 Old 11-14-2011, 12:28 PM   #1
Gwynne's Avatar
Posts: 288   (View Stats)
Gwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the world
Default Product Release! - CorkSport Mazdaspeed 3 Front End Links
CorkSport is pleased to announce the addition of the Mazdaspeed 3 Adjustable Front End Links to our growing list of suspension upgrades developed to enhance your Mazda’s performance.
The sway bar link attaches to the suspension to promote stabilizing of a vehicle in a turn. By replacing your OEM end links with CorkSport adjustable front end links, you will be able to turn your stabilizer bar into a tunable component in your Mazdaspeed 3 and see immediate improvements in suspension compliance and a dramatic increase in turn-in speed and stability on the highway.
The CorkSport Adjustable Mazdaspeed 3 Front End Links are made from 260mm anodized aluminum that has been force analysis tested to hold up to 2000lbs of tensile force. The end links use 5/8” hex stock, M10x1.5 ball joints and jam nuts to eliminate binding and allow for smooth load transition.
Made to fit OEM and aftermarket front sway bars, the CorkSport Mazdaspeed 3 Front Adjustable End Links allows customers to tune any sway bar and remove the preload commonly associated with the suspension.
“Adjustable end links will allow you to properly balance and tune your suspension to give you the best setup possible” Said CorkSport Engineer, Andrew Gilbert, “Our end links will reduce link flex and fatigue, increase sway bar effectiveness and allow for corner balancing suspension.”
The CorkSport adjustable front end links come in a black anodized finish and include an etched CorkSport logo for a custom and long lasting finish.
The CorkSport Mazdaspeed 3 Front End Links can be purchased for the competitive price of $109.00 making this an easy to install and affordable upgrade for your vehicle.
For more information: Mazdaspeed 3 Front Adjustable Swaybar End Links CorkSport
Gwynne
CorkSport Peformance
www.corksport.com
Gwynne is offline   Reply With Quote
 Old 11-14-2011, 12:35 PM   #2
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
It looks from the picture that the end link length can only be extended, not retracted compared to OE. If so, these won't be useful for those like me running KW coilovers, as we need shorter end links.
Tapadatass
The Following 5 Users Say Thank You to silvapain For This Useful Post:
helmetface (03-05-2012), Lex (11-14-2011), Post pwned (11-14-2011), super_pablo_ (11-14-2011), wolly6973 (11-14-2011)
 Old 11-14-2011, 12:44 PM   #3
Please provide the range compared to stock how much your endlinks can be shortened and how much they can be lengthened.
Post pwned (11-14-2011), silvapain (11-14-2011), wolly6973 (11-14-2011)
 Old 11-14-2011, 01:21 PM   #4
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
I'd like to poke you with my end link.
CamSpeed360 (10-24-2012), JohnMS3 (11-16-2011)
 Old 11-14-2011, 01:25 PM   #5
Seaton's Avatar
Posts: 233   (View Stats)
Seaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the world
Im after some of these, Need the specs as stated above first though,
thanks.
Seaton is offline   Reply With Quote
 Old 11-14-2011, 02:08 PM   #6
Gwynne's Avatar
The end links have about 12mm of adjustability. They cannot be shortened in comparison with the OEM end links, only lengthened.
Gwynne
www.corksport.com
Last edited by Gwynne; 11-17-2011 at 10:47 AM. Reason: Misprint 12mm of adjustablility NOT 12cm
 Old 11-14-2011, 02:11 PM   #7
super_pablo_'s Avatar
Posts: 1,648   (View Stats)
sadface. KW coilover owner here.
The Following User Says Thank You to super_pablo_ For This Useful Post:
 Old 11-14-2011, 02:34 PM   #8
x2. I was hoping to drop the FSD shocks further in the knuckle and needed some shorter ones.
I guess you can always grind off the ends. If they can be lengthened by 12cm, then you have enough threads in there to grind the endlink down but it's not elegant.
Last edited by Lex; 11-14-2011 at 02:34 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-14-2011, 02:40 PM   #9
silvapain's Avatar
Groans: 136
Gwynne - tell the engineer to go back and shorten them to allow us +/- 6 cm of adjustment compared to OEM.
