  • 1 Post By SpencerC
  • 1 Post By Code Monkey
 Old 02-18-2015, 05:47 PM   #1
SpencerC's Avatar
Posts: 2,159   (View Stats)
Default NEW RELEASE: CorkSport Mazdaspeed 6 Upper Control Arm
https://corksport.com/mazdaspeed-6-u...ntrol-arm.html
Hey! More Mazdaspeed 6 products! They are what they are.
-Camber adjustability from -0.2 degrees to -2.0 degrees for added personalization.
-Design: For added and improved control, spherical bearings replace the soft rubber bushings used in OEM and other aftermarket camber arms for more precise suspension settings.
Cost: $299.99
Lakespeed6 likes this.
The Following 8 Users Say Thank You to SpencerC For This Useful Post:
AlsMS6 (02-18-2015), Cheese5.0 (02-23-2015), dale_gribble (02-18-2015), Mazdazilla6 (02-19-2015), mxlplx71 (02-19-2015), Poohster (02-21-2015), speed6qc (03-24-2015), [R]usty (02-18-2015)
 Old 02-18-2015, 06:03 PM   #2
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Are ball joints replaceable? One thing I def don't like about SPC BJS, they are running at the very edge of their adjustment on lowering springs so the BJ is at a hard angle. I like the adjustment plate concept. Might as well add BJ info to product page, because I won't be last one asking.
MINI H1 6.0 - CAR LED TAILS
dan7225 (02-19-2015), TiGraySpeed6 (02-19-2015)
 Old 02-19-2015, 07:25 AM   #3
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Considering the target audience for these I'm surprised the camber is only adjustable to -2.0. Autocross and road course will often see camber up to -2.5ish. Some castor adjustment would have been nice too....
What's the cost to replace the ball joint section? I'm guessing that since it's adjustable it's also removable and folks will want to replace just the BJ and not the whole arm.
340hp / 371tq
 Old 02-19-2015, 07:47 AM   #4
DamagedGoods's Avatar
Posts: 304   (View Stats)
DamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the world
If the camber measurement they've listed is with a stock ride height car, then the range will change if the car is lowered, the SPCs were only 1.5° negative/positive at stock ride height (according to their documentation). I would assume that most of us who autocross or participate in road course events would already be lowered a smidgen.
As for the ball joint replacement, I was curious about that yesterday as well and also wanted to know if they were a quality joint, and not some doorman stuff that'll wear out in 5000 miles.
Sent from my SM-N900W8 using Tapatalk
2007 Mazdaspeed 6 - Bolted, Methed, Tuned
DamagedGoods is offline   Reply With Quote
The Following 2 Users Say Thank You to DamagedGoods For This Useful Post:
Code Monkey (02-19-2015), Easter Bunny (02-19-2015)
 Old 02-19-2015, 08:03 AM   #5
SPC's allow up to -2.5 camber on stock suspension, linky.
TiGraySpeed6 likes this.
DamagedGoods (02-19-2015), TiGraySpeed6 (02-19-2015)
 Old 02-19-2015, 08:04 AM   #6
Alpha's Avatar
Posts: 3,711   (View Stats)
Any weight savings over stock with these?
 Old 02-19-2015, 09:16 AM   #7
Well then, I was mistaken, always take whatever is on the Internet with a grain of salt, lol.
 Old 02-19-2015, 09:40 AM   #8
Honestly, I'm just happy that somebody is making something for the Speed6!!
Right now I think it's important to note that we're just asking questions for clarity and there's no bashing going on! Inquiring minds want to know & all that....
For camber it would appear the real question is what can be achieved when on the car. SPC's specs do indicate +/- 1.5*, but when you install em oriented properly and on a good working ride height, as opposed to any stanced bullshit, we've seen -2.5* and even beyond.
That said, the request is for clarity on the specs here- what's that -2.0 mean- is it like SPC's 1.5, or is it a hard wall best you can hope for number? For me it makes a difference between a fresh set of SPC's or a new set of UCA's!
340hp / 371tq
The Following 6 Users Say Thank You to TiGraySpeed6 For This Useful Post:
Alpha (02-19-2015), Code Monkey (02-19-2015), Mazdazilla6 (02-19-2015), phate (02-19-2015), RalliartRsX (02-19-2015), rob ms6gt (02-20-2015)
 Old 02-19-2015, 02:32 PM   #9
Silverdecepticon's Avatar
Posts: 277   (View Stats)
Silverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond repute
Wicked, another item that goes on my list. Fuck I wish an old cougar would buy me parts.
