| CorkSport To say that CorkSport is passionate about Mazda Performance is understatement. It is the essence of what we do. Our mission to offer unparalleled customer service and support, an uncompromising commitment to the community, and deliver top quality performance parts is demonstrated with each product we develop to help fulfill your vehicles performance potential. At CorkSport we believe it doesn’t have to come in a fancy package or be the most expensive product on the market to be the best. |
| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
(Thread Starter) | Not Ranked : 0 score More... |
| The Following 2 Users Say Thank You to CorkSport For This Useful Post: | breakfstincluded (09-07-2015), snailD (09-28-2015) |
![]() Join Date: May 2011 Location: Portland OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,451
| Not Ranked : 0 score I am also Vincent. THIS IS NOW A VINCENT THREAD.
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. |
| The Following 3 Users Say Thank You to breakfstincluded For This Useful Post: |
![]() Join Date: Oct 2013 Location: Detroit, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 509
| Not Ranked : 0 score Y'all better have the soul for getting down. Can you DIG IT?? https://www.youtube.com/watch?v=V-OYKd8SVrI
| The Following 2 Users Say Thank You to aackthpt For This Useful Post: | breakfstincluded (09-09-2015), CorkSport (09-15-2015) |
(Thread Starter) | Not Ranked : 0 score Official voice over for CorkSport, Vincent... |
| Approved MSF Vendor ![]() Join Date: May 2015
Rep Power: 93 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Vincent needs another race car! |
![]() Join Date: Dec 2009 Location: layton, UT
| Not Ranked : 0 score lets see this thing go !!!
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna |
| Approved MSF Vendor ![]() Join Date: Jan 2015
Rep Power: 160 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 48
| Not Ranked : 0 score We can take over the Mazda scene and rule.
__________________ I was given the option to edit this. Not sure if it worked or not. |
| Approved MSF Vendor ![]() Join Date: Apr 2014
Rep Power: 137 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score I've been telling him this for a year. He won't prioritize it! Maybe MSF can help, steer him in the right direction.
__________________ |
| Not Ranked : 0 score Basically what needs to happen is Vincent needs a Speed, Brandon needs a Miata, and Barett needs his meth and tune. Only then will we take over the Mazda community! |
| Log looks perfect, but car is getting slower | JgamB | 2010 MS3 - ECU Computer Tuning | 2 | 10-15-2013 08:29 PM |
| MAF CAL perfect after 1 attempt? | stance is slow | 2010 MS3 - ECU Computer Tuning | 3 | 06-02-2013 05:44 PM |
