-30-2013), El_Diablo (05-03-2013), Fobio (04-30-2013), Menace1 (05-06-2013), Mike@Stratified (05-03-2013), Nliiitend1 (04-30-2013), SLOWHATCH (05-03-2013) |
![]() | | #49 | ![]() |
This has gotten pretty off topic, many of us are confused as to why this is some sort of sticking point for a few people. It was assumed to be common knowledge for many but even then, it really shouldn't matter. If they have an exclusive deal then it does become their part. The real thing to remember is that it is a good pump and does a good job. | |
| The Following 14 Users Say Thank You to CorkSport For This Useful Post: | ABolewski (05-02-2013), cshunter (05-07-2013), Easter Bunny (05-06-2013), El_Diablo (05-03-2013), evil MS3 (04-30-2013), faeker (04-30-2013), Jeremy3eb (04-30-2013), jseams (05-02-2013), mdl3v8 (04-30-2013), memin (05-01-2013), Micha (05-06-2013), sidekick (05-03-2013), tclegg (05-17-2013), Todd98SE (04-30-2013) |
![]() | | #50 | ![]() |
Groans: 793
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals Last edited by Tokay444; 04-30-2013 at 06:37 PM. Reason: MSF Database - Automerged Doublepost | ||
| The Following 16 Users Say Thank You to Tokay444 For This Useful Post: | charlesfist (04-30-2013), Downmented (04-30-2013), Easter Bunny (05-06-2013), El_Diablo (05-03-2013), faeker (04-30-2013), forcedinduktion (04-30-2013), jseams (05-02-2013), madspd6 (05-13-2013), Mauro_Penguin (04-30-2013), memin (05-01-2013), Menace1 (05-06-2013), Micha (05-06-2013), ms3blackmica (04-30-2013), Nliiitend1 (04-30-2013), robry (04-30-2013), SarcasticOne (04-30-2013) |
![]() | | #51 | ![]() |
![]() Join Date: Jul 2009 Location: Ville, KY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,037
| Not Ranked : 0 score |
| The Following 4 Users Say Thank You to charlesfist For This Useful Post: |
![]() | | #52 | ![]() |
![]() Join Date: May 2012 Location: Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 255
| Not Ranked : 0 score When can we expect part 3? |
| The Following User Says Thank You to allo80 For This Useful Post: | mdl3v8 (04-30-2013) |
![]() | | #53 | ![]() |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold | |
| The Following 6 Users Say Thank You to 86AmishMs3 For This Useful Post: | ABolewski (05-02-2013), Downmented (04-30-2013), Easter Bunny (05-06-2013), i8urgti (05-22-2013), SLOWHATCH (05-03-2013), that1rowdyracer (05-06-2013) |
![]() | | #54 | ![]() |
![]() Join Date: Aug 2008 Location: Ashburn, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 305
| Not Ranked : 0 score This is a a sticking point because no part 3 yet. Not much to discuss on part 2 of any interest, we need moar!
__________________ 2006 Black Mica MS6 - Sold 10/15 |
| The Following 2 Users Say Thank You to shadesofgray19 For This Useful Post: | allo80 (04-30-2013), Easter Bunny (05-06-2013) |
![]() | | #55 | ![]() |
| Not Ranked : 0 score Pert 3 !?!? Knowledge is power... Upgraded internals is power!!! |
![]() | | #56 | ![]() |
![]() Join Date: Nov 2010 Location: Lido Beach,NY
Rep Power: 8624 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,845
Groans: 95
| Not Ranked : 0 score :-D Sent from fastest ko4 Pu!
__________________ Nator is what it does. |
![]() | | #57 | ![]() |
| Not Ranked : 0 score Any difference in stroke length between internals? Is there any way to modify their length to increase stroke and thus more flow?
![]() | | #58 | ![]() |
Groans: 95
| Not Ranked : 0 score Stroke is fixed by the lobe on the cam, so that's out unless you play with a new profile on teh cam. Sent from fastest ko4 Pu!
![]() | | #59 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson |
![]() | | #60 | ![]() |
| Not Ranked : 0 score Any updates? |
![]() | | #61 | ![]() |
Groans: 338
| Not Ranked : 0 score corksport is the biggest tease. Cut the foreplay, i'm ready to blow my load.
![]() | | #62 | ![]() |
| Not Ranked : 0 score Currently we haven't seen the DI system run out of fuel on the pump end before the injectors. So unless either pressure is increased or volume is the current pumps get the job done.
