| CorkSport To say that CorkSport is passionate about Mazda Performance is understatement. It is the essence of what we do. Our mission to offer unparalleled customer service and support, an uncompromising commitment to the community, and deliver top quality performance parts is demonstrated with each product we develop to help fulfill your vehicles performance potential. At CorkSport we believe it doesn’t have to come in a fancy package or be the most expensive product on the market to be the best. |
![]() | | #81 | ![]() |
![]() Join Date: Jan 2009 Location: Andover, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,936
Groans: 192
| Not Ranked : 0 score I'm pretty sure they wont because of the straight face on the 9's. If you got the 8's they are more bubbled.
__________________ precision gen2 5862 coming soon [SIZE="1"]07 MS3 GT.. Engine:Cobb V3,GTX3076r EWG,Wiseco Pistons/Manley Rods, L19's,JMF, Bosch 3.5bar MAP,CS cat-back,M2 DP, full race manifold,FP internals,FREEK 4",CP-E flange HKS,DO Stage II ss lines,Cobb piping,TR8L,MD RMM&TMM,JBR RSB & FSB,JBR SST,JBR knob,ACT 6puck,JBR EGR delete,CPE Seals,Grimmspeed EBC,JBR BSD,MD Catch Can.Looks:yellow lamin-x fogs,chrome turn signals,side moldings removed,20% tint,CS wheelSuspension/Wheels:Enkei RPF1 17x9,Eibach 5mm spaces H&R springs,koni yellows. GTX3076r --- 479/412 S4-460/400 Highest HP BNR S3 BNR-S3 424/397 | |
![]() | | #82 | ![]() |
![]() Join Date: Mar 2010 Location: SOJO
Rep Power: 176 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 155
Sent from my iPhone using Tapatalk | |
![]() | | #83 | ![]() |
![]() Join Date: Apr 2013 Location: Seattle, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,526
| Not Ranked : 0 score Wish I knew. I don't have any info from previous customers that I can find confirming that sizing though.
__________________ SOLD: 2009 Metro Gray Mica Mazdaspeed 3 - CorkSport Stage II SRI - CorkSport High Flow Downpipe -CorkSport TMIC - CorkSport Short Shift Plate - CorkSport Shifter Bushings - CorkSport Rear Motor Mount - CorkSport Passenger Side Motor Mount -Cobb Accessport - CorkSport HPFP Max Flow Fuel Pump Internals - CorkSport LED Kit 1992 Red Mazda Miata - Flyin Miata Swaybars, Hard Dog Hard Bar, Koni Yellow Shocks, Flying Miata Springs, Spec Stage 1 Clutch, E-Code headlights Next?: 2016 Mazda Mx5? 2017 Mazdaspeed 3? [SIGPIC][/SIGPIC] |
![]() | | #84 | ![]() |
![]() Join Date: Jun 2008 Location: Tucson, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 752
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score You could use the template and check against the wheel?
__________________ Wiseco OTS pistons, Eagle Rods, ARP mainstuds, JBR BSD w/ baffle,GT2871R, 51R battery, JBR V1 3.5 aluminum widepath, CP-e Catted DP, custom 3in cat-back, Treadstone TR8L core w/ COBB piping, Damond OCC, HKS SSQV3 (full VTA), autotech HPFP internals, Self tune 33% E85, Grimmspeed EBCS (3port), JBR TM & PM, TRZ Rmm, COBB short shifter, COBB Front/Rear swaybars, Koni STR.T struts, AXIS Circuits 18x8.5 45offset **Old Motor** Best 1/4 -13.19 Stock Turbo/ street tires Best trap speed - 112mph **New Motor** Best 1/4 - 13.35 Stock turbo/ street tires Best trap speed - 112.5 |
| The Following 2 Users Say Thank You to udntknw For This Useful Post: | Code Monkey (07-31-2014), Easter Bunny (07-31-2014) |
![]() | | #85 | ![]() |
![]() Join Date: May 2013 Location: Tucson
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score Spencer/Kim, I left ya a voice mail. Having an issue. It appears that either bracket holes for the caliper were not bored enough, or the allen bolt is too long. Either way, there is play of about a few millimeters when fully torqued. The caliper clangs around a bit. It effects 3 of the 4 holes. For now I put small spacers in to fix, and the brakes certainly work, but with the spacer i am sacrificing the sweep area of the pad on the rotor and am worried about overall integrity....
