 Old 06-03-2016, 03:10 PM   #1
CorkSport's Avatar
Posts: 3,416   (View Stats)
Default High-Pressure Fuel Pump Troubleshooting
Anyone who’s anyone in the Mazdaspeed community will always recommend a high-pressure fuel pump internal upgrade before you start to go crazy down the mod list. Why?
 Old 06-03-2016, 03:17 PM   #2
nybe0010's Avatar
Posts: 276   (View Stats)
nybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the world
Groaned at 3 Times in 1 Post
cuz if you don't your gonna have a bad time
11' Black Mica MS3 ATK Reman Long Block iMOTO Shift Forks LuK Clutch Fidanza Flywheel
GC+Koni Coilovers CNT CBE JBR Trilogy Mounts Forge V1 BPV CPE SafeSeals Block8Head Dual Vent Pod Blowshift Boost / OP
nybe0010 is offline   Reply With Quote
The Following 2 Users Say Thank You to nybe0010 For This Useful Post:
AwAfrican (07-18-2016), Gerbilo (06-03-2016)
 Old 07-10-2016, 02:21 PM   #3
Boucher12's Avatar
Posts: 1   (View Stats)
Boucher12 is an unknown quantity at this point
Great read. Thanks for putting this together.
Boucher12 is offline   Reply With Quote
 Old 07-10-2016, 09:43 PM   #4
Insiatent's Avatar
Posts: 97   (View Stats)
Insiatent has a spectacular aura aboutInsiatent has a spectacular aura aboutInsiatent has a spectacular aura about
I already have a cobb intake, everything else stock, would adding a ots tune being too much for stock hpfp?
Insiatent is offline   Reply With Quote
The Following User Says NO Thank You to Insiatent For This Un-useful Post:
g00s3y (07-11-2016)
 Old 07-11-2016, 01:49 AM   #5
MRR
MRR's Avatar
Posts: 95   (View Stats)
MRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to behold
IMO, install an upgrade HPFP, that way, it gives you peace of mind knowing the fuel supply is more than sufficient. Its the very first mod I've done....
MRR is offline   Reply With Quote
 Old 07-13-2016, 05:12 PM   #6
CorkSport Vincent's Avatar
Posts: 163   (View Stats)
CorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the world
No, in a nuthsell there is never a bad time for a tune. We can always use a tune to extract the most performance and reliability out of any modification we have on the car.
I was given the option to edit this. Not sure if it worked or not.
CorkSport Vincent is offline   Reply With Quote
The Following User Says Thank You to CorkSport Vincent For This Useful Post:
robbspeed (07-15-2016)
 Old 07-15-2016, 11:07 PM   #7
sharksinspace's Avatar
Posts: 766   (View Stats)
Groans: 126
A lot of people will tell you that it depends on which gen speed you have. With first gen, you can get away with a couple of more mods before HPFP becomes vital; with second gen, many guys say that HPFP is required for just an upgraded intake.
 Old 07-15-2016, 05:30 PM   #8
Insiatent's Avatar
Alright thanks
 Old 07-16-2016, 02:18 AM   #9
Insiatent's Avatar
I have gen 2, however i have a bluetooth dongle, and torque app with mazdaspeed addon, made bunch of test and never gone under 1600 psi
 Old 07-16-2016, 05:58 AM   #10
Gerbilo's Avatar
Posts: 612   (View Stats)
Gerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the world
I have a CS SRI and TIP on a Pu. Ran that way for a long time, nothing to monitor. Never had any problems, but in retrospect, better to be safe than sorry. Got an AP, loaded the Cobb OTS "Stage 0" tune, logged a few times in different conditions, and didn't see the fuel pressure drop. Loaded the "Stage 1", which is, according to Cobb, safe for stock HPFP, and saw pressure drop on my first log. Not much, but below 1600psi for multiple cells, and that was it for me. Went back to the Stage 0 and installed my internals immediately. Now, I don't even have to worry about it and can add more without any issues.
So, if you want to run safe, without worries, on a Cobb OTS, get the most out of a real tune/OTS+/etc. from a tuner, or add any more power mods, just get the HPFP internals done now so you are in the clear. They are a lot cheaper than a new block.
People may tell you otherwise, but this made sense for me.
