Like Tree117Likes
 Old 10-30-2014, 05:12 PM   #321
SpencerC's Avatar
Posts: 2,159   (View Stats)
There, I made you all a sign, just like at your favorite bar.
The Following 5 Users Say Thank You to SpencerC For This Useful Post:
Easter Bunny (10-30-2014), faeker (10-30-2014), SarcasticOne (10-30-2014), skiptowncat (10-30-2014), Spec (10-30-2014)
 Old 10-30-2014, 05:15 PM   #322
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Just with a 6 year wait...
Personally I think you should just change it to say "available in '2 weeks' "
Granted people who aren't on MSF might not understand...
The Following 5 Users Say Thank You to SarcasticOne For This Useful Post:
cshunter (10-30-2014), Easter Bunny (10-30-2014), Hammology (10-30-2014), kbz0129 (10-31-2014), magicka (11-21-2014)
 Old 11-21-2014, 11:53 AM   #323
leo766's Avatar
Posts: 300   (View Stats)
leo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond repute
Groaned at 93 Times in 33 Posts
corksport once these cams are finally available should start offering cylinder head port and polish and flow match, along with these cams, that would be a bad ass top end Assuming these don't wind up like CP-Es intake manifold, I still have their biz cards with the cad drawing of it on there lol
Fresh to High Rockies Colorado from VA DC area MS6 07 TiGray!
Cpe: FMIC, CAI, TIP, HPFP, bone engine mount
Cobb AP, Test pipe, turbosmart BPV, whitlenine swaybar
Turbine Tech: Extra front motor mount, both diff mounts +bushings
EGR Delete, mini 0803 Dash cam, Prosport Boost guage. Dash Hawk,
AWR: Trans mount with 88 duro bushings, End links front/rear(removed due to them being total garbage and got some moog stock ones for all around on rockauto.
17x7 Kosei K1 TS 15lb rims, goodyear 225/50r17 all season performance tires and RPM springs
Waiting to install: SPC Ball Joints, SS clutch line, lower engine mount bracket local car shop damaged during clutch install and thermal TB gasket and coolant inline plumbing line that can be turned on and off on demand
leo766 is offline   Reply With Quote
The Following 5 Users Say NO Thank You to leo766 For This Un-useful Post:
dooderek (11-22-2014), Easter Bunny (11-21-2014), jack_hammer (11-21-2014), Neverlift (11-22-2014), TazFc3s (11-22-2014)
 Old 11-26-2014, 10:03 AM   #324
CorkSport's Avatar
Posts: 3,416   (View Stats)
If all goes well the camshafts will not be a 6 year wait. We are still working on them.
-Derrick
WWW.CORKSPORT.COM
ItsNox (11-26-2014), kbz0129 (11-28-2014), maisonvi (11-26-2014)
 Old 11-26-2014, 06:19 PM   #325
jme
jme's Avatar
Posts: 39   (View Stats)
jme is a jewel in the roughjme is a jewel in the roughjme is a jewel in the roughjme is a jewel in the rough
So 2 Weeks!!!!!!
CorkSport likes this.
BNR stage 4 turbo, Full race exhaust manifold, Mahle 2618 Forged Pistons, Darrell Cox vvt, Manley H-Tuff Rods, Clevite H-Series Main & Rod Bearings, SP63 Custom Age 625+ 10mm Head Studs, ARP main studs, Keyed Crankshaft, Pulley, & Sprockets, pioer stage 2 camshaft
Guardian Angle with 4 bar Corksport 3" TBE, HPFP, 3.5" intake, Corksport FMIC, JMF Intake Manifold, Synapse DV, toyota fuel injector seals, Grimm speed EBC, RMM, Balanced Crank/Clutch/Flywheel, Balance shaft delete, James Barone Oil pan Baffle, South Bend stage 4 Extreme clutch kit, Injecting yummy METH "CM10"!
jme is offline   Reply With Quote
 Old 11-26-2014, 07:15 PM   #326
everton99's Avatar
Posts: 1,044   (View Stats)
everton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the world
Groaned at 8 Times in 7 Posts
Originally Posted by jme View Post
So 2 Weeks!!!!!!
Somewhere between 2 weeks and 5 years and 364 days. We've got us a solid timeline now!
everton99 is offline   Reply With Quote
The Following User Says Thank You to everton99 For This Useful Post:
Darth_Nuruodo (11-26-2014)
 Old 11-26-2014, 07:56 PM   #327
Darth_Nuruodo's Avatar
Posts: 2,775   (View Stats)
Groans: 88
But still sooner than the CPe IM
Sent from my SCH-I605 using Tapatalk
Bone stock so far
Darth_Nuruodo is offline   Reply With Quote
The Following User Says Thank You to Darth_Nuruodo For This Useful Post:
rymanmazda (11-27-2014)
 Old 11-26-2014, 08:39 PM   #328
CorkSport's Avatar
Lol
I cannot comment on that timeline
We will share when we can on the info.
