Like Tree30Likes
 Old 06-19-2015, 11:11 PM   #241
Kvo_8's Avatar
Posts: 97   (View Stats)
Kvo_8 has a brilliant futureKvo_8 has a brilliant futureKvo_8 has a brilliant futureKvo_8 has a brilliant futureKvo_8 has a brilliant futureKvo_8 has a brilliant futureKvo_8 has a brilliant futureKvo_8 has a brilliant futureKvo_8 has a brilliant futureKvo_8 has a brilliant futureKvo_8 has a brilliant future
So since I got my CS springs/adjustable shocks installed, I've been rubbing really bad. I got my fenders rolled and it's only helped a little bit. I set both the front and rear to the stiffest setting. I started off about 6 clicks from the softest setting and have been making it stiffer throughout the week. That hasn't helped at all. Even when I have one passenger in the car, I rub on every little bump on the highway. Has anyone had this issue with the CS spring/adjustable shock combo?
Kvo_8 is offline   Reply With Quote
 Old 06-20-2015, 11:22 AM   #242
iammike's Avatar
Posts: 1,415   (View Stats)
Rubbing in the front or the rear? The CS dampers gave me horrible rubbing in the rear for two reasons.
1. They don't hit the bump stop until the wheel is very deep up in the wheel well.
2. They were not strong enough to keep the rear from traveling that far quite often.
As such, I had to make major modifications to my splash guards, trim back the bumper tabs, and roll my fenders to make them not rub MOST of the time. Could still happen on occasion.
Mike
 Old 06-20-2015, 12:12 PM   #243
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
If it's the rear, i'd suggest this instead of modifying the car. Buy a second set of rear spring insulators. Install them on the bottom of the rear spring. You'll get about half an inch of lift. Plus, they're not expensive
it's fun to do bad things
 Old 06-20-2015, 03:36 PM   #244
Kvo_8's Avatar
What major modifications did you do? I'm thinking that I'm going to have to do the same really soon.
Yeah, it's the rear that's rubbing the most. I just did a quick google search for rear spring insulators, is there a certain brand/size or anything like that I should look for? I think raising the back a half inch would be pretty nice. Right now, it's slightly tucked in the rear
Last edited by Kvo_8; 06-20-2015 at 03:36 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-20-2015, 05:06 PM   #245
iammike's Avatar
This will help but unfortunately only a little. Ask me how I know. lol
Mike
 Old 06-20-2015, 05:07 PM   #246
iammike's Avatar
Image is attached. It's pretty extreme and I was still rubbing back there in rare situations.
Mike
 Old 06-20-2015, 08:53 PM   #247
Groans: 549
after a few years, my car rubbed with stock suspension. i hoped it would be sagging springs, but when i changed springs the problem remained. that extra piece made all the difference for me.
i used OEM. in stock form, they're on top of the rear springs. buy a set and install on the bottom as well.
Last edited by jack_hammer; 06-20-2015 at 08:53 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-20-2015, 10:59 PM   #248
Kvo_8's Avatar
Thanks for the image man. I'm glad I'm not the only one that has this issue. Just wish I would've seen this before I bought the CS springs/shocks combo
 Old 07-24-2015, 12:35 PM   #249
wolfpack92054's Avatar
Posts: 65   (View Stats)
wolfpack92054 has much to be proud ofwolfpack92054 has much to be proud ofwolfpack92054 has much to be proud ofwolfpack92054 has much to be proud ofwolfpack92054 has much to be proud ofwolfpack92054 has much to be proud ofwolfpack92054 has much to be proud ofwolfpack92054 has much to be proud of
You think if I ran stock pu wheels in the back no spacers I won't get any rub? I really want these over Konis... only due to the rear adjustability
wolfpack92054 is offline   Reply With Quote
Product Release!! CorkSport Adjustable Shocks and Struts for Mazdapeed 3 and Mazda 3 Trey-Z CorkSport 3 11-26-2013 10:41 AM
Product Release!! CORKSPORT 2010+ Mazda 3 Skyactiv Air Box for CorkSport SRI CorkSport CorkSport 0 07-11-2013 04:00 PM
Product Release! CorkSport 2010+ Mazda 2 Struts and Shocks CorkSport CorkSport 8 01-15-2013 05:42 PM
Product Release! CorkSport Adjustable Rear Camber Arms CorkSport CorkSport 15 07-31-2012 12:30 PM
Page generated in 0.31236 seconds with 24 queries
