Like Tree4Likes
  • 2 Post By Code Monkey
  • 1 Post By getemslough
  • 1 Post By Jetfire
 Old 02-10-2016, 03:10 PM   #1
CorkSport's Avatar
Posts: 3,416   (View Stats)
Default New Product Alert: CorkSport Leather E-Brake Handle
Introducing the new CorkSport leather parking brake handle for 2nd generation Mazdaspeed 3 and Mazda 3! This isn’t just another plastic handle with some pattern on it, or maybe some carbon fiber sticker. This is what Mazda should have done from the beginning. The CorkSport handle was CAD designed to fit just like OEM and […]
tec_41 (02-10-2016)
 Old 02-10-2016, 03:32 PM   #2
ToyCop's Avatar
Posts: 237   (View Stats)
ToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond repute
Saw it on the website the other day. Looks slick.
2011 Mazdaspeed 3 VRM W/Tech
CorkSport: 3" Power Series SRI, BPV & hose, Boost tubes, Battery box, HPFP internals, Short shifter and bushings.
ETS TMIC, Ultimate Racing test pipe, Damond dual OCCs, Damond TMM, CP-E S2 RMM, COBB APv3, Freektune OTS+ 93 Oct.
Rice: RallyArmor, Morimoto XB LED Fogs, VLeds Triton Reverse Lights, Redline boots and armrest cover, Maisonvi shift knob.
Audio: Pioneer AVIC-7100NEX
ToyCop is offline   Reply With Quote
 Old 02-10-2016, 03:33 PM   #3
Would be awesome if this included the boot as well.
sent from my Nexus 6P
DaUberSchwebel (02-10-2016)
 Old 02-10-2016, 03:36 PM   #4
You misspelled "intake manifold".
markos213 and Easter Bunny like this.
The Following 5 Users Say Thank You to Code Monkey For This Useful Post:
DaUberSchwebel (02-10-2016), Easter Bunny (02-10-2016), MS3Shadow (02-10-2016), SarcasticOne (02-10-2016), [R]usty (02-10-2016)
 Old 02-10-2016, 04:13 PM   #5
Agreed needs a matching boot.
Now stop fucking around and get to work on that intake manifold.
Code Monkey (02-10-2016), MS3Shadow (02-10-2016)
 Old 02-11-2016, 03:38 PM   #6
getemslough's Avatar
Posts: 163   (View Stats)
getemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the world
Sooo... it says it matches the bad ass steering wheel I bought from you guys but it fits the gen 2... so the steering wheel and brake lever won't even be in the same car??? That sucks...
Looks like you have to make a gen 1 version... like meow. And while your at it we will take some of those floor mats too. @CorkSport;
And the intake manifold...
And cams...
And moar Kim.
That is all.
zjnspeed3 likes this.
---2009 CWP---ATP GTX2867r---COBB AP V3---CS HPFP---CS BERYLLIUM/COPPER INJECTOR SEALS---SELF PORTED INTAKE MANIFOLD---CS 3.5 SRI---
---PROTOTYPE XSPOWER V3 IWG MANIFOLD (BETA TESTER)---CS CATTED DP---CNT CATBACK---RPM/CX FMIC PIPING---TREADSTONE TR8---
---GRIMMSPEED 3 PORT EBCS---3BAR MAP/RPM HARNESS---NGK 6510---JBR 51R TRAY---3P/HKS SSQV IV---CS RECIRC TUBE---KOZMIC OIL DRAIN---KOZMIC EGR DELETES---
---JBR TB/IM TIGS---CS PMM---CS RMM---CS OCC---CS SKID PLATE---
---CS STEERING WHEEL---CS SHIFTER BUSHINGS---SURE SHORTCUT---JBR SHORT SHIFT LEVER---SURE AGS 621g---SURE AGS EXTENDER---
---KONI STR.T---H&R SPRINGS---PROGRESS RSB---MOOG ENDLINKS---17X9+45 RPF1---5MMSPACERS---255/40/17 NITTO NT555---JBR FLAPS---
--GTX BUILD COMPLETE--
--FREEKTUNE 383/404 ON PUMP--
--METH COMING SOON--
getemslough is offline   Reply With Quote
The Following User Says Thank You to getemslough For This Useful Post:
Easter Bunny (02-11-2016)
 Old 02-11-2016, 03:51 PM   #7
Brandon@corksport's Avatar
Posts: 170   (View Stats)
And cams...
And moar Kim.
That is all.
Moar cowbell?
Cheers,
Brandon Johnson
CorkSport Mazda Performance
(360)260-2675 ext. 106
BrandonJ@corksport.com
 Old 08-15-2016, 08:40 AM   #8
Jetfire's Avatar
Posts: 39   (View Stats)
Jetfire is a splendid one to beholdJetfire is a splendid one to beholdJetfire is a splendid one to beholdJetfire is a splendid one to beholdJetfire is a splendid one to beholdJetfire is a splendid one to beholdJetfire is a splendid one to behold
I also want a GEN 1 parking brake handle to match my CS wheel.
markos213 likes this.
2008.5 Mazdaspeed3
|JBR 3 inch intake|Corksport turbo |Corksport EBC|CS injector seals|Cobb TBE|
|CPE TMIC|Turbosmart BPV|Koni Yellows|FatCat BumpStops|Eiback Prokit springs|JBR OCC|SPC rear camber arms|DBA4000 rotors| Hawk HPS pads|JBR mounts x3|3 BAR MAP|
|CS adjustable shifter|CS steering wheel|CS Sways, links and mid chassis brace
Cobb AP v3
Autotech HPFP internals
Jetfire is offline   Reply With Quote
Product Release!!! CorkSport 4 Piston Big Brake Caliper Kit CorkSport CorkSport 98 06-26-2017 08:14 PM
Product Release! CorkSport Mazdaspeed 3 and Mazdaspeed 6 Brake Pads CorkSport CorkSport 54 03-07-2014 07:50 PM
Slack in e-brake handle NewCar Mazdaspeed3/6 General Discussion 7 04-05-2013 08:38 AM
Product Release! CorkSport LED 3rd Brake Light for 2010+ Mazda3 Sedan CorkSport CorkSport 0 04-03-2012 11:20 AM
Aluminum e-brake handle installed M3_MPS Interior 18 07-07-2010 11:33 PM
Page generated in 0.29436 seconds with 27 queries
