  • 2 Post By
 Old 03-03-2014, 10:44 AM   #1
twenty5psi's Avatar
Posts: 213   (View Stats)
twenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the world
Basically the same issue I have, it's starting to warm up here so I don't hear it much anymore. If you pull the driver wheel you can clearly see the bar and trans case about a millimeter from contacting each other.
2013 MS3 VRM w/Tech
-unSure Track RMM//Cobb AP//AT HPFP Internals//HTP 3" Intake//UR Resonated TP//UR CBE//JBR Weighted Shift Knob//JBR Shifter Cage Bushings
FlowTuned 2 Gallon E85 blend 307whp/336wtq
twenty5psi is offline   Reply With Quote
front bumper insert tooslow10 Exterior 60 11-04-2013 11:01 AM
Front lower grille AKmac11 MazdaSpeed 3/6 - Appearance 2 02-27-2013 11:45 AM
Front Lower Tie Bar Todd98SE CorkSport 3 10-23-2012 05:24 PM
lower front springs only? bmannn 2010 MS3 - Suspension & Brakes 1 04-22-2011 01:19 AM
Page generated in 0.23670 seconds with 22 queries
