 Old 12-12-2011, 09:30 AM   #1
CorkSport's Avatar
Posts: 3,416   (View Stats)
Default Product Release! CorkSport LED Underhood Lighting Kit
CorkSport is pleased to announce the addition of a new Mazda Underhood LED lighting kit to its list of enhanced lighting options for Mazda and Mazdaspeed vehicles. This brand new accessory builds on the success of CorkSport’s line of LED light kits for Mazda and Mazdaspeed vehicles by adding a lighting kit that will cast [...]
littleloogy (11-29-2013), Mase (12-12-2011), MGM_GT3 (12-12-2011), Raider (12-12-2011)
 Old 12-12-2011, 09:33 AM   #2
Mase's Avatar
Posts: 1,282   (View Stats)
Mase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the world
Groans: 143
Groaned at 14 Times in 14 Posts
Hmmmm....interesting....Like a built in drop light. I like it
Trying to download install instructions to see how much wiring is required...No pagey:
http://support.corksport.com/index.p...=354&nav=0,774
Mase is offline   Reply With Quote
 Old 12-12-2011, 10:01 AM   #3
I need this for my 1st Gen!
 Old 12-12-2011, 11:26 AM   #4
Poohster's Avatar
Posts: 353   (View Stats)
Poohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the world
Very interested for a MS6 installation.
06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP
RPM: Sport Springs, Shark Fin, LED side markers
CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount
Poohster is offline   Reply With Quote
 Old 12-12-2011, 11:39 AM   #5
not interested unless it is neon blue.. lol
 Old 12-12-2011, 02:13 PM   #6
CorkSport's Avatar
Installation Instructions - CorkSport Underhood LED Light Kit - Knowledgebase & Support Center
They are working on a revision. They will be up a bit later.
-Derrick
WWW.CORKSPORT.COM
Mase (12-12-2011)
 Old 12-12-2011, 02:16 PM   #7
Mase's Avatar
Groans: 143
-Derrick
Nice. Thanks. Any deals on buying both LED kits at once? ^^
 Old 12-13-2011, 02:46 PM   #8
CorkSport's Avatar
There are no specials running for both LED lights kits at the same time.
-Derrick
WWW.CORKSPORT.COM
 Old 11-12-2013, 09:49 PM   #9
sbrunnings's Avatar
Posts: 10   (View Stats)
sbrunnings has a spectacular aura aboutsbrunnings has a spectacular aura about
Did you ever create install instructions for gen one?
2009 MazdaSpeed3 - Cobb APv3 Stage 1 and RMM - ETS TMIC - CorkSport SRI, TIH, Cold Air Box, End Links, LED Interior/Fog/Underhood Kit - Eibach Pro Springs and Adjustable Cambers - Koni Yellow Sports - AutoTech HPFP - Stop Tech Rotors - NGK Iridium IX Spark Plugs
sbrunnings is offline   Reply With Quote
 Old 11-17-2013, 10:44 PM   #10
The Nut's Avatar
Posts: 1,571   (View Stats)
Blog says: This user friendly accessory is priced at just $35.00 and takes only 20 minutes to install. A kit can be purchased today from CorkSport.com at Underhood LED Light | Mazda LED Underhood Lighting Strip
Click that link to your ordering page, and the price goes up $5. Um...??
2012 BLACK MICA w/TECH
91 & Corn diagnostics by:
 Old 11-29-2013, 10:03 PM   #11
sbrunnings's Avatar
Super easy install, despite lacking genWON specific instructions. You guys could have done a lot better with a stiffer wire gauge, made the wire black instead of needing a black wire condom, and included notes for ALL parts in your install. Not super impressed CorkSport
 Old 11-30-2013, 12:42 AM   #12
The Nut's Avatar
Gen Pu install here so no problems with that. One suggestions though...
-Little squishy pad that goes on under hood where pin contacts is too soft. Within a few hrs, the pin has permanently pushed indentation in it and light stays on even with hood closed. (Working on gerry rigging a fix right now.
 Old 11-30-2013, 04:29 AM   #13
Shoulda read the listing before purchase. Says only genpu instructions included.
SofaKingAwesome (11-30-2013)
CorkSport Product Release - Mazdaspeed 6 Mud Flaps! Gwynne CorkSport 0 08-30-2011 11:23 AM
CorkSport Product Release! ? Introducing the New CorkSport Radiator Cap CorkSport CorkSport 0 08-05-2011 06:30 PM
CorkSport Product Release! ? CorkSport Mazdaspeed 3 Lowering Springs Now Available CorkSport CorkSport 0 08-05-2011 06:30 PM
Page generated in 0.33954 seconds with 27 queries
