Like Tree113Likes
 Old 07-15-2013, 03:43 PM   #81
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
Originally Posted by Tommy View Post
Meth tank that is mounted under the hood on passenger side for those of us that want their trunk space and washer fluid.
Who needs clean windows?
sent with smiles and mouth hugs
Mods: stock
 Old 07-15-2013, 03:43 PM   #82
dale_gribble's Avatar
Posts: 4,720   (View Stats)
1. Take the AutoExes handling/rates and add another .25" of drop for MS6.
2. Make Billions.
3. You will be sucking coke off a hookers body in Vegas faster then you can say spring.
4. Die of coke overdose on your yacht.
Mauro_Penguin likes this.
MINI H1 6.0 - CAR LED TAILS
The Following 9 Users Say Thank You to dale_gribble For This Useful Post:
15driley15 (07-21-2013), Agent_Orange (07-16-2013), DamagedGoods (07-17-2013), Easter Bunny (07-15-2013), Hickpunk (09-03-2013), Mauro_Penguin (07-16-2013), ms3_goon (07-15-2013), rob ms6gt (07-21-2013), SLOWHATCH (07-16-2013)
 Old 07-15-2013, 03:52 PM   #83
jk_ms3's Avatar
Posts: 1,390   (View Stats)
Groans: 40
What about some more CS swag? I'd rock some CS boxers. I'd get my wife a CS bikini. Heck, I'd get the bikini for the wives of several of the guys on here.
EDIT: I would also consider the bikini for several of the guys on here.
On deck: VG Sharkfin Antenna
The Following 5 Users Say Thank You to jk_ms3 For This Useful Post:
06Speed6 (07-16-2013), Easter Bunny (07-15-2013), Kyle Undefined (07-16-2013), R4LLY3 (07-24-2013), SLOWHATCH (07-16-2013)
 Old 07-15-2013, 03:54 PM   #84
Mauro_Penguin's Avatar
Posts: 1,997   (View Stats)
Groans: 171
Liquid/Air IC
Gear sets
Stockish height spring upgrade
Bolt on oil cooler upgrade
Radiator upgrade
EGR block off that removes the entire EGR unit from the water manifold and comes with the IM plug. Cant believe that no one makes that.
Full SS turbo oil feed line for top mount turbos
AN12/16 oil drain fittings for Holset turbos (19mm ID is Holset spec and no one on earth makes them)
Undivided T3 exhaust housing for the HX35 series turbos that will flow enough to max the compressor (no one on earth makes one)
Bolt on fuel line (tank to CDFP) upgrade, the stock one is going to be close to maxed for the high hp guys
Upgraded oil pump and timing sprockets on the crankshaft, the oem metal is too soft and compresses which leads to slipped timing
Upgraded timing chain, there has got to be a v8 VVT that has higher load capability, I know because its listed on the Hitachi web page
Injector seals
Upgraded injectors
Upgraded clutch slave and master
Dual CDFP bracket
Radiator fan upgrade
MS6 engine skid plate
Rear diff cooler (Caddy CTS style)
Trans sealed ball bearing upgrade (its the rolling marble sound you hear at idle) those bitches are $60 from the dealer too. I have 3 or 4 broken ones laying around from my three transmissions and no tapered roller bearings have failed in any of those transmissions.
Drop in valve upgrade (they dont exist)
CDFP internal seal upgrade to keep oil from leaking into the fuel side
Top mount turbo intake
I think that about covers it.
Silly rabbit, you forgot a corksport air freshner!
 Old 07-15-2013, 03:54 PM   #85
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
You could put it on the drivers side up in the fender. A U shaped vent tube would be all thats needed to make it work if you wanted to tuck it up high in the fender.
 Old 07-15-2013, 04:05 PM   #86
BigBoostMS3's Avatar
Posts: 1,429   (View Stats)
Is the coolant reservoir for gen ones as well? Now that I extended my engine harness that's the next eye sore under the hood.
Does it replace the PS reservoir as well? I'm definitely interested in a dual res.
Sent from my SPH-L710 using Tapatalk 2
Scott
www.TorqueSteerStickers.com
 Old 07-15-2013, 04:29 PM   #87
faeker's Avatar
Groans: 731
Mine is already there. Vent tube n all
Mods: stock
El_Diablo (07-15-2013)
 Old 07-15-2013, 09:21 PM   #88
Emphezima's Avatar
Posts: 40   (View Stats)
Emphezima is a splendid one to beholdEmphezima is a splendid one to beholdEmphezima is a splendid one to beholdEmphezima is a splendid one to beholdEmphezima is a splendid one to beholdEmphezima is a splendid one to beholdEmphezima is a splendid one to behold
Grill replacement for genpu would be nice, seems like the only decent offerings are all imports which brings cost way up.