06 MS6
GTX3076R, Xs power exhaust manifold(suxs), ebay dp(sux), 3" catless exhaust, 4" HTP TIP, Sure shortshift & counterbalance, COBB V3, Autotech HPFP internals, Grimmspeed EBCS, CP-e RMM, Perm PCV plate, JBR EGR delete, JBR BSD, JBR Oil pan baffle plate, Kozmic OCC, rebuilt fuel injectors, safeseal injector seals, Bosch 3 bar MAP, new gaskets(valve cover, throttle body, intake manifold, exhaust manifold, dp), cleaned valves and chambers, CP-E motor mount & rear-diff mount, ATP-INT-003 FMIC, Stratified Guardian Angel set to 24psi, Stoptech rotors, Hawk HPS pads, Forge BPV, home-made strut mounted tower bar, badgeless, special edition 19" anniversary rims. Battery finally relocated to trunk with custom box. New VVT stuff, BC coilovers, new OEM Clutch, fidenza lightweight flywheel, replaced driveshaft again, replaced power steering pump again, busted rear diff side bolts again....FML
Silverdecepticon is offline   Reply With Quote
 Old 02-19-2015, 04:58 PM   #10
SpencerC's Avatar
I'm checking with our engineers on your questions. I honestly am not sure on answers myself. We will see what they say.
TiGraySpeed6 (02-20-2015)
 Old 02-20-2015, 02:11 PM   #11
Boostin'likeAboss's Avatar
Posts: 1,792   (View Stats)
08 cwp ms3
 Old 02-20-2015, 02:19 PM   #12
SpencerC's Avatar
Answer to the first question:
"If the ball joint fails in the first 2 years it will be replaced. If it fails after the 2 years then CS will offer new ball joints at an affordable price. "
Still trying to get info on the adjustment of -2 camber.
 Old 02-20-2015, 02:38 PM   #13
I know on lowered suspension, I can barely get -1.5 out of SPCs. They are at limit.
Definitely another good question Corksport, at what ride height can the arms hit -2.0 degrees of camber? Stock? Lowered on your springs?
 Old 02-20-2015, 03:02 PM   #14
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
I am pretty sure the orientation of the ball joint can change the range. You might need to turn it 180° to get you in that upper range. With lowered suspension, you should have already gained some negative camber. I've seen mine over -3° on the alignment rack when moving things around, there's a lot of range in the spc's.
If not that, I would look for bent suspension.
-06 MS6
-Corn fed 07 MS3 - Sold
Code Monkey (02-20-2015), Mauro_Penguin (02-21-2015), TiGraySpeed6 (02-21-2015)
 Old 03-09-2015, 06:56 AM   #15
Omega's Avatar
Posts: 441   (View Stats)
@Spencer@CorkSport; any news on the camber specifics?
 Old 05-19-2015, 11:32 PM   #16
Oli61's Avatar
Posts: 15   (View Stats)
Oli61 has a spectacular aura aboutOli61 has a spectacular aura aboutOli61 has a spectacular aura about
Hey guys i'm looking to fix coilovers on my MS6 this summer but for the camber is it better to fix SPC's or the CORKSPORT Upper Control Arm to get camber on my car ? I'm not sure which one is better.
Thanks for the help!!
Oli61 is offline   Reply With Quote
 Old 05-20-2015, 10:47 AM   #17
CorkSport's Avatar
Posts: 3,416   (View Stats)
How low are you going to drop your speed 6?
-Derrick
WWW.CORKSPORT.COM
 Old 05-20-2015, 11:03 AM   #18
Oli61's Avatar
Around 1.8"-2" in front and maybe 1.5"-1.8" in rear
 Old 05-20-2015, 11:17 AM   #19
Oli61's Avatar
-Derrick
I'm not able to message you..
I'm looking to buy coilovers this summer but before i want to know if Corksport Upper Control Arm are better or SPC's ball joint are better?
I'm looking to low like 1.8"-2" in front and 1.5"-1.8" in rear.
Thank you, Oli
NEW RELEASE: CorkSport Electronic Boost Control Solenoid SpencerC CorkSport 18 09-01-2018 07:02 AM
CorkSport Product Release! ? CorkSport Mazdaspeed 3 Lowering Springs Now Available CorkSport CorkSport 0 08-05-2011 06:30 PM
Page generated in 0.39440 seconds with 31 queries