2010 CBM Mazdaspeed3
Freektune 93
CorkSport SRI, TIP & Race Pipe
CP-E Stage 2 RMM & TMIC
Cobb Accessport V3
Autotech HPFP Internals
Pilot Super Sport 235/40/18 - Stock Pu
Pilot Alpin PA3 215/50/17 - Sport Edition CE
2016.5 MGM Mazda CX-5 Touring
Gerbilo is offline   Reply With Quote
 Old 07-16-2016, 06:54 AM   #11
Bingo's Avatar
Posts: 740   (View Stats)
Groaned at 9 Times in 7 Posts
The way I see it is that if you're going to mod any more in the future thereby undoubtedly requiring a HPFP, why not just do it now instead of toying with the devil? If it comes down to not being able to spend $300 on your car right now, then modding should not be the path you take.
The Following 2 Users Say Thank You to Bingo For This Useful Post:
CorkSport Vincent (07-18-2016), sharksinspace (07-16-2016)
 Old 07-16-2016, 07:13 AM   #12
Insiatent's Avatar
Yes, i am aware that hpfp upgrade is a no-choice for modding, but i dont think i would go any higher than a ots tune and my cobb sri this year, if i could avoid being forced to get a hpfp untill i want to add a tip or dp, it will be ideal, from what ive heard, some genpu will keep higher pressure than other.
I should also check if my hpfp could already be modded, i got my genpu at 63k km, already had a cobb rmm when i got it.
 Old 07-16-2016, 01:52 PM   #13
Groans: 126
Genpus are a riskier venture when it comes to HPFP, from what I've read; like you said, not all genpus are equal and while some will be fine with light modding on stock internals, others have had issues after just an intake. The dangerous part is that when the pump goes bad, it tends to do so without warning and happens quickly enough that live monitoring won't be able to save you.
If you can spare the money, it really is worth it just for peace of mind; it's not as tough of an install as it may seem and is great insurance...$300 for beefier internals is better than the cost of a new engine, after all.
 Old 07-16-2016, 02:04 PM   #14
Insiatent's Avatar
What are the symptoms of a hpfp going bad? Or at least not pushing enough?
 Old 07-16-2016, 02:14 PM   #15
Groans: 126
My understanding is (someone more knowledgeable please chime in if I'm incorrect or missing info):
1. Internals get overloading and can't keep up with fuel demand, pressure drops
2. AFR leans out due to dropped pressure
3. ECU tries to compensate for lean condition by pushing more fuel
4. Additional fuel overloads internals even more
5. Cycle repeats itself until Zoom Zoom Boom
There's really no forewarning or pre-failure symptoms that you can look for that will tell you it's about to go bad, unless you happen to catch sign of pressure dips through datalogging (in which case drive it easy until internals are upgraded); it's just good until it's very bad.
 Old 07-16-2016, 02:23 PM   #16
Insiatent's Avatar
Okay i understand, but more scientist, its a huge detonation that happen at this moment?
 Old 07-16-2016, 03:00 PM   #17
Groans: 126
Typical outcome is that you end up with a new (and unwanted, obviously ) hole in your block. Not trying to put the fear in you or anything, I just know how much I would hate to ZZB my MS3 and therefore don't like seeing it happen to anyone else.
 Old 07-16-2016, 03:33 PM   #18
Insiatent's Avatar
Yeah me neither.
I could try stage 0 tune first, if its still stay plenty higher than 1600, then i could try stage 1, if stage 0 is not trusty, then i go back stock untill hpfp upgrade.
 Old 07-16-2016, 07:26 PM   #19
Insiatent's Avatar
So today i tried to check the hpfp, when i removed the battery, there was weird green fungus and bolt was all eaten, dunno if previous owner had a battery leak or something but now i cant manage to remove the damn battery case bolt, completly ceased and no box size fit properly, tried with vise grip but was too hard and rounded bolt.
Shit
Fuel pump pressure (high) Illusion Gen2 MS3 General Discussion 9 05-25-2012 11:40 AM
Opinion On High RPM High Pressure Fuel Pump Spring ms3brendan MazdaSpeed 3 - Engine, Transmission & Driveline 1 07-13-2010 01:04 PM
Page generated in 0.37110 seconds with 28 queries
