Like Tree19Likes
 Old 04-10-2014, 08:50 PM   #81
daytonabluez05's Avatar
Posts: 222   (View Stats)
daytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant future
Why the face palm?
daytonabluez05 is offline   Reply With Quote
 Old 04-11-2014, 04:10 PM   #82
Chron's Avatar
Posts: 800   (View Stats)
Chron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the world
Ordered Wednesday morning... Just came in the mail... That was some super fast shipping! Now for the install!
2012 Mazdaspeed 3 CWP
CorkSport: 3" Power Series Intake, TP, CBE, RMM, TMM Insert, RSB, Front Control Arm Bar, ECU Relocation Box, Short Shifter, Leather Shift Knob, Hood Struts, Exhaust Hangers, LED Fog Lights, Interior LEDs
Other: AutoTech HPFP, ETS TMIC, Cobb AP, Morimoto 3five 4500k HIDs
CorkSport Whore
Stratified Tuned
Chron is offline   Reply With Quote
The Following User Says Thank You to Chron For This Useful Post:
sidekick (05-06-2014)
 Old 04-12-2014, 08:26 AM   #83
England15j's Avatar
Posts: 1,910   (View Stats)
Got a call from corksport today asking me to wait to install my shifter. I have also noticed they pulled it from the website and now says "call us for a price" anybody know whats going on with this? @Spencer@CorkSport;
 Old 04-12-2014, 08:27 AM   #84
Blkpearl's Avatar
Posts: 353   (View Stats)
Recall already ?
 Old 04-12-2014, 08:39 AM   #85
Chron's Avatar
Guess I'll wait to install mine now...
CorkSport Whore
Stratified Tuned
 Old 04-12-2014, 09:32 AM   #86
England15j's Avatar
It looks like the 2012-13 is still available for purchase the 2010-11 is not available. Maybe it's just a 2010-11 issue?
 Old 04-12-2014, 12:49 PM   #87
iammike's Avatar
Posts: 1,415   (View Stats)
From my install, I certainly can't see what would be wrong for the 2012-2013 anyway. I'm certainly curious though.
Mike
 Old 04-12-2014, 06:49 PM   #88
Polaren's Avatar
Posts: 13   (View Stats)
Polaren has a spectacular aura aboutPolaren has a spectacular aura about
I believe it only applies to the 2010-2011.
The bases are different and the cable looks like it attaches opposite side(not sure if there is a benefit to the 2012 base/design). Something about a part being wrong I was told.
Polaren is offline   Reply With Quote
 Old 04-12-2014, 06:51 PM   #89
covelife1016's Avatar
Posts: 151   (View Stats)
covelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond repute
Just about to buy this for my 2010 too.
2010 MS3 non tech
// CS TMIC// CS battery box// JBR short shifter// JBR 88a rmm// JBR boost tubes// JBR solid shifter bushings// JBR coolant bypass and throttle body tig// Kozmic Motorsports primary and secondary egr delete// NGK one step colder plugs// AT fuel pump internals// HTP 3" intake// GFB bov// COBB accessport V2 // GroundControl springs// Koni yellows//
TUNED BY STRATIFIED
covelife1016 is offline   Reply With Quote
The Following User Says Thank You to covelife1016 For This Useful Post:
Speed3Power (04-22-2014)
 Old 04-13-2014, 03:23 PM   #90
I am a banana's Avatar
Posts: 43   (View Stats)
I am a banana has much to be proud ofI am a banana has much to be proud ofI am a banana has much to be proud ofI am a banana has much to be proud ofI am a banana has much to be proud ofI am a banana has much to be proud ofI am a banana has much to be proud ofI am a banana has much to be proud of
Helped my friend install one on Friday night. Everything went in fine except the ball stud was on the wrong side if the shaft out of the box. That added an extra couple minutes to take it apart and move it to the correct side. Other than that, it went smoothly.
Ace likes this.
I am a banana is offline   Reply With Quote
The Following User Says Thank You to I am a banana For This Useful Post:
mazdaspeedmyk (04-13-2014)
 Old 04-14-2014, 12:57 AM   #91
mazdaspeedmyk's Avatar
Posts: 124   (View Stats)
@I am a banana; helped me install the Corksport Adjustable Short Shifter.
Overall, I really like the shifter and it's quick short throws. It was easy to put in. We found that removing the center console gave us more room to work with. We had to buy white lithium grease and T20 torx bit.
The shifter came with the pin on the shifter ball on the wrong side. We realized it after we put the assembly back together. No big deal, we just moved it to the correct side. @Spencer@CorkSport; heads up on that. Also, I hear that a couple other people are also having issues with the 10-11 MS3s' center console hitting the adjuster plate. I'm a 10, but don't have that issue because my center console is off a 12 MZ3 SA.
