Like Tree14Likes
 Old 10-09-2014, 11:19 PM   #81
cshunter's Avatar
Posts: 1,312   (View Stats)
If it was not said else where, the HTP 3.5 is able to fit with the K04.
2013 CWP That's slow
Previous: MILTUNED E85 K04
 Old 10-10-2014, 07:50 AM   #82
Cujo's Avatar
Posts: 1,192   (View Stats)
Groaned at 6 Times in 4 Posts
Installed my Corksport battery box yesterday... (see image)
Other than that it feels better to know my intake isn't eating my ECU. The side of my intake was rubbed flat but no real damage to the pipe while the side of my ECU's plastic was rubbed away and metal was showing.
Still a Corksport fan boy but the trick to installing the box with the 3" intake is that you need to undo the brace at the top of the intake and push it down to make it fit. lso you need to remove the white plastic piece that's holding the ECU wiring together to fit it through the hole in the box.
Also it said to use supplied bolts to attach the ECU to the box yet mine didn't come with any. Lucky enough I had 4 random ones that fit laying around in my tool box.
2012 Mazdaspeed3 Black Mica
The Following User Says Thank You to Cujo For This Useful Post:
cshunter (10-26-2014)
 Old 10-26-2014, 05:56 PM   #83
06yellowroush's Avatar
Posts: 108   (View Stats)
06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold
So would the new jbr tru 3.5 inch intake fit with the corksport battery box?
06yellowroush is offline   Reply With Quote
 Old 10-26-2014, 06:03 PM   #84
cshunter's Avatar
+1 on pushing the intake down.
@06yellowroush ; Hard to say, I'd say its plausible. However the difference irc. in the HTP 3.5 and JBR 3.5 is the JBR has an actual inside diameter of 3.5 vs HTP 3.5 outside diameter. So in short the JBR is larger.
 Old 10-27-2014, 04:32 AM   #85
Anthony1982's Avatar
Posts: 139   (View Stats)
Anthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond repute
I'm running the jbr 3.5 with the corksport battery box. It's snug, but not bad at all.
2011 Silver MS3
JBR-EGR block off/delete, Stage 2 OCC, 3.5 SRI, Short Shifter, PMM/TMM, rear sway bar
Corksport-TP, Axle back, battery box, hood scoop
Auto tech internals, NGK plugs, ETS TMIC, Sure TB/IM TIG
CPE stage 2 RMM, Gaurdian Angel, perm tuning butt plug
AP V2 with RICH TUNE on 93.
Forge V1 BPV-SHIIING!
Anthony1982 is offline   Reply With Quote
The Following User Says Thank You to Anthony1982 For This Useful Post:
SpencerC (10-28-2014)
 Old 10-28-2014, 03:01 PM   #86
SpencerC's Avatar
Posts: 2,159   (View Stats)
We should have a 3.5" releasing.... soon..... also.
 Old 10-28-2014, 03:09 PM   #87
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
3.5" is the old 3". Skip it and go straight for 4".
It will be interesting to see Corksports version of the 3.5".
 Old 10-30-2014, 02:32 PM   #88
How soon? Looking to have my gf order a 3.5 inch for my bday lol.
Also Anthony is the 3.5 inch your running the new tru 3.5?
Last edited by 06yellowroush; 10-30-2014 at 02:32 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-30-2014, 03:02 PM   #89
Yea it's the tru 3.5.
2011 Silver MS3
 Old 10-30-2014, 03:04 PM   #90
SpencerC's Avatar
Supposed to be releasing within a week.
 Old 10-30-2014, 03:14 PM   #91
Thanks anthony and ok look forward to seeing it corksport!
 Old 11-03-2014, 12:46 PM   #92
SpencerC's Avatar
Released:
https://corksport.com/mazdaspeed-3-p...ke-system.html
 Old 12-13-2014, 10:02 PM   #93
WAMBUSHHHH!'s Avatar
Posts: 1,599   (View Stats)
Any chance you can provide some pictures? I have a JBR 3.5 as well and my current ecu relocation bracket doesn't fit so I was looking at the CS battery box to fix this..just want to see how snug before going this route..thanks dude!
 Old 12-14-2014, 01:28 AM   #94
Sorry I won't be able to post any pics. I'm currently out of the country for another 6 months.
2011 Silver MS3
 Old 12-14-2014, 05:15 AM   #95
I figured (location = armed forces, I think). Thanks though. Are you rubbing anywhere?
edit: Are you using the Silicone or Aluminum 3.5?
sent from...I'm pooping
 Old 12-14-2014, 06:19 PM   #96
It's the silicone 3.5. I went with the silicone because it would be more forgiving than the aluminum if it rubbed. I had the intake in for about 800 miles before I left. When I did look I had no signs of rubbing. If you do decide to go this route, take your time and it will fit. It is snug and is not moving anywhere. I'm sure some good motor mounts would eliminate some of the rubbing issues.
2011 Silver MS3
WAMBUSHHHH! (12-15-2014)
 Old 12-14-2014, 06:42 PM   #97
I got the aluminum one so no idea how this is going to work. If the silicone works I can't see why the aluminum wouldn't work, just may take a little more to get everything to sit nicely. Thanks dude!
Anthony1982 (12-14-2014)
Report: Next-gen Nissan Altima Hybrid to feature supercharged 2.5L engine, advanced CVT, li-ion battery Haltech Automotive News 0 10-13-2011 11:40 AM
Report: Four-cylinders increase lead over V6s as engine of choice for Americans Haltech Automotive News 0 07-25-2011 05:00 PM
How to Increase Engine Horsepower, How To Raise Oil Level In An Emergency, Brake Caliper Placement, Using The Correct OI Haltech Automotive News 0 10-09-2009 02:30 PM
Removing Engine Valve Cover, Belt-Driven Transmission, Battery Sulphation, Replacing Dashboard Lights, Buying Tires For Haltech Automotive News 0 06-10-2008 02:12 AM
Page generated in 0.36253 seconds with 27 queries