__________________ www.emeraldtuning.com twittter: @emeraldtuning YouTube: https://www.youtube.com/user/EmeraldTuning 2013 CWP w/ Tech JBR Shortie JBR TIP JBR Boost Tubes JRB RMM JBR RSB JBR 5mm Spacers JBR Heavy Shift Knob JBR Flaps Buddy Club Custom 3" Exhaust Koni Yellows Corksport 4-Piston Brake Upgrade Corksport Springs Corksport Adjustable End Links Stoptech Slotted Stoptech Sport Pads Stoptech SS Lines Last edited by Hal; 08-10-2014 at 07:21 AM. |
![]() | | #86 | ![]() |
![]() Join Date: Oct 2012 Location: Concord, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
| Not Ranked : 0 score Just installed this kit this weekend. Overall it's a nice kit but I do have to nit picks with the kit. 1. For the cost of the kit I would expect the brake lines to be one piece. Not use one adapter one each end. Even though it should be fine, I always think for the brake system the less adapters the better. 2. In order to run off the shelf brake pads you have to modify the inner pads and cut off the little extra nub. I do believe this was talked about in some other thread. I check dozens of pad manufactures everyone has the extra nub. |
![]() | | #87 | ![]() |
| Not Ranked : 0 score @Hal; I didn't hear about a message, I'll look into it though first thing tomorrow. @SaveMelMac; Oddly you are the first to worry about the lines not being one piece. I do get the thought though, not sure why we went with it being the way it is. I have seen some pads that need the nub ground off, and some that don't. EBC pads I've seen needed it ground off, but I've seen Hawk that were fine. Not sure what's up with that.
| The Following User Says Thank You to SpencerC For This Useful Post: | Easter Bunny (08-11-2014) |
![]() | | #88 | ![]() |
| Not Ranked : 0 score Spencer, I received an email from Kelly stating engineering was looking in to it. If I could get the new hardware by Friday, I can sit down Saturday and swap em out real quick and send the originals back. They look boss, and overall feels better, but I'm just worried about integrity over the long term with the spacers. Thanks!
__________________ www.emeraldtuning.com twittter: @emeraldtuning YouTube: https://www.youtube.com/user/EmeraldTuning 2013 CWP w/ Tech JBR Shortie JBR TIP JBR Boost Tubes JRB RMM JBR RSB JBR 5mm Spacers JBR Heavy Shift Knob JBR Flaps Buddy Club Custom 3" Exhaust Koni Yellows Corksport 4-Piston Brake Upgrade Corksport Springs Corksport Adjustable End Links Stoptech Slotted Stoptech Sport Pads Stoptech SS Lines |
![]() | | #89 | ![]() |
| Not Ranked : 0 score The only brand I saw that didn't have the nub was hawk. Basically I was referring to stock off the shelf pads you could pick up at any auto parts store. I don't think I made that clear in my first post. I work at an auto parts store and I looked at every manufacturer I could find, I probably spent too much time. More than my boss would like lol. Just trying to save some people some time if they decide to go that route and grind off the nubs before you start the job. Just needs to be done on the inner pads. |
| The Following User Says Thank You to SaveMelMac For This Useful Post: | SpencerC (08-12-2014) |
![]() | | #90 | ![]() |
| Not Ranked : 0 score I've got a sweet squeal on my passenger side now...i think it has to do with running the spacers....occassional sound, nothing too bad. once the new hardware arrives I will report back.
| The Following User Says Thank You to Hal For This Useful Post: | SpencerC (08-12-2014) |
![]() | | #91 | ![]() |
| Not Ranked : 0 score Thanks for keeping us updated!
![]() | | #92 | ![]() |
| Not Ranked : 0 score No problem. Is the new hardware on the way?