Here's where the pin should have been placed:
I have a TWM SSP and, combined with the shifter, the throw is super short. I have it set to the shortest throw position. I tried the longer positions, but the 1,3, and 5 gears wouldn't engage. I think that's due to the SSP being installed. I adjusted the height to be a tad higher than stock, but the height is limited by the boot. Any taller than stock and the boot gets yanked out when I tried to go into 5th. Adjusting the height helped get into gear easier, since it has a little more leverage.
In this picture, you can see that the knob is more to the right in neutral, since the shifter isn't angled towards the driver.
SPEND!!!
The Following 8 Users Say Thank You to mazdaspeedmyk For This Useful Post:
3starmagnum (04-14-2014), Cujo (04-17-2014), dan7225 (04-18-2014), Easter Bunny (04-14-2014), jeopardy98 (04-15-2014), SpencerC (04-18-2014), VRM_MS3 (04-14-2014), WetzMS3 (04-15-2014)
 Old 04-14-2014, 11:57 AM   #92
Cujo's Avatar
Posts: 1,192   (View Stats)
Groaned at 6 Times in 4 Posts
The more I see it the more tempted I am to get one.....
2012 Mazdaspeed3 Black Mica
 Old 04-14-2014, 01:29 PM   #93
iammike's Avatar
Worth it to me. Shifts smoother and feels better than the SSP. Only possible downside IMHO is that it moves the shifter to the right.
Mike
The Following User Says Thank You to iammike For This Useful Post:
himurax13 (04-29-2014)
 Old 04-14-2014, 02:02 PM   #94
Cujo's Avatar
I wonder how many they have left....
 Old 04-14-2014, 03:09 PM   #95
Are you running it with a SSP? I don't want to have to take mine out, but the 1,3, and 5 throws are so short, I almost feel like I should.
 Old 04-14-2014, 04:20 PM   #96
rolanblack's Avatar
Posts: 2,110   (View Stats)
Shifter has a tilt to the right... just like me. must buy SST meow!
The Following User Says Thank You to rolanblack For This Useful Post:
btstarcher (04-19-2014)
 Old 04-14-2014, 06:59 PM   #97
iammike's Avatar
Took the SSP and the lighter counter weight out and put the OEM ones back on.
Mike
The Following 2 Users Say Thank You to iammike For This Useful Post:
himurax13 (04-29-2014), mazdaspeedmyk (04-15-2014)
 Old 04-15-2014, 10:26 AM   #98
Has @CorkSport; or @Spencer@CorkSport; provided any new info or solutions to the issues the 10-11 STS have been experiencing?
 Old 04-15-2014, 02:50 PM   #99
England15j's Avatar
Quoted email I received from Corksport
"The shifter will end up hitting the plastic for your Shift boot. We are making a quick revision and should be able to get it to you soon. Stay tuned for more info on doing a replacement or return."
The Following User Says Thank You to England15j For This Useful Post:
 Old 04-15-2014, 03:28 PM   #100
Chron's Avatar
Did they specify if this was just for the 2010-2011 vehicles?
CorkSport Whore
Stratified Tuned
 Old 04-15-2014, 04:49 PM   #101
England15j's Avatar
Default Product Release: CorkSport Adjustable Shortshifter ? Mazdaspeed 3
Yes it's a 10-11 only issue
 Old 04-15-2014, 05:11 PM   #102
Blkpearl's Avatar
For those that have it how much of a difference is it really from say corksports short shifter plate n bushing combo? Is there that much difference to justify getting this n selling the current setup?
 Old 04-15-2014, 06:03 PM   #103
iammike's Avatar
Shifts smoother than the SSP. Height adjustable unlike SSP. I feel like I've said this before.
Mike
 Old 04-15-2014, 06:26 PM   #104
Blkpearl's Avatar
I saw u said it was smoother just asking for others. Not like you can make much $ off the ssp.
 Old 04-16-2014, 12:16 AM   #105
Polaren's Avatar
That's not terrible, wanted to change the 2011 center piece anyway to the black 2012 with silver trim.
I assume you can probably just swap out the boot and plastic piece there anyway.
 Old 04-16-2014, 01:08 PM   #106
ABOSWORTH's Avatar
Posts: 467   (View Stats)
I don't like how it's angled to the right when in neutral. I won't buy this piece.
Current Mods
 Old 04-16-2014, 01:43 PM   #107
Chron's Avatar
The shifter isnt angled to the right... It's still straight up/down in neutral, it's just located slightly right of stock position because the Corksport shifter does not have the same shaft bend that oem has.
CorkSport Whore
Stratified Tuned
 Old 04-16-2014, 02:03 PM   #108
JgamB's Avatar
Posts: 2,566   (View Stats)
I flopped Teddy's knob around at ENM - the move to the right didn't bother me at all (could hardly tell) and it felt very concise (granted while parked). If I weren't already happy with my Damond SSP I'd be getting one. For extra particular people this will probably give you the options you want.
