Like Tree14Likes
 Old 09-11-2013, 11:40 AM   #1
CorkSport's Avatar
Posts: 3,416   (View Stats)
Default Increase Room In Your Engine Bay with a New Battery Box
CorkSport 2010-2013 Mazdaspeed 3 ECU Relocation Battery Box The Mazdaspeed 3 has a Battery Box that takes up more space than a watermelon in your refrigerator. Even worse, the stock ECU location can often interfere with intake upgrades. With these facts in mind, CorkSport decided to design a new Battery Box with a new location [...]
ilias and Robi like this.
The Following 9 Users Say Thank You to CorkSport For This Useful Post:
3starmagnum (09-12-2013), cshunter (09-12-2013), El_Diablo (09-11-2013), Geo13 (09-11-2013), himurax13 (10-30-2013), kritz (09-11-2013), Pu Manchu (09-11-2013), Robi (11-18-2013), Ryguy (09-11-2013)
 Old 09-11-2013, 11:51 AM   #2
Ryguy's Avatar
Posts: 546   (View Stats)
Will this work with the cs strut tower bar?
The Following User Says Thank You to Ryguy For This Useful Post:
Easter Bunny (09-11-2013)
 Old 09-11-2013, 11:59 AM   #3
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
NCE until one for Gen One available
The Following 6 Users Say Thank You to hnda etr For This Useful Post:
breakfstincluded (09-11-2013), DSIT995 (09-11-2013), Dumbguy (09-12-2013), Gibbo (09-11-2013), magicka (09-11-2013), mig02 (09-11-2013)
 Old 09-11-2013, 12:01 PM   #4
Gibbo's Avatar
Posts: 156   (View Stats)
Gibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the world
^^ This. Gen1 going to happen?
Also it will fit with the CS Air box right? Pictures only show it with the stock air box..
Gibbo is offline   Reply With Quote
 Old 09-11-2013, 03:06 PM   #5
CorkSport's Avatar
Gen 1 will happen.... as long as people care about this one....
WWW.CORKSPORT.COM
3ONBOOST (09-13-2013), breakfstincluded (09-11-2013), djrich26 (08-11-2014), Gibbo (09-11-2013)
 Old 09-11-2013, 03:14 PM   #6
Keko's Avatar
Posts: 1,455   (View Stats)
Groans: 107
Groaned at 9 Times in 9 Posts
Do you have the dimensions? Want to take some measurements
2012 MS3
Stratified 91
 Old 09-11-2013, 03:19 PM   #7
SpeedLife's Avatar
Posts: 890   (View Stats)
SpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the world
When I go 4" intake ill be needing this for ECU movement! looks awesome!
2013 Mazdaspeed3
Mods:Stock as shit, trading in for e92
Add me on instagram: @mario_speed3
SpeedLife is offline   Reply With Quote
 Old 09-11-2013, 03:22 PM   #8
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
Genwon! Now!
2009 CWP Speed3
The Following 2 Users Say Thank You to SleeperHatch For This Useful Post:
breakfstincluded (09-11-2013), Gibbo (09-11-2013)
 Old 09-11-2013, 03:35 PM   #9
brandonlee's Avatar
Posts: 144   (View Stats)
brandonlee has a reputation beyond reputebrandonlee has a reputation beyond reputebrandonlee has a reputation beyond reputebrandonlee has a reputation beyond reputebrandonlee has a reputation beyond reputebrandonlee has a reputation beyond reputebrandonlee has a reputation beyond reputebrandonlee has a reputation beyond reputebrandonlee has a reputation beyond reputebrandonlee has a reputation beyond reputebrandonlee has a reputation beyond repute
looks nice. price is kinda steep for a box. but ill wind up getting it either way.
Mpettograsso likes this.
2011 MS3 VRM Tech|CobbAPV3|HTP 3.5|HTP 51r |CS Bpv|UR Tbe CPE Fmic|JBR 88 Rmm|JBR SB|JBR egr delete|JBR gasket and coolant bypass|AT Internals|Sonic Tuning Coilovers|3bms|3 Port Ebcs|Ngk 6510|FREEKTUNED -E85
brandonlee is offline   Reply With Quote
The Following 2 Users Say Thank You to brandonlee For This Useful Post:
El_Diablo (09-12-2013), SLOWHATCH (09-12-2013)
 Old 09-11-2013, 03:39 PM   #10
CorkSport's Avatar
We tried to keep the price as low as we could. I would say in it's defense, there is a lot more to it than some of the simple folded sheet metal ones I've seen on the market. Also, the ability to use a full size battery and move the ECU out of the way is something that nobody else can offer.
