Like Tree14Likes
 Old 08-18-2014, 10:32 PM   #81
Fjager's Avatar
Posts: 246   (View Stats)
Fjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the world
Did some driving today in the high desert, ambient was at 97, ac on 67, coolant temps hovered around 185-195 in stop go and Highway, went through a drive through and let it sit ac off for a while, hit 212 and the fan kicked on like it was supposed to, brought temps down to 207, then turned ac on to 72 and they dropped a bit more to around 200, so far so good as temps go. Hit on some boost on the highway and it only raised temps slightly and they came back down fast after I let off the throttle.
Initial impressions are good, before with stock radiator after I hit 200 it wouldn't ever go back below it without hitting the heater, now ac running and it drops back to the 190s like a champ. Gonna see how hot the afternoon is tomorrow and try to run in over 100 ambient temps.
2013 White Pearl MS3
JBR SSP/bushings/RMM/EGR delete
Corksport 3ID Intake/Radiator
Cobb APV3/AT Internals
Grimmspeed 3 port EBCS/Matt Damond CC
FMIC W/DIY Sprayer
CPE DP
Fjager is offline   Reply With Quote
The Following 6 Users Say Thank You to Fjager For This Useful Post:
ABolewski (08-19-2014), AwAfrican (05-13-2015), Code Monkey (08-19-2014), JSmith (04-29-2015), Mauro_Penguin (08-19-2014), SpencerC (08-19-2014)
 Old 08-18-2014, 10:37 PM   #82
Yatta's Avatar
Posts: 1,862   (View Stats)
I still want to see one of these at half height.... if you could get the same coolant volume as stock with a thicker core down low, the rest of the space could house a FMIC.
The Following 2 Users Say Thank You to Yatta For This Useful Post:
dan7225 (06-17-2015), Easter Bunny (08-19-2014)
 Old 08-19-2014, 06:01 AM   #83
Fjager's Avatar
I'd you don't mind taking out the ac system, sure that could work. Just not very well, the purpose of having a big surface area is to dissipate heat better, a thicker core won't do as well as a taller/wider one.
FMIC W/DIY Sprayer
CPE DP
The Following User Says Thank You to Fjager For This Useful Post:
magicka (08-19-2014)
 Old 08-19-2014, 11:27 AM   #84
Yatta's Avatar
I don't disagree with you on the importance of surface area but the parts in play are a little more complicated, most (all) current FMIC's cool charge air at the expense of engine cooling air flow to the radiator; this is one of the main reasons I am still TMIC.
What I am suggesting is that you take a portion of the space where the stock radiator is and place an IC there, this would require a shorter (height or width) core but still likely big enough to improve on stock for both; it would give you a wider IC core in the area Mazda designed to get good air flow, the same area serviced by the electric fan, which might be manipulated to curb heat-soak, I don't believe you should have to remove the AC core for this; though I did use an AC core for a water to air cooler on my last project car.....
It could be 1/3, or 1/2 of the space and I might sound crazy but it would keep things simple, and the intake path as short as possible.
Getting this back on topic though, more cooling is good for the folks tracking these cars and corksport seems to be addressing areas where they could improve for track use... (brakes, cooling) makes me wonder what is next....
 Old 08-19-2014, 11:46 AM   #85
Mauro_Penguin likes this.
Easter Bunny (08-19-2014), Yatta (08-19-2014)
 Old 08-19-2014, 11:53 AM   #86
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
Would
tapped by satan
Mods: stock
 Old 08-19-2014, 12:18 PM   #87
someone needs to read more about sucker cars
 Old 08-19-2014, 12:32 PM   #88
Yatta's Avatar
Why not Lexan ? I would do this; less noise more race car...
 Old 08-19-2014, 12:51 PM   #89
Fjager's Avatar
The ac core is directly in front of the radiator, it's also the same size (HxW). If you want to make a short deep intercooler it would have to go through the ac core, same goes for the radiator.
I do agree that it's a good idea, just not practical for most people. Definitely something a dedicated race car could use.
FMIC W/DIY Sprayer
CPE DP
 Old 05-10-2015, 09:36 PM   #90
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
Just an fyi for anyone else looking at this. It does not fit with the GenPu Cobb FMIC kit.
Hotside pipe clearance goes from finger depth between pipe and radiator shroud to none with the other side touching the pump.
The Following User Says Thank You to JSmith For This Useful Post:
Mauro_Penguin (05-12-2015)
 Old 05-11-2015, 08:51 PM   #91
Fjager's Avatar
Damn, the water pump doesn't clear on the hot side? No combination of angling the piping worked to give you some space?
FMIC W/DIY Sprayer
CPE DP
 Old 05-11-2015, 09:17 PM   #92
JSmith's Avatar
Groans: 106
Its the ac compressor on the engine side and the shroud on the other. The Cobb pipe is directly touching the radiator shroud when its (where it should be) on the intake mount point. Taking it off the mount and fishing it around did not prove fruitful either.
Totally not blaming Corksport for this. Just getting info out there.
 Old 06-16-2015, 12:16 PM   #93
Jkelley's Avatar
Posts: 218   (View Stats)
Jkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the world
so about that gen 1 option tho?
2008 Mazda Mazdaspeed3 GT (True Red) SOLD
~Mods: ATP GTX3071r IWG, JBR Tru 3.5" WP, UR V2 3" catless DP & TP, Tr8+JBR FMIC, Turbosmart BPV, CP-e HPFP, NGK 6510, Bosch 3bar MAP, Cobb 3-port EBCS, PERM PCV Plate, Damond OCC (1sealed, 1 VTA), Kozmic 1°/Damond 2° EGR Delete, Corksport seals, CP-e RMM 75A, JBR side MM 80A, Cobb AP V2, spin-on oil conversion, KSport Coilovers, SPC Performance Camber Arms, JBR IM/TB TIG, SURE Anchors
~~332whp @5300rpm / 354wtq @4800rpm @ 21psi on 91oct FREEKTUNED
~~380whp @6500rpm / 367wtq @4800rpm @ 20psi on e33 FREEKTUNED
2007 Mazda CX-7 (Burgundy Wine) SOLD
Jkelley is offline   Reply With Quote
 Old 06-18-2015, 12:01 PM   #94
senor blanco ms3's Avatar
Posts: 1,353   (View Stats)
senor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the world
Koyorad Racing Radiator V Series Core Mazda 3 Mazdaspeed 3 2007-2009
2008.5 Crystal White Pearl MS3
A lot of mods
Check out my big turbo build!
senor blanco ms3 is offline   Reply With Quote
Product Release! CorkSport Gen 1 Mazdaspeed 3 FMIC Radiator Shroud CorkSport CorkSport 16 08-25-2013 07:33 PM
CorkSport Product Release! ? Introducing the New CorkSport Radiator Cap CorkSport CorkSport 0 08-05-2011 06:30 PM
CorkSport Product Release! ? CorkSport Mazdaspeed 3 Lowering Springs Now Available CorkSport CorkSport 0 08-05-2011 06:30 PM
Page generated in 0.36365 seconds with 28 queries