 Old 04-16-2014, 02:27 PM   #109
ABOSWORTH's Avatar
Perhaps I worded it wrong. I can see from the pics that the unit isn't actually angled. I just don't like how it sits further to the right in neutral.
Current Mods
 Old 04-16-2014, 03:56 PM   #110
darthxar's Avatar
Posts: 560   (View Stats)
Yeah the shift over to the right is the only thing holding me back on this. My arms are kind of short
Double tappin' the Moto
2013 VRM MS3
 Old 04-18-2014, 02:52 PM   #111
SpencerC's Avatar
Posts: 2,159   (View Stats)
This is correct. It is a 2010-2011 problem only. If you have changed your center console to the black console from a 2012-2013 it will work fine. I don't believe you can swap just the shift boot and plastic since it won't clip in together. Should have the revision in about a month.
Easter Bunny (04-18-2014), himurax13 (04-18-2014)
 Old 04-18-2014, 02:58 PM   #112
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
If you can manage to get a center console and shift boot bracket from a 2012-2013 Manual regular 3 or a Skyactive, that will work too.
Pickles Tune in progress
mazdaspeedmyk (04-19-2014)
 Old 04-18-2014, 07:05 PM   #113
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
I will test gen 1 right now.
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 04-18-2014, 07:15 PM   #114
Someone else is releasing one for the genjuan soon... Wish CS would release theirs soon
 Old 04-19-2014, 02:39 AM   #115
Default Product Release: CorkSport Adjustable Shortshifter For Mazdaspeed 3
I checked under there today and the clearance between the adjustable shift plate and the plastic trim of the boot is less than a finger's width. Thanks to @I am a banana; for the trim piece off his old Skyactiv.
The Following 2 Users Say Thank You to mazdaspeedmyk For This Useful Post:
himurax13 (04-19-2014), I am a banana (04-27-2014)
 Old 04-21-2014, 04:33 PM   #116
smr87's Avatar
Posts: 1,288   (View Stats)
smr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the world
Installed mine today. A few observations:
Not that it was a huge deal, but a lock ring on the bottom of the shifter shaft or a keyed shaft with a stop pin would be nice so you dont pull the assembly apart and have the detent spring shoot out while adjusting the height.
Other than having to come up with a little ingenuity to get the 3 tabs engaged simultaneously to disassemble the stock setup by myself the install was a breeze.
I have mine set on the shortest throw with the height almost at the max. I removed the collar from the shift boot, with the shifter extended this far it pulls the boot taught in 5th and 6th, I didnt want it pulling out. I need to come up with a solution to improve the look of the boot without the collar.
1999 Cosmos M3
turning bits and more better suck, squish, bang, and blow
FREEK'D 2012 Liquid Silver Genpu-sold
We were young, and we were fearless and, after all, nobody had ever told us young engineers that we couldn't successfully land humans on another planet. So we did it.
smr87 is offline   Reply With Quote
 Old 04-21-2014, 11:15 PM   #117
himurax13's Avatar
Groans: 255
Well I noticed that the fingers that holds the ball at the bottom flex quite a bit. Some sort of insert could be installed under the steel ring that is screwed down. It could eliminate the remaining slop.
Sent from Stockish Pu
littleloogy (04-21-2014)
 Old 04-29-2014, 01:01 PM   #118
Ace
Ace's Avatar
Posts: 79   (View Stats)
Ace is a glorious beacon of lightAce is a glorious beacon of lightAce is a glorious beacon of lightAce is a glorious beacon of lightAce is a glorious beacon of lightAce is a glorious beacon of light
Just ordered one! Thanks to everyone who posted their reviews/installs.
Hopefully, it'll get here before the weekend.
2012 Black Mica MS3
AFE Dry Panel Filter - CP-E S2 RMM - JBR SSP - about to be replaced by the CS SS
Corksport LEDs - Red Chicco Baby Seat
2013 Black Mica CX-5
Stock
Ace is offline   Reply With Quote
 Old 04-30-2014, 04:35 AM   #119
shaneski's Avatar
Posts: 506   (View Stats)
@corksport wil this work on right hand drive models, the JBR gen1 states there's wont..not sure if the Gen2s around the world share the same bits for gear shift bits.
 Old 04-30-2014, 03:40 PM   #120
SpencerC's Avatar
I chatted with our engineer. His answer was yes it will work.
shaneski (05-01-2014)
Product Release!! CorkSport Adjustable Shocks and Struts for Mazdapeed 3 and Mazda 3 CorkSport CorkSport 248 07-24-2015 12:35 PM
Product Release!! CorkSport Adjustable Shocks and Struts for Mazdapeed 3 and Mazda 3 Trey-Z CorkSport 3 11-26-2013 10:41 AM
Product Release! CorkSport Adjustable Rear Camber Arms CorkSport CorkSport 15 07-31-2012 12:30 PM
Page generated in 0.57456 seconds with 40 queries
