Like Tree131Likes
 Old 05-13-2015, 07:03 PM   #41
speedfreak44's Avatar
Posts: 1,391   (View Stats)
Pulled out and reinstalled my oem downpipe in about 6 hours on jack stands from underneath the car but I have been working on hondas nissans and miscellaneous GM products for years so this was really nothing new. What also helps a downpipe mod is doing it before 10k miles are on the car shit comes out much smoother.
In for whenever datalogs are posted
The line up:
 Old 05-13-2015, 07:08 PM   #42
Turbo_Steve's Avatar
Posts: 944   (View Stats)
My downpipe was a 2 hour install.....
Pb Blaster and a GOOD assortment of tools is your friend.
Soon to come.
WHO KNOWS? A.D.D. FTW!
 Old 05-13-2015, 07:09 PM   #43
If only your tuner wasnt a never around, never posting, slacker.
@rfinkle2;
Probably busy with the tuning and work. I'm keeping frequent contact with him by email and message chat. I wanted to be further on in tuning too. My car is just fighting it. As it does everything.
 Old 05-13-2015, 08:06 PM   #44
Oni
Oni's Avatar
Posts: 565   (View Stats)
My DP was super easy... The O2 sensor on the other hand... Mazda decided to cross-thread the stock one
'12 Velocity Red Mica MS3
Cobb AP V3 // Autotech Fuel Pump Internals // HTP 3" // UR Catted V2 DP // UR Resonated TP // UR Resonated CBE // GrimmSpeed EBCS // CP-E TMIC // GFB Respons BPV // JBR Trilogy 88/80/80 // Corksport Hood Struts // Prosport EVO Boost Gauge w/ block8head vent pod // E30 Freektune
Installing Soon : Stratified GA // Bosch 3 Bar Map w/ PNP Harness
Oni is offline   Reply With Quote
 Old 05-13-2015, 08:11 PM   #45
My time was removing the oem one, gutting it, and reinstallig it. That is why it took 6 hours. Oh and a run to harbor freight for the impact extensions that pivot. Those are a must.
The line up:
 Old 05-13-2015, 08:14 PM   #46
My car has the passenger axle pressed into the hub 1/2 thread off. So when I swap axle, hub gets to go too. Same with my passenger brake caliper bracket. That was fun to have overnighted when it stripped out.
If the downpipe nuts did not fight, would have helped. A lot.
 Old 05-13-2015, 08:31 PM   #47
I feel bad for you. Man do you seem to have terrible luck
The line up:
 Old 05-13-2015, 08:45 PM   #48
wdautrem's Avatar
Posts: 159   (View Stats)
wdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the world
Oh wow, that sucks. Did it tear it up or were you able to reuse it?
wdautrem is offline   Reply With Quote
 Old 05-13-2015, 08:52 PM   #49
You did all of the hard shit for swapping the downpipe. Should have done it while you were there.
The Following 5 Users Say Thank You to Easter Bunny For This Useful Post:
aromig (05-13-2015), Awal (05-16-2015), Cyclops (05-14-2015), neganox (05-13-2015), Raider (05-14-2015)
 Old 05-13-2015, 11:55 PM   #50
The Nut's Avatar
Posts: 1,571   (View Stats)
Subbed for logs, VDyno, charts, graphs, and pics of @Raider shirtless. Also banging head into wall for having to pull out of beta test.
2012 BLACK MICA w/TECH
91 & Corn diagnostics by:
 Old 05-14-2015, 01:50 AM   #51
Oni
Oni's Avatar
Nope. Found out right away and tried using more PB blaster and waiting to no avail. Ordered a replacement just in case for take 2. Ended up needing it. Screwed the threads up pretty bad getting it out.
 Old 05-14-2015, 04:50 AM   #52
nas711's Avatar
Posts: 71   (View Stats)
nas711 is just really nicenas711 is just really nicenas711 is just really nicenas711 is just really nice
Groaned at 30 Times in 8 Posts
Nice write up! I just purchased the corksport turbo a few hours ago, but thank god I am running an after market DP (COBB) haha. All I want is to bolt and tune!
nas711 is offline   Reply With Quote
 Old 05-14-2015, 05:33 AM   #53
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Thanks for posting. Can't wait to see some logs and results. I'm glad I've decided to do the DP first before any turbo upgrades.
2007 Mazdaspeed3 GT
 Old 05-14-2015, 06:32 AM   #54
Updated OP with before and after 3rd gear runs for comparison. Again, I have OEM 2 port EBCS issues unrelated to the turbo. I just need a better solution, and @jdmage_mx5; has been awesome to help speed things up.
Awal (05-16-2015), btstarcher (05-16-2015), jdmage_mx5 (05-14-2015)
 Old 05-14-2015, 06:39 AM   #55
Just saw this thread linked to Australia and what looks like Russia. Cool.