Derrick
WWW.CORKSPORT.COM
 Old 11-26-2014, 09:18 PM   #329
jme
jme's Avatar
I have faith. You must give me back what I once had in my hands. My entire build was based around what you took away from me!!!!
The Following User Says Thank You to jme For This Useful Post:
KotzurRacing (11-27-2014)
 Old 11-27-2014, 10:18 PM   #330
KotzurRacing's Avatar
Posts: 444   (View Stats)
KotzurRacing is the leader of the worldKotzurRacing is the leader of the worldKotzurRacing is the leader of the worldKotzurRacing is the leader of the worldKotzurRacing is the leader of the worldKotzurRacing is the leader of the worldKotzurRacing is the leader of the worldKotzurRacing is the leader of the worldKotzurRacing is the leader of the worldKotzurRacing is the leader of the worldKotzurRacing is the leader of the world
SAME HERE
COBB BROKE JMS FIXED
MazdaSpeed. Errrone can afford
KotzurRacing is offline   Reply With Quote
 Old 01-15-2015, 10:19 PM   #331
jme
jme's Avatar
Update please......
 Old 01-15-2015, 10:31 PM   #332
BLKSTIG's Avatar
Posts: 507   (View Stats)
this summer at the earliest is the last I heard from Corksport
 Old 01-15-2015, 10:33 PM   #333
jme
jme's Avatar
Did you hear this today? Errr Thursday....I'm just getting in from work so its still today to me.
 Old 01-16-2015, 01:05 AM   #334
BLKSTIG's Avatar
I pm'd corksport on the 15th
I work 12hr shifts from 6pm to 6am
I never know what the day is...
jme likes this.
 Old 01-16-2015, 12:46 PM   #335
SpencerC's Avatar
No update besides the fact that it is still being worked on and still going to be later. Obviously not 2020, but probably not before this summer at the earliest.
 Old 08-12-2015, 05:37 AM   #336
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
Sooooooooooo it's summer bahahaha
The Following 3 Users Say Thank You to 2.0t03speed For This Useful Post:
Easter Bunny (08-12-2015), MS3Shadow (08-12-2015), SarcasticOne (08-12-2015)
 Old 08-12-2015, 08:44 AM   #337
CorkSport's Avatar
Thus the 2020 date.
-Derrick
WWW.CORKSPORT.COM
2.0t03speed (08-12-2015), Justin@Freektune (08-12-2015), MS3Shadow (08-12-2015), WetzMS3 (08-12-2015)
 Old 08-12-2015, 11:07 AM   #338
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
You guys gonna test 4 lobe HPFP setup too? *hint hint*
 Old 08-12-2015, 11:45 AM   #339
Brandon@corksport's Avatar
Posts: 170   (View Stats)
Maybe someday eventually!
Cheers,
Brandon Johnson
CorkSport Mazda Performance
(360)260-2675 ext. 106
BrandonJ@corksport.com
 Old 08-12-2015, 01:00 PM   #340
speedfreak44's Avatar
Posts: 1,391   (View Stats)
Synonyms for maybe
adv possibly
perchance, perhaps, as it may be, can be, conceivable, conceivably, could be. credible, feasible, imaginably, it could be, might be, obtainable, weather permitting, 2 weeks
The line up:
 Old 08-12-2015, 01:02 PM   #341
BLKSTIG's Avatar
^ Tl;Dr
2weeks
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f500/product-release-camshafts-disi-mzr-motor-172465/
Anybody try the new corksport cams yet? : mazda This thread Refback 07-25-2014 06:17 PM
Dual Product Release!! CorkSport Mazdaspeed 3 Passenger Side Motor Mount and Transmission Insert CorkSport CorkSport 143 04-13-2016 12:00 AM
Product Release!! CorkSport Race Rear Motor Mount CorkSport CorkSport 67 12-19-2014 03:52 PM
Product Release MAZDASPEED 6 Motor Mounts in Stock!! JBR JAMES BARONE RACING 133 02-26-2014 09:20 PM
New Product Release!! – JBR 70 & 80 Duro Focus ST Passenger Side Motor Mounts JBR JAMES BARONE RACING 1 01-29-2014 08:57 PM
Product Release! Mazdaspeed Protege / Mazda Protege Front Motor Mount CorkSport CorkSport 0 02-22-2013 10:10 AM
Page generated in 0.39893 seconds with 33 queries
