Like Tree15Likes
 Old 02-17-2014, 08:22 AM   #41
sleeperstang1994's Avatar
Posts: 569   (View Stats)
Groaned at 7 Times in 5 Posts
Originally Posted by Johnasaurus View Post
the only thing really holding me back from getting this is that it only comes polished. I can build my own air box out of aluminum if I needed to so thats not a worry. other than that it looks absolutely badass!
have it shipped to me and ill powder coat it wrinkle black. problem solved
The Following 2 Users Say Thank You to sleeperstang1994 For This Useful Post:
Johnasaurus (02-17-2014), SpencerC (02-21-2014)
 Old 02-17-2014, 03:55 PM   #42
CorkSport's Avatar
Posts: 3,416   (View Stats)
There is no way this will be CARB approved.
-Derrick
WWW.CORKSPORT.COM
Monotonous ONE (02-19-2014), NCspecV81 (02-22-2014)
 Old 02-17-2014, 04:05 PM   #43
Cujo's Avatar
Posts: 1,192   (View Stats)
Groaned at 6 Times in 4 Posts
Just ordered one. I can't wait to install it.
2012 Mazdaspeed3 Black Mica
The Following User Says Thank You to Cujo For This Useful Post:
SpencerC (02-20-2014)
 Old 02-17-2014, 04:25 PM   #44
The Nut's Avatar
Posts: 1,571   (View Stats)
-Derrick
Is it slow up there or something? You took the time to answer this?
P.S. I'll be ordering soon.
2012 BLACK MICA w/TECH
91 & Corn diagnostics by:
 Old 02-18-2014, 08:30 AM   #45
CorkSport's Avatar
The move has slowed down my forum trolling as of late, this week it is getting back up to normal speed.
-Derrick
WWW.CORKSPORT.COM
 Old 02-18-2014, 05:15 PM   #46
moonrider_99's Avatar
Posts: 185   (View Stats)
moonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond repute
Groaned at 46 Times in 14 Posts
Probably not possible to have it CARB certified, because it won't run properly on the stock tune. Part of CARB certification requires that the new part works with the stock tune, IIRC.
good point, thank you.
2017 Ford Focus RS - Stock
2004 MSM
- AEM Intake - BEGI - FM Turboback - Turbosmart BPV - Hallman Boost Controller - ...
"I'm a Turbo addict, I know."
SCCA Philadelphia: (http://www.phillyscca.com/solo/)
2012 MS3 Silver w/ Tech Package - sold in '17
2009 WRX Stage 2- sold in '12
moonrider_99 is offline   Reply With Quote
 Old 02-18-2014, 06:09 PM   #47
The Nut's Avatar
SMH
 Old 02-18-2014, 10:29 PM   #48
Patty-Wack's Avatar
Posts: 885   (View Stats)
Patty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the world
Just finished installing this bad boy. Great Stuff. Thanks again to @Spencer@CorkSport; for the personal delivery. I won't know how much extra power I am creating until I fix my BCS (the one i broke on install) but even with that creating a leak it pulls like a raped ape now and sounds like sex.
Keep up the good work @CorkSport;! Satisfied Customer Here. I'll be contacting you for some springs soon..
CorkSport likes this.
Black 2010 MS3 - Non-Tech 281whp/310tq on 92 (v-dyno w/ 1.01 correction)
Corksport 3" Intake l AP v2 l Stage-2 CP-E RMM l Autotech Internals l DDM 35w 5k Hids (Low Beam) l JBR Stage 2 Short Shift Plate Kit w/ Bushings l JBR big Fing Knob l Corksport TMIC l Forge BPV v2 l Stratified E-Tune l Stratified 3-port (Running 2-port) l NGK 1 step Colder plugs l Corksport Test Pipe l DDM 35w 3k Hids (Fogs)
Waiting to install... Prosport Boost Gauge w/ vent pod
Patty-Wack is offline   Reply With Quote
The Following User Says Thank You to Patty-Wack For This Useful Post:
 Old 02-19-2014, 02:26 AM   #49
Putin 2.3T's Avatar
Posts: 1,040   (View Stats)
I wouldn't be running your car with a broken BCS. That's kind of important..