Awal (05-16-2015), littleloogy (05-14-2015), SarcasticOne (05-16-2015)
 Old 05-14-2015, 06:40 AM   #56
mjblank425's Avatar
Posts: 44   (View Stats)
mjblank425 has much to be proud ofmjblank425 has much to be proud ofmjblank425 has much to be proud ofmjblank425 has much to be proud ofmjblank425 has much to be proud ofmjblank425 has much to be proud ofmjblank425 has much to be proud ofmjblank425 has much to be proud of
Groaned at 7 Times in 1 Post
Thanks for the write up! Ordered mine this morning and have DP waiting. Probably going to do that at the same time. Your issues with the OEM BCS...would you recommend just going head and getting the 3 port EBCS to avoid any future tuning issues?
mjblank425 is offline   Reply With Quote
 Old 05-14-2015, 06:44 AM   #57
Cut the OEM downpipe out, and scrap it. Destroy it's every being. If I could see it melted down, I would be all about that too.
And ABSOLUTELY get a 3 port (need to tell your tuner too!) to not be like me. They had another near stock like mine test fine with OEM. But they are not me. They do not have the evil car. If I had a flat billed had on sideways, and was running 45 degrees of camber, I would give my car a name. It would be Christine, like the movie.
CorkSport, mjblank425 and Awal like this.
aromig (05-14-2015), Awal (05-16-2015), Rich990 (05-20-2015)
 Old 05-14-2015, 06:45 AM   #58
Justin@Freektune's Avatar
Posts: 954   (View Stats)
Raider what is going on with the stock 2port? Looks like you are holding boost pretty easily with 30% wgdc and maf volt is higher than it was on stock turbo. Looks like you are already at 4.7 maf volts at low boost with that CS turbo, which is moving some air
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
rfinkle2 (05-14-2015)
 Old 05-14-2015, 07:00 AM   #59
We are just not able to get the boost we are mapped for.
 Old 05-14-2015, 07:16 AM   #60
MD1032's Avatar
Groans: 143
@Raider; did you keep the stock BCS routing or did you interrupt the 1/4" nipple side of the WGA and cap the 1/8" side like some people recommend doing? That is how mine is routed.
2007 Mazdaspeed3 GT
 Old 05-14-2015, 07:18 AM   #61
100% stock.
 Old 05-14-2015, 08:43 AM   #62
Of course, but I just checked my garage and there is not one in there.
Easter Bunny (05-14-2015)
 Old 05-14-2015, 08:55 AM   #63
At least beat the media out of the OEm
 Old 05-14-2015, 08:57 AM   #64
Come beat my meatyuh.
 Old 05-14-2015, 09:01 AM   #65
Feline Führer
neganox's Avatar
Posts: 1,790   (View Stats)
@CorkSport; any chance of offering this terba with a single port actuator? When I initially looked at the turbo I went lmaooo that actuator is beefy as fuck!
 Old 05-14-2015, 10:16 AM   #66
CorkSport's Avatar
Posts: 3,416   (View Stats)
We do not have any plans to do that.
Derrick
WWW.CORKSPORT.COM
 Old 05-14-2015, 10:28 AM   #67
Feline Führer
neganox's Avatar
Daww.
CorkSport (05-14-2015), Easter Bunny (05-14-2015), monkey.bones.007 (05-14-2015), Raider (05-14-2015)
 Old 05-14-2015, 11:21 AM   #68
ihasmazda's Avatar
Posts: 1,011   (View Stats)
Someone needs to create a product that we can pour into our oil that will ONLY damage the stock K04 so that we have an excuse to upgrade. Oh wait, isn't that called Mobil 1?
2007 Mazdaspeed 6 GT
2003 Ford Ranger XLT
 Old 05-14-2015, 11:25 AM   #69
lpugfan2004's Avatar
Posts: 771   (View Stats)
lpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the world
Or go catless, its only a matter of time
2012 Velocity Red Mazdaspeed3
- CP-E Stage 1 RMM - Autotech HPFP Internals - COBB AP v3 - Corksport 3inch Intake - Corksport Turbo - Corksport BPV -
- JBR Shift Plate & Shift Weight - JBR Solid Bushings - cp-e Catted TBE - NGK 1 step colder plugs - COBB 3 Port EBCS -
- ETS TMIC - Michelin Pilot Super Sport 235/40-18 - JBR OCC Stage 2 - JBR EGR Delete - CorkSport Boost Tubes -
- JBR IM and TB gaskets w/ coolant bypass - Damond Motosports PMM - Corksport PMM Bushing Insert -
Tune in progress
lpugfan2004 is offline   Reply With Quote
The Following User Says Thank You to lpugfan2004 For This Useful Post:
JgamB (05-14-2015)
 Old 05-14-2015, 11:45 AM   #70
klam5000's Avatar
Posts: 18   (View Stats)
klam5000 is a splendid one to beholdklam5000 is a splendid one to beholdklam5000 is a splendid one to beholdklam5000 is a splendid one to beholdklam5000 is a splendid one to beholdklam5000 is a splendid one to beholdklam5000 is a splendid one to behold
I would take it to my exhaust shop to deal with the stupid downpipe removal
Sorry for off topic, but what exhaust shop do you use?
klam5000 is offline   Reply With Quote
 Old 05-14-2015, 11:48 AM   #71
S&S Custom Exhaust
Address: 3210 Forest Blvd, Jacksonville, FL 32246
Phone: (904) 232-8495
Was about $150 last I checked.
klam5000 (05-14-2015)
 Old 05-14-2015, 01:07 PM   #72
I thought you would never ask.
