| CorkSport To say that CorkSport is passionate about Mazda Performance is understatement. It is the essence of what we do. Our mission to offer unparalleled customer service and support, an uncompromising commitment to the community, and deliver top quality performance parts is demonstrated with each product we develop to help fulfill your vehicles performance potential. At CorkSport we believe it doesn’t have to come in a fancy package or be the most expensive product on the market to be the best. |
![]() | | #81 | ![]() |
| Not Ranked : 0 score
__________________ 2006 MS6 WWP Sport - 340whp/350wtq JBR 3"- BNRS3V2 - GS EBCS - CUSTOM FMIC - CS IM - LTR7IX - CMGS WMI & D07 GA - TURBOXS HEADER - FIDANZA FW - CP-E CATTED DP - 3" CATBACK BILSTEIN - H&R SPRINGS - 18x8.5 +48 ROTA SVN - 265/35R18 HTR ZIII MINI H1 6.0 - CAR LED TAILS SEE MORE USING !SHOUTTAG.COM - ENTER: !6SPEED6 |
![]() | | #82 | ![]() |
Rep Power: 1237 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,288
Groans: 111
| Not Ranked : 0 score ...Or maybe you're commanding too much fuel rail pressure in certain areas. I'd stick with the factory target fuel rail pressure at least in the closed loop areas of the fuel pressure tables, if not for the entire tables.
![]() | | #83 | ![]() |
![]() Join Date: Nov 2015 Location: Rochester Hills, MI
| Not Ranked : 0 score im running a freaktune so I'm assuming Justin would have done that....
__________________ "Sarcasm and shit talking are two different things. MSF offers the best advice, just delivered by sarcastic pricks, with your best interest in mind." -ThePedigree13 Silver 06 MS6 - DD stealth build - no show, all go.... '12 Abarth Challenge Car - very loud, very fast, very inconvenient to drive on the street... |
![]() | | #84 | ![]() |
Groans: 111
| Not Ranked : 0 score You should better ask and be sure...
![]() | | #85 | ![]() |
| Approved MSF Vendor ![]() Join Date: May 2015
Rep Power: 93 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Is your pressure relief valve still good? Only reason i ask is because i know the ticking can get louder when that valve starts to fail. Just some food for thought..... |
| The Following User Says Thank You to Luke@corksport For This Useful Post: | mituc (12-20-2017) |
| Corksport fuel pump Internals? | ep87 | CorkSport | 10 | 01-24-2013 05:39 PM |