Cheers,
Joel
WWW.CORKSPORT.COM
brandonlee (09-11-2013), cshunter (09-12-2013), jdmage_mx5 (09-12-2013)
 Old 09-11-2013, 03:50 PM   #11
DSIT995's Avatar
Posts: 1,768   (View Stats)
No genjuan?? Wtf! Don't know why I waited all this time for this box when it wasn't even for gen1's. I PM'd you guys a couple time about it and it was never mentioned '10-13 specific.. 51r here I come
Cheers,
Joel
Unless you have a genone
99 Miata NB - Stock for now
Last edited by DSIT995; 09-11-2013 at 03:50 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-11-2013, 04:07 PM   #12
brandonlee's Avatar
Cheers,
Joel
i agree thats how it should have came from factory.
 Old 09-11-2013, 04:19 PM   #13
SparkySparks's Avatar
Posts: 1,314   (View Stats)
Is it wider then the stock one? Useing the picture we can see how much longer it is (matches up with the corner of the fuse box) but can't tell how much closer to the engine it is.
On Order:
Coming Soon:
DIY Projects:
 Old 09-11-2013, 04:22 PM   #14
CorkSport's Avatar
It's not wider, and you can't really tell but it's actually longer than stock because we were able to use more room behind where the stock box ends.
WWW.CORKSPORT.COM
 Old 09-11-2013, 04:42 PM   #15
CorkSport's Avatar
Also, it does work with the Cold Air box
Awal likes this.
WWW.CORKSPORT.COM
Awal (10-21-2015)
 Old 09-11-2013, 04:59 PM   #16
Thank you, I wanted to see where the two sides closes to the intake/engine would be compared to stock that way I can see how much room I will have with my 3.5" intake. I would hate to spend $160 on the box and it not fit.
On Order:
Coming Soon:
DIY Projects:
lilred (09-11-2013)
 Old 09-11-2013, 05:27 PM   #17
SpencerC's Avatar
Posts: 2,159   (View Stats)
Default Installed with Airbox
As you can see it works together
If you look in between there is a large cable.
Here I am pointing to it.
Anyway it should work fine, but that one cable I'm pointing at is somewhat in the way. If you re-route that black cable through the ECU, or underneath it then they both will fit seamlessly.
Awal likes this.
The Following 4 Users Say Thank You to SpencerC For This Useful Post:
Awal (10-21-2015), breakfstincluded (09-11-2013), DaUberSchwebel (10-29-2014), jm211 (09-12-2013)
 Old 09-11-2013, 06:01 PM   #18
spdtrux's Avatar
Posts: 481   (View Stats)
Groaned at 9 Times in 6 Posts
+1 Gen1...............
99 JEEP WRANGLER SPORT
The Following User Says Thank You to spdtrux For This Useful Post:
 Old 09-11-2013, 07:13 PM   #19
Geo13's Avatar
Posts: 856   (View Stats)
Geo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the world
Groans: 107
Groaned at 8 Times in 7 Posts
@Joel@CorkSport; @Spencer@CorkSport; @CorkSport so does this mean we'll be seeing the release of the 3" intake also (finally)?!? I was told the two would be released together... Please say yes and take my money!!!!
SPONSORED BY MY WIFE- 2010 Mazdaspeed3 Black Mica (DeadPool): COBB AP Stage 2+(Custom skeurHYPNOTICton Tune), JBR TRILOGY 88D DogBone, 70D TMM & PMM, RSB, OCC, EGR Block Off, Mudflaps, TURBOSMART 50/50 BOV, Tanabe Strut Tower Bar, Moddiction Anvil, TWM Full Replacement Shifter, Fortune Auto 500 Coilovers, SPC Adjustable Camber Arms, Autotech Internals, Denso ITV24, ETS TMIC, UR Catted Down Pipe & Resonated Test Pipe, Corksport 3" Power Series Intake, CBE, GrimmSpeed 3 Port EBCS, Proto Tuning AP Holder, ProSport EVO Boost & AFR Gauge, Ultragauge Classic, Block8Head Dual Vent Pod, DDM Lows: 35w/6K & Fogs: 35w/3k HIDs, Headlight Armor Yellow Fog Overlays, some SURE stuff...still iNATORva
2 Reckless By Speed + 3 Speeding = Mazdaspeed3 (no more parts and a pissed off wife)
Geo13 is offline   Reply With Quote
The Following User Says Thank You to Geo13 For This Useful Post:
skeurton (09-11-2013)
 Old 09-11-2013, 08:17 PM   #20
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Be sure to let people know not to track with it, in the disclaimer.