![]() | | #93 | ![]() |
![]() Join Date: Nov 2009
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score I hate to bump an old thread with this but I have some serious concerns about the fatigue life of the caliper brackets, especially if they are aluminum. Was a fatigue analysis done on this part? How many cycles? There should not be 90 degree angles between the caliper and it's mounting tabs, even with fillets. There's a reason you don't see this on OEM designs, or any of the major aftermarket brake manufacturers. The tabs are always blended and webbed as much as is possible. The brake caliper brackets are NOT the place to try and save a few ounces by minimizing material. Last edited by drago86; 11-04-2015 at 03:13 AM. |
![]() | | #94 | ![]() |
| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
-Derrick | |
| The Following 2 Users Say Thank You to CorkSport For This Useful Post: | Easter Bunny (11-06-2015), MS3Shadow (11-06-2015) |
![]() | | #95 | ![]() |
Groans: 192
Comes in fighting like he knows the material and is mastermind in brakes....
| The Following 4 Users Say Thank You to taf0422 For This Useful Post: |
![]() | | #96 | ![]() |
| Not Ranked : 0 score |
| The Following 2 Users Say Thank You to Raider For This Useful Post: | PhillyCheese (11-06-2015), silvapain (11-06-2015) |
![]() | | #97 | ![]() |
Rep Power: 1237 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,288
Groans: 111
| Not Ranked : 0 score Ok, old thread is old but as a romanian saying states one needs an old chicken to make the soup good. So after these years I'd like to hear some opinions. I want to change my factory callipers, they're pretty old and I feel they don't perform as I'd like (mainly street spirited driving, occasional track/circuit racing). Right now I have two options: 1. brand new factory callipers; 2. some decent aftermarket callipers that are proven to perform well under these conditions. Therefore I'd like to hear a few opinions apart from the stupid colour mismatch (my car is blue for I'll be good with silver callipers in the back until I paint them with some Foliatec Blue RS paint). I'd also like to know how much larger rotors can these callipers accommodate and where can I source them (330mm rotors would be nice, even though not necessarily a must).
![]() | | #98 | ![]() |
| Not Ranked : 0 score Been running these for a few years now and about 20k miles no issues what so ever. Just driven on the street. I have been happy. Sorry that's the only input I can contribute |
![]() | | #99 | ![]() |
![]() Join Date: Mar 2013 Location: Accokeek MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 81
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score I had these on my first pu and they were great for street driving. I recently was in the market to upgrade braking system as I needed new rotors and looked at these again. For the price I was going to pay for these calipers and a pair of rotors was setting me back $1200. I kept searching and found a complete BBK from wilwood 6 pot and 2 piece rotors, pads and SS lines for $1150 on Edge. I'm not knocking the CS calipers as they're great if you just want a caliper and still have life left in your rotors, but if you're upgrading all components you can get an entire kit for just a few more Hondos. And that weight redux!
__________________ 2013 LSM w/tech Cobb AP V3, CBE CS Turbo tuned by PD Corksport Catted DP/HPFP Internals JBR FMIC Pipe Kit w/TR8 CP-E TIP/3.5" Intake DM OCC/TMM Forge V2 BPV Bilstein B8 w/Swift springs Wilwood 6 pot BBK EBC RedStuff rear pads Konig Hypergram 18x8.5" |
| Product Release! ? CorkSport Adds Mazdaspeed 6 Rear Sway Bar to Product Line-Up | CorkSport | CorkSport | 47 | 04-22-2014 11:53 PM |
| Product Release! CorkSport Oil Catch Can Development and Release Notes | CorkSport | CorkSport | 118 | 03-25-2014 05:20 PM |
| Product Release! CorkSport Mazdaspeed 3 and Mazdaspeed 6 Brake Pads | CorkSport | CorkSport | 54 | 03-07-2014 07:50 PM |
| Rear brake caliper piston wont go in? | AFcadet | MazdaSpeed 3/6 - Suspension & Brakes | 19 | 09-19-2012 04:06 PM |
| Product Release! CorkSport LED 3rd Brake Light for 2010+ Mazda3 Sedan | CorkSport | CorkSport | 0 | 04-03-2012 11:20 AM |