Do you even MAF cal bro?
2011 Mazdaspeed 3 [Sold]
The Following User Says Thank You to Putin 2.3T For This Useful Post:
Micha (02-23-2014)
 Old 02-19-2014, 05:13 AM   #50
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
Any plans to make these with white silicone pieces?
 Old 02-19-2014, 05:20 AM   #51
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
Racist
 Old 02-19-2014, 06:32 AM   #52
Racist
just a little. white silicone is the master silicone.
The Following User Says Thank You to 2.0t03speed For This Useful Post:
CorkSport (02-19-2014)
 Old 02-19-2014, 07:48 AM   #53
Patty-Wack's Avatar
Stock MAF cal on 3" with no bcs. That's not safe? lol
My BCS isn't broken, I just broke the nipple to the inlet intake. The wastegate is still hooked up and the BCS is still holding boost where it needs to be. It's only for a couple of days until 3 port (will run 2-port) comes in. I'm also not running too hard and watching it like a hawk on the AP.
And I am running the MAF cal that Corksport/Lex supplied. Although after the new bcs I'll do another one. Good looking out, although clearly you don't check the Nator section much. ;/
 Old 02-19-2014, 09:12 AM   #54
CorkSport's Avatar
Not at the moment. You are the second person who has asked. Anyone else down with the white?
-Derrick
2.0t03speed likes this.
WWW.CORKSPORT.COM
2.0t03speed (02-19-2014)
 Old 02-19-2014, 10:39 AM   #55
Elvisrosales88's Avatar
Posts: 113   (View Stats)
Elvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the world
Groaned at 9 Times in 2 Posts
Originally Posted by Patty-Wack View Post
And I am running the MAF cal that Corksport/Lex supplied.. ;/
Supplied? Where? How?
Cobb AP+ Stratified OTS--JBR Powerpath Stage III intake-- Turbosmart BPV--AutoTech Fuel Pump Internals--CPE TMIC-- OBX test pipe+ UR catback--ITV-22 plugs-- H&R springs--CPE RMM- JBR PMM and TMM--
Elvisrosales88 is offline   Reply With Quote
 Old 02-19-2014, 10:50 AM   #56
The Nut's Avatar
There are 2 .pdf's in the instructions. One for how to do a MAF Cal, one with the suggested starting #'s for the MAF scaler.
 Old 02-20-2014, 09:13 AM   #57
Patty-Wack's Avatar
@CorkSport; I'm having issues with the intake filter rubbing with the hood. Did you guys have that problem with the shop car? I'm guessing i need to push the silicone connections down, if i can. Any insight would be great though if you guys ran into the problem already...
Edit: I have stage 2 RMM so shouldn't be moving that much..
 Old 02-20-2014, 09:25 AM   #58
zeroecco's Avatar
Posts: 223   (View Stats)
zeroecco is the leader of the worldzeroecco is the leader of the worldzeroecco is the leader of the worldzeroecco is the leader of the worldzeroecco is the leader of the worldzeroecco is the leader of the worldzeroecco is the leader of the worldzeroecco is the leader of the worldzeroecco is the leader of the worldzeroecco is the leader of the worldzeroecco is the leader of the world
The silicone bend that connects to the maf housing should be curved like the stage 2 =. You should be able to simply turn that 25 degrees toward the driver side nd stop the hood rub. I had the same issue on the stage 2 and it was that change that fixed it.
Current:
2008 Mercedes CLS 550 (AMG Sport package, Luxury P2 package, iPod package, Nav, etc)
382HP/391TQ
Previous:
2010 Mazdaspeed 3
268HP/320TQ
zeroecco is offline   Reply With Quote
The Following User Says Thank You to zeroecco For This Useful Post:
 Old 02-20-2014, 09:29 AM   #59
Bludypoo's Avatar
Posts: 287   (View Stats)
Bludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the world
That silver bracket can be removed. It is only there for the stock air box i believe. When installing my Stage 2 it came very close to that bracket and i had left it for a while before a buddy was like "dude, undo that bolt and remove that shit."
Plenty of room now.