2011 MS3 Velocity Red w/tech
AT HPFP COBB AP ETS TMIC CS SRI TIP CAB SBT BPH UR TP JBR SSP HK RMM NGK SP FORGE BPV GS EBCS
Next: JBR RSB E-TUNE
Emphezima is offline   Reply With Quote
The Following 2 Users Say Thank You to Emphezima For This Useful Post:
Dead Ms3 (08-14-2013), El_Diablo (07-16-2013)
 Old 07-15-2013, 09:30 PM   #89
Yousuf's Avatar
Posts: 1,398   (View Stats)
Groans: 128
This grille replacement by @JTMS3; looks promising, I'd recommend subbing to this thread if you're really interested in a new grille How to make the Gen2 less happy. Give me some Ideas. - Page 7 - Mazdaspeed Forums
Mod-bug's back...
 Old 07-15-2013, 09:31 PM   #90
ilias's Avatar
Posts: 335   (View Stats)
ilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the world
Groaned at 9 Times in 2 Posts
I agree, grill will be nice
Cobb AP V3 // CPE HPFP // CS Downpipe // CS Coilovers // CS Rear Camber Arms // CS SRI and TIP // CS Oil Catch Can // CS RMM & TMInsert //
JBR RSB, Short Shift and bushing // Turbosmart BOV // NGK one step colder // ETS TMIC // STRATIFIED //
ilias is offline   Reply With Quote
 Old 07-15-2013, 09:31 PM   #91
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Liquid to Air IC kit, Five point harness mounting kit, tubular LCA, AWD conversion kit(lol)!
Sent from fastest ko4 Pu!
Nator is what it does.
The Following 2 Users Say Thank You to kritz For This Useful Post:
Dmurray06 (07-15-2013), El_Diablo (07-16-2013)
 Old 07-15-2013, 09:35 PM   #92
xx5PEEDxx's Avatar
Posts: 113   (View Stats)
xx5PEEDxx is the leader of the worldxx5PEEDxx is the leader of the worldxx5PEEDxx is the leader of the worldxx5PEEDxx is the leader of the worldxx5PEEDxx is the leader of the worldxx5PEEDxx is the leader of the worldxx5PEEDxx is the leader of the worldxx5PEEDxx is the leader of the worldxx5PEEDxx is the leader of the worldxx5PEEDxx is the leader of the worldxx5PEEDxx is the leader of the world
front lip for genpu!! We need some quality rice around here!!!
Silver 2013 w/ Tech -- CorkSport Intake / CorkSport Turbo Inlet Pipe / CorkSport CatBack Exhaust / CorkSport Race Pipe / Go Fast Bits Respons BOV / H&R Coilovers / H&R 15mm Spacers / Cobb Shift Knob / 33% Suntech Cermaic Tints w/ 18% rear hatch / Escort Passport 9500ix / Corksport Stubby Antenna / Xexon Yellow 3000k HID fogs / Head light Armor Yellow Fog Light Covers / LED Parking Lights and License Plate Lights / STI Limited Lip / Bayson Motor Sports Rear lip / Auto Tech Internals / Cobb Access Port v3
xx5PEEDxx is offline   Reply With Quote
The Following 4 Users Say Thank You to xx5PEEDxx For This Useful Post:
Corvette Tuner (07-16-2013), El_Diablo (07-16-2013), himurax13 (07-15-2013), Mauro_Penguin (07-16-2013)
 Old 07-15-2013, 10:58 PM   #93
ms6_nate's Avatar
Posts: 35   (View Stats)
ms6_nate has much to be proud ofms6_nate has much to be proud ofms6_nate has much to be proud ofms6_nate has much to be proud ofms6_nate has much to be proud ofms6_nate has much to be proud ofms6_nate has much to be proud ofms6_nate has much to be proud of
MS6 badgless grill, but different from the ebay ones, or a CS specific ones. And a MS6 extended rear lip spoiler.
Rayd likes this.
Houstin, Texas
ms6_nate is offline   Reply With Quote
The Following User Says Thank You to ms6_nate For This Useful Post:
rymanmazda (07-15-2013)
 Old 07-16-2013, 01:01 AM   #94
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Lol only if its a christmas tree!
2006 Mazdaspeed 6
 Old 07-16-2013, 02:39 AM   #95
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
ms3 sound symposer.
