  • 1 Post By Gr8Speed
 Old 03-04-2014, 03:56 AM   #1
sawdust777's Avatar
Posts: 11   (View Stats)
sawdust777 is a glorious beacon of lightsawdust777 is a glorious beacon of lightsawdust777 is a glorious beacon of lightsawdust777 is a glorious beacon of lightsawdust777 is a glorious beacon of light
Groaned at 8 Times in 2 Posts
Default Single piece Spring Retainer Tappet ?
I just got the internals and found the tappet and spring retainer to be one solid piece. The directions and pictures have not been changed/updated and they still included the installation pipe and tool with the kit. Of course I found no use for them. Am I missing something ? or did CS just slip an upgrade in there without bragging about it ?
sawdust777 is offline   Reply With Quote
The Following User Says Thank You to sawdust777 For This Useful Post:
Murcielago311 (03-04-2014)
The Following User Says NO Thank You to sawdust777 For This Un-useful Post:
Agent_Orange (03-04-2014)
 Old 03-04-2014, 09:32 AM   #2
SpencerC's Avatar
Posts: 2,159   (View Stats)
We slipped an upgrade in without mentioning it.... not really an upgrade just a simpler install. You should slide the piston into the retainer and tappet, then set it in the tool and still pop it further into place until you cant remove the piston from the retainer and tappet.
I'll try and see if we can update the install instructions.
 Old 03-05-2014, 06:30 AM   #3
sawdust777's Avatar
Well that's not good because its already installed. It was under good tension with the spring and seemed secure. I figure the cam would do the tapping for me at this point and drive it the rest of the way down ...right ? or should I pull it out and make sure ?
 Old 03-05-2014, 07:50 AM   #4
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Well it's only your fueling system, so I'd just guess it's fine and move on. No potential for ZZB or anything.
trancehead likes this.
He Hate Me (03-05-2014), trancehead (03-05-2014)
 Old 03-06-2014, 02:11 PM   #5
SpencerC's Avatar
The cam will do the job for you. We already chatted about this, but I want others to see that it shouldn't be an issue if they did the same thing. The pressure from inside the pump will seal it for you.
daytonabluez05 (10-19-2014)
 Old 03-06-2014, 02:24 PM   #6
Johnasaurus's Avatar
Posts: 359   (View Stats)
Johnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the world
OP got lucky! This could have ruined your day.
2012 black mica. Totaled 10/31/14.
Johnasaurus is offline   Reply With Quote
Valve Tappet Clearance Excel Spreadsheet silvapain MazdaSpeed 3 - Engine, Transmission & Driveline 3 05-11-2018 01:32 PM
Retainer Corndogler MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 12 12-09-2009 09:51 PM
Page generated in 0.27246 seconds with 23 queries