*Edit*
Actually, i believe you are talking about intake sitting up too high and touching the hood. You should be able to spin the silicon to angle it to the right more.
Bludypoo is offline   Reply With Quote
 Old 02-20-2014, 09:39 AM   #60
Patty-Wack's Avatar
Thanks guys. Figured it was something simple, I'll fix it tonight.
 Old 02-20-2014, 09:52 PM   #61
Patty-Wack's Avatar
Hmm. So I took a look at it tonight and as far as I can tell that silcone that connects to the MAF is straight, no curve. So the only thing you can do it move it back and forth on the pipe. I pulled it out the best I could to try and make it "hang" a little lower. We will see if that works. It's rubbing on my hood insulation. It's only during heavy engine movement I'm guessing.
The only other thought is trying to rotate it at the turbo itself but I don't think that works because it is screwed into the stock bracket so in theory it should be where it needs to be.
 Old 02-20-2014, 10:08 PM   #62
The Nut's Avatar
Hmmm... Maybe I should wait for a revision?
 Old 02-20-2014, 10:15 PM   #63
Patty-Wack's Avatar
hmm I wouldn't go that far. I'm sure it's something simple, or so I hope. I'm giving Corksport a call tomorrow and hope they can shed some light on the matter. I'll update on how it goes and what ends up hopefully fixing it.
 Old 02-20-2014, 10:36 PM   #64
The Nut's Avatar
Yeah, I was joking. They're awesome about making shit right. But @Spencer@CorkSport needs to learn how to seal an envelope. Speaking of which, Spencer, did you get my message a few weeks ago? If not, give me a call please.
 Old 02-21-2014, 05:41 AM   #65
valveking35's Avatar
Posts: 64   (View Stats)
valveking35 has a reputation beyond reputevalveking35 has a reputation beyond reputevalveking35 has a reputation beyond reputevalveking35 has a reputation beyond reputevalveking35 has a reputation beyond reputevalveking35 has a reputation beyond reputevalveking35 has a reputation beyond reputevalveking35 has a reputation beyond reputevalveking35 has a reputation beyond reputevalveking35 has a reputation beyond reputevalveking35 has a reputation beyond repute
Groaned at 8 Times in 3 Posts
In for white.
Sent from my DROID RAZR using Tapatalk
valveking35 is offline   Reply With Quote
 Old 02-21-2014, 09:20 AM   #66
SpencerC's Avatar
Posts: 2,159   (View Stats)
@Patty-Wack; I just sent you a PM. I'm interested if you have any photos. Shoot them to my email (Spencer@CorkSport.com ) or post them here.
Also @The Nut; wuuut??? envelope? Oh the one with the little sticky rubber bumper for your underhood LED light? What happened?
 Old 02-21-2014, 10:38 AM   #67
Even with a straight silicone piece you can adjust how the two pipes curve by clamping them down at a slight angle. I am not sure how much is needed here.
 Old 02-21-2014, 10:47 AM   #68
Patty-Wack's Avatar
You are correct. I guess my concern would be long term wear on the inside of that silcone if you let it hang at an angle. That being said, if it's a common practice and no one has seen any long term issues than I'll do it.
 Old 02-21-2014, 11:16 AM   #69
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
Groans: 51
Offer me a deal i cant refuse and I will snatch one of these 3"ers up Spencer!
I has CS points!
Matt
 Old 02-21-2014, 11:23 AM   #70
The Nut's Avatar
Also @The Nut; wuuut??? envelope? Oh the one with the little sticky rubber bumper for your underhood LED light? What happened?[/QUOTE]
I called and left you a message about this, but the envelope wasn't sealed properly and whatever you guys sent me didn't make it to my house. The kind note was still in there though.
 Old 02-21-2014, 02:49 PM   #71
SpencerC's Avatar
I has CS points!
Matt
Umm. Drat. I offered @Patty-Wack; free delivery, but he's only 3 hours from me. It might be a long roadtrip to you! How about this... Spencers tax season special ... call me (360-260-2675 ext 105) to order and I'll throw in a free pint glass, lanyard and one of these epic bottle opener rings I found (until I run out! then I'll do something else random)
If anyone else wants in on this just give me a call.... I'll do this until the end of the month.