94 M
MS6
IS350
The Following 2 Users Say Thank You to Pu Manchu For This Useful Post:
Code Monkey (07-16-2013), Easter Bunny (07-17-2013)
 Old 07-16-2013, 03:22 AM   #96
Bigeasy's Avatar
Posts: 41   (View Stats)
Bigeasy has much to be proud ofBigeasy has much to be proud ofBigeasy has much to be proud ofBigeasy has much to be proud ofBigeasy has much to be proud ofBigeasy has much to be proud ofBigeasy has much to be proud ofBigeasy has much to be proud ofBigeasy has much to be proud of
Hood props
Exhaust manifold for BT... Sidewinder would be tits as well as a top mount for the 3's
Camshafts
Black housing headlights for the pus
Aero add ons
Racing seat brackets
Harness bar
Front Grill Replacement or front bumper for pu
Upgraded WG actuator for stock turbos
EWG mani for stock turbos
Gauge pods
Dash trim replacement(black or cf)
Throttle Body
Headstuds
Shift Forks
Gears
Koke382 likes this.
--Erik
2005 Stroked Silver EVO 8 -- SOLD
2005 Built White 30r STi -- SOLD
2010 Red Mazdaspeed 3 -- Self Tuned with E85 335whp/420wtq
Bigeasy is offline   Reply With Quote
The Following 2 Users Say Thank You to Bigeasy For This Useful Post:
El_Diablo (07-16-2013), Koke382 (07-16-2013)
 Old 07-16-2013, 07:18 AM   #97
bigmike's Avatar
Posts: 278   (View Stats)
bigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond repute
Originally Posted by Sid3wayS View Post
A mount for the ap much like cpe has for the dashhawk.
+3 for something to do with heat management.
If you go with oil cooler, add 2 ports somewhere on it so we can tap for temp/pressure.
I second this. A dock for the AP that I don't have to use damn tape or adhesive would be nice. One for around the dash area to glance at while driving.
2/1 91 octane gasoline/E85, Stratified tuned, ~340 hp/360 ft·lb
AEM Water/methanol injection kit 550 ml/min nozzle ~5 psi/10 psi triggers 1/1 methanol/water Filter Autotech HPFP internals BrakeBest Brake pads Front Clarion XC1410 car amplifier COBB Tuning Downpipe Catback exhaust Front mount intercooler v2.0 XLE bypass valve Hybrid mode Short ram intake Turbo inlet hose Airbox Sport springs Short throw shifter Shift knob Shifter weight AccessPORT V3 Corksport Mid chassis brace Oil catch can Rear sway bar Radiator shrouds LED light kit cp-e SAFEseal injector seals Excalibur Wheel Accessories Black acorn bulge lug nuts 3/4" Echlin Ignition Parts Tire pressure monitoring system Left, right tire Firehawk Wide Oval Indy 500 tires 225/40R18 XL Ground Control Frim strut bump stops Front Interstate Mega-Tron battery James Barone Racing Rear motor mount 88 durometer Transmission side motor mount 80 durometer Passenger side motor mount 80 durometer EGR block off kit Thermal insulating intake gasket kit Thermal insulating throttle body gasket Coolant bypass kit Solid shifter bushings Bypass valve hose Kicker 40CSS684 component speaker system Front KS68 speakers Rear 11PT10CA powered subwoofer enclosure Koni Sport yellow shock absorbers Front 540 degrees LLumar ATR 35 film Mazda 2004-2008 RX-8 rims 18" x 8" FL22 engine coolant Monroe Sensa-Trac shock absorbers Rear Motorcraft XT-M5-QS transmission fluid NGK Iridium IX 6510 LTR7IX-11 spark plugs ~0.28" gap Shell Rotella T6 5W-40 motor oil SSP Primary EGR delete kit Stratified Tuning Guardian Angel ~21.5 psi trigger Visual Garage Shark fin antenna
bigmike is offline   Reply With Quote
The Following 2 Users Say Thank You to bigmike For This Useful Post:
El_Diablo (07-16-2013), littleloogy (07-22-2013)
 Old 07-16-2013, 08:09 AM   #98
Corvette Tuner's Avatar
Posts: 404   (View Stats)
Corvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the world
That's probably never going to happen. It will probably end up costing more than the front set up and most people won't even buy the front set up.
It would be nice of you to offer a caliper paint kit so the rears could be painted to match the front calipers you offer.
Corvette Tuner is offline   Reply With Quote
The Following 3 Users Say Thank You to Corvette Tuner For This Useful Post:
littleloogy (07-22-2013), mrmonk7663 (07-16-2013), rfinkle2 (07-16-2013)
 Old 07-16-2013, 08:15 AM   #99
djern's Avatar
Posts: 1,139   (View Stats)
Groans: 27
Curb feelers
06 VRM Speed 6 W/Navi
05 Mazda Family Truckster
twitter.com/djern
instagram.com/djern
facebook.com/djern
 Old 07-16-2013, 08:18 AM   #100
maybe this?