Or at least not with the lid on.
bhamitgeek likes this.
"Exclusivity" - CP-enis
Demodded.
The Seals
The Following 10 Users Say Thank You to Tokay444 For This Useful Post:
bhamitgeek (09-12-2013), breakfstincluded (09-11-2013), Easter Bunny (09-11-2013), El_Diablo (09-12-2013), IanMacKenzie (09-11-2013), Mauro_Penguin (09-11-2013), Micha (09-11-2013), SLOWHATCH (10-29-2013), YABBAMZR (09-11-2013), ZetaDrift (09-11-2013)
 Old 09-12-2013, 12:26 AM   #21
lup15's Avatar
Posts: 8   (View Stats)
lup15 is an unknown quantity at this point
although unlikely, I am questioning whether having a crucial component such as the ecu not protected from things such as leaking battery acid... perhaps making a removal divider may be a solution
lup15 is offline   Reply With Quote
 Old 09-12-2013, 03:34 AM   #22
shaneski's Avatar
Posts: 505   (View Stats)
Excellent, in that case i am off to order one
Eff they aint available yet.
 Old 09-12-2013, 04:24 AM   #23
Tokay444's Avatar
Groans: 793
There's a critical reason the oem box is vented.
Putting the ecu INSIDE, now that's something.
Did you guys test this till a battery exploded, and they do when they get hot enough in a confined space full of hydrogen, to see how acid resistant the ecu is? Or that up to the end user to determine as well?
Demodded.
The Seals
The Following 6 Users Say Thank You to Tokay444 For This Useful Post:
bhamitgeek (09-12-2013), bstover17 (09-12-2013), Easter Bunny (09-13-2013), IanMacKenzie (09-13-2013), JTMS3 (09-12-2013), sxman (12-18-2013)
 Old 09-12-2013, 05:18 AM   #24
shaneski's Avatar
Lex asked a simialr question a while ago in another folder during the prototype about venting and C/S advised it was just as well vented as the OEM box, have you beta tested this box and had a fail?
 Old 09-12-2013, 07:00 AM   #25
Tokay444's Avatar
Groans: 793
The oem box has a hole in the TOP, because hydrogen is lighter than air.
In that regard, there is no way that box is as well vented as the oem box.
Demodded.
The Seals
 Old 09-12-2013, 07:06 AM   #26
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
The pu's box doesnt have a hole at the top like the juans. In fact now that i think of it, when the lid is on only thing that lets it breath are the openings for the wireing.
TEAM LUXURY
The Following 4 Users Say Thank You to Sid3wayS For This Useful Post:
5doorsoffury (09-12-2013), El_Diablo (09-12-2013), JTMS3 (09-12-2013), SLOWHATCH (09-12-2013)
 Old 09-12-2013, 07:10 AM   #27
Tokay444's Avatar
Groans: 793
Interesting.
Demodded.
The Seals
 Old 09-12-2013, 07:17 AM   #28
pwdunmore's Avatar
Posts: 368   (View Stats)
I would like a "Battery box" with the ECU on the outside, just for good measure.
Not an "ECU + Battery box"...
Keep everything in the same locations (as this modified box) but make the box smaller and mount the ECU on outside of the box.
There is a reason they mount it away from the battery and that's because if there is a battery issue there is no threat of the ECU being damaged if there is a malfunction.
ex. battery fires, accidental short circuits, over heating, battery explosions, battery leaks, etc.
The Following 2 Users Say Thank You to pwdunmore For This Useful Post:
Easter Bunny (09-13-2013), Tokay444 (09-12-2013)
 Old 09-12-2013, 07:22 AM   #29
Gibbo's Avatar
If the lid of the box sits at the same height as the stock box it wouldn't be hard at all to just cut out the same hole the stock box has, that way you still utilise the under hood ducting that's there
Just not sure if it's same height or not..