I called and left you a message about this, but the envelope wasn't sealed properly and whatever you guys sent me didn't make it to my house. The kind note was still in there though.[/QUOTE]
Shooot. Well I'll have to see if we have another one of those things... and send it again.
The Nut (02-21-2014)
 Old 02-21-2014, 05:50 PM   #72
Jeremy M's Avatar
Posts: 345   (View Stats)
Jeremy M has a reputation beyond reputeJeremy M has a reputation beyond reputeJeremy M has a reputation beyond reputeJeremy M has a reputation beyond reputeJeremy M has a reputation beyond reputeJeremy M has a reputation beyond reputeJeremy M has a reputation beyond reputeJeremy M has a reputation beyond reputeJeremy M has a reputation beyond reputeJeremy M has a reputation beyond reputeJeremy M has a reputation beyond repute
Groaned at 11 Times in 3 Posts
fmba (fuck my bank acct)
this is gonna be hard to pass up
2010 Celestial Mica Blue
APv2, CS RMM, JBR ALUM 3" INTAKE, CS CBE, CS DPcatted,CS HPFP, H&R Springs (BNR S4 to be installed)
Stratified OTS+ E85 tune
Jeremy M is offline   Reply With Quote
 Old 02-22-2014, 12:46 PM   #73
NCspecV81's Avatar
Posts: 2,867   (View Stats)
-Derrick
The only other, better way to say fuck California is to dangle a 30 round magazine in front of them.
Chron (02-22-2014)
 Old 02-23-2014, 12:12 PM   #74
IMASA's Avatar
Posts: 209   (View Stats)
Any plans to sell just the MAF housing?
 Old 03-09-2014, 09:53 AM   #75
bunta's Avatar
Posts: 42   (View Stats)
bunta has a spectacular aura aboutbunta has a spectacular aura about
For the two vacuum hoses that go to the valve cover and the boost solenoid can we just slide them on and leave them that way or do we need to go buy clamps for them? The instructions doesn't say.
Please help....im in the process as we speak.
bunta is offline   Reply With Quote
 Old 03-09-2014, 12:15 PM   #76
The Nut's Avatar
Held on with friction dude. That's why the existing ones don't have clamps, not enough pressure to need it. Also, donate.
Easter Bunny (03-10-2014)
 Old 03-10-2014, 11:21 AM   #77
SpencerC's Avatar
This isn't something we plan on doing.
 Old 03-10-2014, 11:34 AM   #78
someguy's Avatar
Posts: 914   (View Stats)
-Derrick
How about a black pipe too? Rather than the polished chrome.
 Old 03-10-2014, 11:56 AM   #79
The Nut's Avatar
^^^^want this! Promises made that this can be done gets phone order from me today @Spencer@CorkSport!
The Following 2 Users Say Thank You to The Nut For This Useful Post:
modusoperandi (03-15-2014), someguy (03-10-2014)
 Old 03-15-2014, 06:49 PM   #80
modusoperandi's Avatar
Posts: 309   (View Stats)
modusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond repute
I'm running this intake & haven't run into any issues with rubbing against the hood, fitment was pretty tight in there. Wouldn't have made it far if it wasn't for himurax13 lol. Still the gains were definitely there after the install. I do have to agree with The Nut about the black inlet pipe instead of polished chrome. Switcharoo?
modusoperandi is offline   Reply With Quote
Product Release! 2014+ Mazda 6 and CX5 2.5L SkyActiv Power Series Short Ram Intakes CorkSport CorkSport 1 05-03-2013 05:52 PM
Product Release! CorkSport Cold Air Intake for the 2010+ Mazdaspeed 3 CorkSport CorkSport 26 09-08-2012 09:14 PM
Product Release! CorkSport SkyActiv Mazda 3 Power Series Single Exit Exhaust CorkSport CorkSport 0 04-10-2012 01:20 PM
Product Release! Corksport Stage One Power Series Short Ram Intake for Mazdaspeed 3 CorkSport CorkSport 1 02-28-2012 07:16 PM
Page generated in 0.60531 seconds with 42 queries