SSP EGR Delete Kit MS3
SLOWHATCH likes this.
06Speed6 (07-16-2013), Dizzy Turbo (07-16-2013), El_Diablo (07-16-2013), SLOWHATCH (07-16-2013)
 Old 07-16-2013, 08:48 AM   #101
faeker's Avatar
Groans: 731
Oh that's sexy.
Mods: stock
 Old 07-16-2013, 08:57 AM   #102
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
The boxers need to be branded CockSport
A CS product to hold a Cobb product, lol
Sent while Tappin' that ass
The Following 4 Users Say Thank You to SofaKingAwesome For This Useful Post:
jk_ms3 (07-16-2013), rfinkle2 (07-16-2013), SarcasticOne (07-16-2013), Sid3wayS (07-16-2013)
 Old 07-16-2013, 09:08 AM   #103
faeker's Avatar
Groans: 731
I still say convert some of those lanyards you have into 1 gallon bottle holders for the foot wells in the back. or, just send me some and i'll do it myself.
Mods: stock
 Old 07-16-2013, 09:14 AM   #104
Yousuf's Avatar
Groans: 128
c'mon corksport make some bolt on hood struts so we don't need to rivet them in I shall keep bugging you about them
Mod-bug's back...
The Following 4 Users Say Thank You to Yousuf For This Useful Post:
Kyle Undefined (07-16-2013), rfinkle2 (07-16-2013), SLOWHATCH (07-16-2013)
 Old 07-16-2013, 09:18 AM   #105
super_pablo_'s Avatar
Posts: 1,648   (View Stats)
Give it time guys. You are making good products. People like me are interested, but Im just waiting for a couple of things to sort out financially. Brakes are serious business, but once a few guys get em, test em, and prove they are a quality product, I can almost guarantee you will dominate the big brake market for this platform.
Thanks for taking the risk in developing new products.
Joel@corksport likes this.
The Following 5 Users Say Thank You to super_pablo_ For This Useful Post:
Code Monkey (07-16-2013), Hush (07-16-2013), kritz (07-16-2013), SLOWHATCH (07-16-2013)
 Old 07-16-2013, 09:40 AM   #106
jm211's Avatar
Posts: 943   (View Stats)
CS should collect this and make a vote thread for genpu, juan and 6 and we shall vote.
Maybe make categories of perfomance, handling, cosmetic, and other.
CS (and Jamie) is in a great position, with two major vendors having issues they can really take some market space and build an even better name for themselves.
This is an exciting time for speed owners!
 Old 07-16-2013, 09:53 AM   #107
Crarrs's Avatar
Posts: 1,662   (View Stats)
Why is everybody bitching about rivets?
A rivet gun is $10 on Amazon, and they're easy to drill out if you need to remove them. I've done 3/16" stainless rivets with this one, no problem.
Stanley MR33C Medium Duty Riveter - Amazon.comStanley MR33C Medium Duty Riveter - Amazon.com
2004 MSM TiGrey
The Following User Says Thank You to Crarrs For This Useful Post:
 Old 07-16-2013, 10:17 AM   #108
CorkSport's Avatar
Posts: 3,416   (View Stats)
They're coming... no rivets.... promise.
WWW.CORKSPORT.COM
The Following 13 Users Say Thank You to CorkSport For This Useful Post:
06Speed6 (07-16-2013), evil MS3 (07-16-2013), faeker (07-16-2013), JesseFrye (07-16-2013), Kyle Undefined (07-16-2013), pstpolamalu43 (07-21-2013), rfinkle2 (07-16-2013), RobT2009 (08-02-2013), SarcasticOne (07-16-2013), SLOWHATCH (07-16-2013), tbot (07-16-2013), The Nut (07-16-2013), Tommy (07-20-2013)
 Old 07-16-2013, 10:21 AM   #109
Yousuf's Avatar
Groans: 128
Mod-bug's back...
The Following 2 Users Say Thank You to Yousuf For This Useful Post:
Kyle Undefined (07-16-2013), SLOWHATCH (07-16-2013)
 Old 07-16-2013, 11:32 AM   #110
El_Diablo's Avatar
Groans: 769
Seriously, I don't get the rivet BS. its faster than bolting them on, the struts can be removed by pulling the clip and they will stay solid a lot longer than a bolt on system. Rivets dont work loose easily due to vibration like bolts, something to think about if you're mounted or experience a lot of wheel hop.