![]() | | #63 | ![]() |
(Thread Starter) | Not Ranked : 0 score Volume you say??? interesting... |
| The Following User Says Thank You to CorkSport For This Useful Post: | El_Diablo (05-06-2013) |
![]() | | #64 | ![]() |
![]() Join Date: Feb 2013
| Not Ranked : 0 score Need part 3. And Imma need you to come out with your pump before I have to buy a different one. |
![]() | | #65 | ![]() |
| Banned ![]() Join Date: Jan 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 125
| Not Ranked : 0 score Everybody just chilllllll. And good things will come. |
| The Following User Says Thank You to AustinK For This Useful Post: | kritz (05-14-2013) |
![]() | | #66 | ![]() |
Groans: 95
| Not Ranked : 0 score Yes they will! Sent from fastest ko4 Pu!
| The Following User Says Thank You to kritz For This Useful Post: | AustinK (05-14-2013) |
![]() | | #67 | ![]() |
| Not Ranked : 0 score I'm gettin cold from all this chillin |
![]() | | #68 | ![]() |
Groans: 769
| Not Ranked : 0 score Fuck that... turn the heat up and get us the conclusion to this!
![]() | | #69 | ![]() |
![]() Join Date: Dec 2010
| The Following User Says Thank You to 2010_MS3 For This Useful Post: | AustinK (05-15-2013) |
![]() | | #70 | ![]() |
Groans: 769
| The Following User Says Thank You to El_Diablo For This Useful Post: | AustinK (05-15-2013) |
![]() | | #71 | ![]() |
![]() Join Date: Mar 2013 Location: Huntsville, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,402
| Not Ranked : 0 score I suspect my old DD will be sold tonight and I'll be in the market for AP/internals and more by Friday, need more info MEOW. I'm about to have to do something filthy to get my AT internals...
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) |
![]() | | #72 | ![]() |
| Not Ranked : 0 score I never took apart the stock HPFP, but how hard would it be to machine a new housing to allow for a larger or longer plunger? Without disassembling one, it seems like a very simple part or that it works on basic principles. I'd be willing to pay a grand or a little more for a brand new pump design that eliminated the need for port injection or 5th port. If not eliminate PI, at least move the requirement for up past 500-600 WHP if the injectors could handle that flow.
![]() | | #73 | ![]() |
![]() Join Date: Nov 2011 Location: Lex. Park, Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 866
__________________ '12 MS3 Black Mica w/ Tech COBB AP V3 >> AUTOTECH HPFP >> HTP 3.5" >> ATP DP (catless) >> AXLEBACK (no mufflers) >> COBB PIPING/TR6 CORE >> JBR RMM >> SSP/BUSHINGS >> RSB >> STG. 2 OCC >> HYPNOTIC TUNED: tehmadscientist & senor finkle | |
![]() | | #74 | ![]() |
![]() Join Date: Jun 2011 Location: australia
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score Considering we already max out the injectors (110-115% IDC) don't think it'll make any difference
__________________ OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPVNEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP |
| The Following 3 Users Say Thank You to SarcasticOne For This Useful Post: |
![]() | | #75 | ![]() |
| Not Ranked : 0 score Cobb AP goes up for sale on used section the day I order new... √ CS releases info on new internals the day I order ATs from those that shall not be named... ??? With my luck these will be $250 and install themselves while giving you a handy, and available tomorrow.
| The Following 5 Users Say Thank You to JgamB For This Useful Post: | allo80 (05-17-2013), Easter Bunny (05-22-2013), memin (05-20-2013), Roddiy (05-21-2013), ZetaDrift (05-20-2013) |
![]() | | #76 | ![]() |
![]() Join Date: Mar 2012 Location: Waterford, MI - America's High Five
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,451
| Not Ranked : 0 score lol this was the best post i've read all day!
__________________ Silver 2007 Speed3 GT Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power. Titanium Grey Mazdaspeed6 GTX3071, DD |
![]() | | #77 | ![]() |
| Not Ranked : 0 score Any updates? Been a month since last part |
![]() | | #78 | ![]() |
Groans: 95
![]() | | #79 | ![]() |
| The Following 5 Users Say Thank You to CorkSport For This Useful Post: | Easter Bunny (05-22-2013), kritz (05-21-2013), Little John (05-21-2013), Stryker124 (05-22-2013), ZetaDrift (05-22-2013) |
![]() | | #80 | ![]() |
Groans: 95
| Not Ranked : 0 score I got bettah. Love Monty Python.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f500/fuel-pump-comparison-part-2-a-143900/ | ||||
| Internals/Fuel pump blog from Corksport | This thread | Refback | 04-30-2013 05:08 PM | |
| Fuel Pump Comparison Part 1 | CorkSport | CorkSport | 47 | 04-27-2013 06:24 AM |
| Issues with fuel pump pressures, aftermarket pump... | ptperformance | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 0 | 10-04-2009 06:17 PM |
| Fuel pump part numbers | tburton101 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 0 | 04-03-2009 02:32 PM |
