Like Tree100Likes
 Old 06-13-2015, 02:26 PM   #561
aromig's Avatar
Posts: 289   (View Stats)
aromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the world
Originally Posted by speedfreak44 View Post
I used motor assembly lube in mine and it has been working flawless
That's what Lubriplate is. Figured since they specified, it must have certain advantages in this application.
"I apologize for nothing!" - Hedonismbot
aromig is offline   Reply With Quote
 Old 06-13-2015, 02:30 PM   #562
speedfreak44's Avatar
Posts: 1,391   (View Stats)
Good stuff. Guess that makes me feel a little better now. I did ocassionally wonder if I made the right choice using that lol
The line up:
 Old 06-13-2015, 05:59 PM   #563
punkk77's Avatar
Posts: 813   (View Stats)
punkk77 is the leader of the worldpunkk77 is the leader of the worldpunkk77 is the leader of the worldpunkk77 is the leader of the worldpunkk77 is the leader of the worldpunkk77 is the leader of the worldpunkk77 is the leader of the worldpunkk77 is the leader of the worldpunkk77 is the leader of the worldpunkk77 is the leader of the worldpunkk77 is the leader of the world
Fyi, i found Lubriplate at a local Napa Auto. Call one in your area and see if they have it on the shelf, especially if you dont want to wait for shipping.
aromig likes this.
2012 Black Mica Mazdaspeed 3 w/tech
CS SRI w/TIP - CS ABE - SU Test Pipe - JBR 88 RMM
Cobb AP V2 - Autotech Internals - Stratified OTS+ Stage 2 Tune
Maisonvi Stainless Dessert Beagle Knob - Custom Mud Flaps - Lovely, lovely Rice - CS BPV - JBR BPV Hose - Damond OCC
SOON...
CS 3" Intake - CS TMIC - Cobb Springs w/Koni Yellows
punkk77 is offline   Reply With Quote
The Following User Says Thank You to punkk77 For This Useful Post:
JgamB (06-13-2015)
 Old 06-15-2015, 03:28 PM   #564
Brandon@corksport's Avatar
Posts: 170   (View Stats)
Napa usually has the smaller tube (not that you need much for this application). I'd get it from amazon for the big guy for the same price, if you are not in a hurry!
Cheers,
Brandon Johnson
CorkSport Mazda Performance
(360)260-2675 ext. 106
BrandonJ@corksport.com
 Old 06-15-2015, 04:14 PM   #565
punkk77's Avatar
The tube i got from Napa was pretty big, around 8 bucks or so. May have been old stock based on the dust i knocked off lol. Im sure supply will vary by location, but never hurts to call.
aromig and Brandon@corksport like this.
SOON...
CorkSport (06-15-2015)
 Old 09-13-2016, 09:48 PM   #566
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
Apologies for reviving an older thread..
This question is for those that have done a boost leak test with the CS BPV on the car...
Were you getting any air/pressure from the recirculating side? No, a lil, a lot???
 Old 09-13-2016, 11:12 PM   #567
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
I didn't do a boost leak test but I did try putting this BPV to my mouth and blowing through the recirculate port. I can't push much air with my lungs but I can hear air leaking past the piston...
I wouldn't get this on the stock valve or turbosmart kompact.
2018 Audi RS3
2007 Acura TSX 6MT
Blow off valve vs recirculation valve Vlad 2010 MS3 - Engine, Transmission & Driveline 19 06-22-2012 08:59 AM
Blow off valve speed6mazda Mazdaspeed3/6 General Discussion 67 11-30-2011 07:55 AM
Blow Off Valve Brianspeed3 Gen2 MS3 General Discussion 52 08-19-2011 06:18 PM
blow off valve speed3po MazdaSpeed 3/6 - Turbo Induction 16 01-16-2010 10:39 AM
Why does your motor blow thread, look inside. ptperformance Mazdaspeed3/6 General Discussion 207 08-16-2009 12:01 PM
Page generated in 0.29713 seconds with 26 queries