Now I know that's not buying a "plug and play" item in needing to cut that hole, but i'd be willing to do it and use that ducting that's already there..
 Old 09-12-2013, 07:24 AM   #30
evil MS3's Avatar
Posts: 1,294   (View Stats)
Groans: 55
Gen2s do not have top venting on the battery box, nor does it have ducting like the gen1.
A little tapa tapa taparoo...
The Following 2 Users Say Thank You to evil MS3 For This Useful Post:
El_Diablo (09-12-2013), himurax13 (10-30-2013)
 Old 09-12-2013, 07:26 AM   #31
Gibbo's Avatar
Yeah, @Tokay444; and me are referring to Gen1 though..
 Old 09-12-2013, 07:26 AM   #32
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
Is there any reason that you can't mount the ECU on the outside of this box? Looks to just be some bolt holes the thread into the ecu plate.
The Following 2 Users Say Thank You to daafisch For This Useful Post:
SLOWHATCH (09-12-2013), Tokay444 (09-12-2013)
 Old 09-12-2013, 07:28 AM   #33
evil MS3's Avatar
Groans: 55
Considering this box is for a gen2, it's not really pertinent. Perhaps if one is built for the gen1 they'll utilize the ducting?
surebOOst likes this.
The Following 3 Users Say Thank You to evil MS3 For This Useful Post:
El_Diablo (09-12-2013), surebOOst (10-30-2013), Tokay444 (09-12-2013)
 Old 09-12-2013, 07:30 AM   #34
Gibbo's Avatar
You'd hope so.. seeing as though it's there and ready to go.
I wonder why Mazda removed it from the Gen2 though...
 Old 09-12-2013, 07:31 AM   #35
pwdunmore's Avatar
I thought the purpose was to save space? Mounting outside this box would take up more space
El_Diablo (09-12-2013), evil MS3 (09-12-2013)
 Old 09-12-2013, 07:33 AM   #36
Gibbo's Avatar
The design of the box is ECU infront of battery instead of beside it as is stock configuration. If you were wanting it externally mounted, but also free up the same space the box does, wouldn't the logical thing be have a shorter box with the ECU mounted on the outside of the front of it?
The Following 3 Users Say Thank You to Gibbo For This Useful Post:
Easter Bunny (09-13-2013), pwdunmore (09-12-2013), Tokay444 (09-12-2013)
 Old 09-12-2013, 07:42 AM   #37
evil MS3's Avatar
Groans: 55
I think the rationale with putting the ecu inside the box is to protect it better perhaps?
I'm assuming they deemed it wasn't necessary given the hood scoop perhaps?
Last edited by evil MS3; 09-12-2013 at 07:42 AM. Reason: MSF Database - Automerged Doublepost
 Old 09-12-2013, 07:46 AM   #38
Gibbo's Avatar
Hood scoop just supplies air to the TMIC though and it has the shroud and all, not like there's a ton of random air swirling around in there because of the scoop.
Either way, I don't know (and not too fussed as I own gen1 hehe) but hope for sure they use the ducting for gen1 box.
 Old 09-12-2013, 07:48 AM   #39
evil MS3's Avatar
Groans: 55
True...maybe they realized it just wasn't necessary, period lol
 Old 09-12-2013, 07:58 AM   #40
daafisch's Avatar
Groans: 58
I thought the purpose was to fit a larger intake, which this will allow for. If the ECU doesn't interfere with the filter then why the fuck not put it on the front?
Gibbo (09-12-2013), SLOWHATCH (09-12-2013)
Report: Next-gen Nissan Altima Hybrid to feature supercharged 2.5L engine, advanced CVT, li-ion battery Haltech Automotive News 0 10-13-2011 11:40 AM
Report: Four-cylinders increase lead over V6s as engine of choice for Americans Haltech Automotive News 0 07-25-2011 05:00 PM
How to Increase Engine Horsepower, How To Raise Oil Level In An Emergency, Brake Caliper Placement, Using The Correct OI Haltech Automotive News 0 10-09-2009 02:30 PM
Removing Engine Valve Cover, Belt-Driven Transmission, Battery Sulphation, Replacing Dashboard Lights, Buying Tires For Haltech Automotive News 0 06-10-2008 02:12 AM
Page generated in 0.59758 seconds with 40 queries