Crarrs (07-16-2013)
 Old 07-16-2013, 11:45 AM   #111
Yousuf's Avatar
Groans: 128
I think it's because most people don't want the hood struts bad enough to bother making sure they drill everything perfectly and line them up, and since most of us are always under the hood anyways it wouldn't really matter if they loosened up over time since we could just tighten them.. I guess it's one of those to each his own things.. I get what you mean though by rivet BS
Mod-bug's back...
 Old 07-16-2013, 11:45 AM   #112
Crarrs's Avatar
If you can't figure out a rivet gun, there are probably a bunch of mods you've already done to your car that you shouldn't have touched.
2004 MSM TiGrey
The Following 3 Users Say Thank You to Crarrs For This Useful Post:
Easter Bunny (07-17-2013), El_Diablo (07-16-2013), Tommy (07-20-2013)
 Old 07-16-2013, 11:50 AM   #113
Yousuf's Avatar
Groans: 128
People just don't find them important enough to even bother with the rivet gun, I'm sure we can handle a rivet gun if we can handle a downpipe install
Mod-bug's back...
 Old 07-16-2013, 11:58 AM   #114
Cujo's Avatar
Posts: 1,192   (View Stats)
Groaned at 6 Times in 4 Posts
you could probably sell 1000s...
2012 Mazdaspeed3 Black Mica
 Old 07-16-2013, 11:58 AM   #115
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
I'm sure we can think of more part ideas than just hood struts
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 07-16-2013, 12:15 PM   #116
Speeeeeed
06Speed6's Avatar
They dont offer the IM plug so I have to buy the SSP kit and the JBR kit in order to get a complete kit. That is the dumbest thing ever
2006 Mazdaspeed 6
 Old 07-16-2013, 12:19 PM   #117
MazdaspeedKills's Avatar
Posts: 443   (View Stats)
MazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the world
Groaned at 7 Times in 4 Posts
I would suggest something that isn't already made by competitors (CP-E, SU, etc). Some things that come to mind.
- intercooler spray kit for TMIC or FMIC
- under drive pulley for the accessories
- electric exhaust cutouts (google QTP exhaust)
BTW whatever happened to the lightened crank pulley?
Koke382 likes this.
MazdaspeedKills is offline   Reply With Quote
The Following 2 Users Say Thank You to MazdaspeedKills For This Useful Post:
Koke382 (07-16-2013), rfinkle2 (07-16-2013)
 Old 07-16-2013, 12:57 PM   #118
El_Diablo's Avatar
Groans: 769
Originally Posted by MazdaspeedKills View Post
I would suggest something that isn't already made by competitors (CP-E, SU, etc). How about a intercooler spray kit for TMIC or FMIC or under drive pulley for the accessories?
IC sprayers has been proven to be ineffective on our platforms, even with the gen2 scoop. You're far better off spraying it into the engine.
Cams
Lightweight pullies
Electric water pump
Lightweight flywheel
Lighter or stronger springs & retainers
Transmission gearsets or 1-2 gears
Different gen2 wing or gurney flap for the stocker
Rear bumper or diffuser
Underbody trays
Aluminum subframe bushings
Front bumper or grille that is more effcient at managing air
Meth tank for the void in the upper portion of the drivers side fender
Mazda 5 rear rotor conversion
Two piece light weight rotors
Brake duct kit for the front fog location
Coil pack cover
Delrin suspension bushings
A gauge pod that would work well with the interior of a gen2
Wider front fenders for the drag racers
 Old 07-16-2013, 12:58 PM   #119
Roddiy's Avatar
Posts: 5,388   (View Stats)
Groans: 279
I don't think we'll get into the turbo market, that is very narrow and limited as far as sales are concerned.
How about an OEM-to-T3/T4 adapter flange?
For those of us who can't go all out all at once and order DP + EM + non-OEM flanged turbo...
Also, a small in-bay Meth tank that can be easy to access/refill would come a long way.
Maybe also an undertray that looks good!
2010 LSM Speed3
#BakeryTuned
The Following User Says Thank You to Roddiy For This Useful Post:
 Old 07-16-2013, 01:38 PM   #120
Like the CP-E triple for the first gen...
I don't know why someone hasn't been all over this.
I'd buy one.
El_Diablo (07-16-2013), jk_ms3 (07-16-2013), Roddiy (07-22-2013)
Officially Official: 2012 Buick Verano is one part Cruze, one part Regal Haltech Automotive News 0 01-05-2011 10:50 PM
Page generated in 0.64061 seconds with 48 queries