Raider (05-14-2015)
 Old 05-14-2015, 03:04 PM   #73
El Beaner's Avatar
Posts: 4,262   (View Stats)
Definitely going to be watching this thread.
SOLD 2012 LSM Tech - 11/17/17
 Old 05-14-2015, 03:34 PM   #74
aromig's Avatar
Posts: 289   (View Stats)
aromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the world
Once you do swap out the stock dp, go Office Space on that fucker with neganox and Yanahdi. Might not do much to it, but would be oh-so-satisfying. Pics too. Damn it feels good to be a gangsta.
"I apologize for nothing!" - Hedonismbot
aromig is offline   Reply With Quote
The Following 4 Users Say Thank You to aromig For This Useful Post:
Awal (05-16-2015), mjblank425 (05-15-2015), Raider (05-15-2015), Yanahdi (05-15-2015)
 Old 05-15-2015, 11:56 PM   #75
nas711's Avatar
Question for Raider and others who have this turbo. I have a COBB SRI intake and wonder if this will play nice with the corksport turbo (size wise)? I am only tuning it to 350HP ...so MAF should be ok, just talking about dimensions. Thanks
 Old 05-16-2015, 01:49 AM   #76
Kor3y101's Avatar
Posts: 193   (View Stats)
Kor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond repute
The corksport puppy is stock inlet size. As it is a bolt on design, even the stock intake will fit ( though definitely not recommended) so if you have the stage 2 or stage 1 corksport intake, it will work fine
'12 Black Speed 3
CS RMM -~- CS SSP & Gearbox Bushings -~- CS OCC -~- CS LED light kit -~- CS Front and Rear Sway Bar -~- UnPlugged EGR Delete -~- CS Hood Struts -~- DVC30 WMI -~- JBR 3" Widepath -~- CS HPFP -~- GrimmSpeed 3 Port -~- HKS SSQV -~- CS TMIC -~- 500W Memphis Sub/Custom Wheel Well Box -~- 3" Xforce TBE -~- RayD Tuned
Kor3y101 is offline   Reply With Quote
 Old 05-16-2015, 02:00 AM   #77
nas711's Avatar
Thanks alot for the information. As I said I have a COBB intake and not really interested in replacing it as I like the design. The COBB one looks the same size as the CS stage 2 (easily bigger than stage 1)....but not sure of size.
 Old 05-16-2015, 02:11 AM   #78
Kor3y101's Avatar
Oh sorry, I misread, that's what I get for being at the gym and on the forum haha. My apologies!
The Cobb SRI uses the same 2" ID diameter as stock standard, so there won't be any size issues. It's only when you go 3" or bigger, even then, it's just a matter of using a silicone reducer. So sizing won't be a problem
'12 Black Speed 3
 Old 05-16-2015, 02:40 AM   #79
nas711's Avatar
Ahh thank you again! Only thing tho...if COBB is 2" ID diameter, will I have MAF problems then as not 3"?
 Old 05-16-2015, 02:56 AM   #80
Kor3y101's Avatar
I'm sorry, I don't quite understand where your going with that. The Cobb SRI you have currently installed will fit the Corksport turbo, it is also the same size as a stock intake, so as far as MAF's go, there is no issue. If you do decide to upgrade to a 3", a new MAF housing comes with it, you will then need to do a MAF calibration but once that is done, there are no problems again.
So as far as your current intake is concerned, it will fit without problems.
'12 Black Speed 3
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f500/raider-s-beta-test-corksport-turbo-188391/
?????????? - ??????? (??????????, ???????, ??????) This thread Refback 05-14-2015 01:47 AM
I know you guys like fast things...Sneek Peak - Page 2 This thread Refback 05-13-2015 09:44 PM
AccessPORT and AccessTUNER Beta Support for World Market Turbo Mazda3/6 + New PURE Boost OTS Maps! Cobb Tuning 2010 MS3 - ECU Computer Tuning 183 11-10-2012 03:32 PM
AccessPORT and AccessTUNER Beta Support for World Market Turbo Mazda3/6 + New PURE Boost OTS Maps! Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 32 10-14-2012 09:01 AM
Windows Vista/XP 64 Bit/MAC OSX Users Beta Test Haltech MazdaSpeed 3/6 - ECU Computer Tuning 49 02-02-2009 10:07 AM
Go get your 103 beta map to test.. brecker
Cobb Access Port/Maps
199 12-11-2008 09:30 PM
Page generated in 0.59050 seconds with 39 queries