Tapadatass
The Following 8 Users Say Thank You to silvapain For This Useful Post:
Enki (11-14-2011), helmetface (03-05-2012), Mizzle (03-20-2013), rfinkle2 (01-24-2012), SLOWHATCH (10-23-2012), super_pablo_ (11-14-2011), TexasSpeed3 (11-14-2011), wolly6973 (11-14-2011)
 Old 01-23-2012, 07:37 PM   #10
Gwynne's Avatar
Tapadatass
We have revised the end links to allow for +/- .5cm of adjustment compared to stock. Mazdaspeed 3 Front Adjustable Swaybar End Links CorkSport
Gwynne
www.corksport.com
The Following 6 Users Say Thank You to Gwynne For This Useful Post:
helmetface (03-05-2012), rfinkle2 (01-24-2012), silvapain (01-24-2012), super_pablo_ (01-24-2012), Tomas (01-23-2012), wolly6973 (01-24-2012)
 Old 03-05-2012, 04:54 AM   #11
Atomic41's Avatar
Posts: 1,174   (View Stats)
Originally Posted by Gwynne[MENTION=130
CorkSport;1224039]We have revised the end links to allow for +/- .5cm of adjustment compared to stock. Mazdaspeed 3 Front Adjustable Swaybar End Links CorkSport
.5cm or 5cm ?
2008 MAZDASPEED3 Black
Stratified Tuned / Stage 2
 Old 11-14-2011, 02:43 PM   #12
Gwynne's Avatar
I have passed the suggestion along to Andrew for revision consideration. Thank you for your feedback!
Gwynne
www.corksport.com
The Following 8 Users Say Thank You to Gwynne For This Useful Post:
Enki (11-14-2011), helmetface (03-05-2012), Mizzle (03-20-2013), rfinkle2 (01-24-2012), silvapain (11-14-2011), stang9779 (11-20-2011), super_pablo_ (11-14-2011), wolly6973 (11-14-2011)
 Old 11-14-2011, 03:09 PM   #13
aanguia1's Avatar
Posts: 291   (View Stats)
aanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the world
Groaned at 32 Times in 8 Posts
Subbed for shorter endlinks
Sent from my LG-P999 using Tapatalk
aanguia1 is offline   Reply With Quote
 Old 11-14-2011, 06:44 PM   #14
Seaton's Avatar
Yeah, good to see this product but it seems kinda pointless when they can only be adjusted longer. Looks like I'll have to go the Whiteline ones. Sorry guys...
Most people with a lowered car are surely after some shorter ones.
The Following 2 Users Say Thank You to Seaton For This Useful Post:
fishbait (11-17-2011), SLOWHATCH (10-23-2012)
 Old 01-24-2012, 07:58 AM   #15
silvapain's Avatar
Groans: 136
Now that's what I'm talking about!
Tapadatass
Gwynne (01-24-2012), rfinkle2 (01-24-2012)
 Old 03-05-2012, 05:53 AM   #16
Uberfly's Avatar
Posts: 773   (View Stats)
Uberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the world
the link she supplied states the following:
Adjustable: +/- 6mm in adjustable length compared to stock to easily tune the sway bar as part of the suspension system.
2008 MS3 GT - Guardian Angel, Cobb Acessport, hacked up mazda CAI converted to SRI, Turbosmart BPV
Uberfly is offline   Reply With Quote
 Old 10-20-2012, 09:03 PM   #17
Dooby's Avatar
Posts: 42   (View Stats)
Dooby is a name known to allDooby is a name known to allDooby is a name known to allDooby is a name known to allDooby is a name known to allDooby is a name known to all
These endlinks work for MS6 as well?
Dooby is offline   Reply With Quote
 Old 10-24-2012, 01:12 PM   #18
CorkSport's Avatar
Posts: 3,416   (View Stats)
They will not. The MS6 uses a different length end link.
-Derrick
WWW.CORKSPORT.COM
 Old 10-24-2012, 01:34 PM   #19
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
.5cm ? ...
Product Release! CorkSport Mazda 2 Front Sway Bar CorkSport CorkSport 0 11-07-2011 11:00 AM
CorkSport Product Release! ? CorkSport Mazdaspeed 3 Lowering Springs Now Available CorkSport CorkSport 0 08-05-2011 06:30 PM
Page generated in 0.40416 seconds with 31 queries
