Like Tree15Likes
 Old 12-12-2017, 12:53 PM   #81
dale_gribble's Avatar
Posts: 4,720   (View Stats)
My HPFP has seemed to be more noisy lately. It was usually only when it was cold, but now I hear it more. I've had ATs in for 5+ years and 150k miles. Interested to see what you find.
MINI H1 6.0 - CAR LED TAILS
 Old 12-15-2017, 07:46 AM   #82
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Originally Posted by GroceryGtr View Post
Might be normal and I'm just anal, but my gut is thinking either issues with the internals or maybe a worn cam follower/cap. I'll update when I pull them apart, probably be a good gauge for others.
...Or maybe you're commanding too much fuel rail pressure in certain areas. I'd stick with the factory target fuel rail pressure at least in the closed loop areas of the fuel pressure tables, if not for the entire tables.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 12-15-2017, 08:23 AM   #83
GroceryGtr's Avatar
Posts: 472   (View Stats)
im running a freaktune so I'm assuming Justin would have done that....
 Old 12-15-2017, 03:06 PM   #84
mituc's Avatar
Groans: 111
You should better ask and be sure...
 Old 12-20-2017, 09:47 AM   #85
Luke@corksport's Avatar
Posts: 120   (View Stats)
Luke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond repute
Is your pressure relief valve still good?
Only reason i ask is because i know the ticking can get louder when that valve starts to fail.
Just some food for thought.....
Luke@corksport is offline   Reply With Quote
The Following User Says Thank You to Luke@corksport For This Useful Post:
mituc (12-20-2017)
Corksport fuel pump Internals? ep87 CorkSport 10 01-24-2013 05:39 PM
Page generated in 0.25941 seconds with 24 queries
