Like Tree642Likes
 Old 10-16-2016, 11:28 AM   #1841
Flying_Avocado's Avatar
Posts: 4   (View Stats)
Flying_Avocado is an unknown quantity at this point
I have the CS turbo and the Stratified GA V3. I used a bosch 3 bar map sensor with a bitwise connector instead of the integrated 4 bar map sensor in the GA. Other wise you have to cut and crimp the signal wire from Map sensor to the GA to use the 4 bar map sensor. I can say I haven't noticed any boost creep in the few months that I've had this system set up.
07 MS6: Cobb AP V3/ CS HPFP Internals/ CS Catted DP/ CS Turbo/ Magnaflow CBE/ CS Stage 2 SRI/ Forge V2 BPV/JBR Trilogy Motor Mounts/ TR6 FMIC/Stratified Guardian Angel V3/ HTP Battery Relocate/Upgraded Rear Diff Mounts/Whiteline RSB
Flying_Avocado is offline   Reply With Quote
 Old 10-16-2016, 11:50 AM   #1842
darthxar's Avatar
Posts: 560   (View Stats)
Have you driven in cold weather with it? I was considering a cork sport turbo and GA V 3 set up until all the boost creep talk started. I experience some subzero super dense air where I'm at, so creep is something I don't need.
2013 VRM MS3
 Old 10-16-2016, 12:21 PM   #1843
I haven't had the chance to test it in temps lower than 40 yet. I live around Chicago.
 Old 10-16-2016, 12:55 PM   #1844
darthxar's Avatar
You'll get that chance soon enough then.
TRBODriver likes this.
2013 VRM MS3
 Old 01-12-2017, 06:44 AM   #1845
GroceryGtr's Avatar
Posts: 472   (View Stats)
anyone have any updates on these. Namely the reliability/creep? Was holding out on the hope they got this fixed or atleast improved in relation to the creep issue.
 Old 01-12-2017, 07:09 AM   #1846
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
I've heard rumors they updated the hotside to resolve the problem. As usual they've chosen to try to keep everything hidden instead of transparent, so nothing is verifiable. There are plenty of other options in this size range of turbo. No need to take a gamble on something this important IMO.
speed3okie likes this.
2007 Mazdaspeed3 GT
 Old 01-16-2017, 03:58 PM   #1847
CorkSport's Avatar
Posts: 3,416   (View Stats)
We have made changes with the turbo. We are not the only company to do so with their turbo products either without announcing it.
We make tweaks an changes with most of our products over time as do other companies. It is just the nature of the business.
-Derrick
WWW.CORKSPORT.COM
zxhoya (03-15-2017)
 Old 01-16-2017, 08:26 PM   #1848
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
I'm curious, to what extent, the negatives would be if you went back to the 12-blade turbine wheel.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 06-03-2017, 04:28 AM   #1849
irissanen's Avatar
Posts: 89   (View Stats)
irissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond repute
Originally Posted by irissanen View Post
Hello,
Can anyone explain what happens when I hit 150 mph? Why am I hitting fuel cut there? Fuel cut is set to 27 psi. Also IDC is lower than with two previous gears so fuel supply shouldn't be an issue. Some AccessTuner feature/issue?
Google docs: https://docs.google.com/spreadsheets...iCMl8/pubhtml#
Update: I was able to figure out the reason with the help of COBB customer support. It seems that WM MS6 has two separate speed limiter parameters. I was using the older Accesstuner Race which showed only the other parameter. I had to upgrade to the newer Accesstuner to be able to see and adjust the other which was originally set to 149.16 mph / 240 kmh. Thank you COBB customer support.
My mods: http://www.mazdaspeedforum.org/forum/forum/f511/finland-has-fast-mazdas-too-191514/
irissanen is offline   Reply With Quote
 Old 07-09-2017, 06:16 PM   #1850
ericrapp0507@gmail.com's Avatar
Posts: 281   (View Stats)
ericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the world
Freektune just gave me an effective start up tune.
CS turbo sounds sweet even at spring pressure
ericrapp0507@gmail.com is offline   Reply With Quote
 Old 07-24-2017, 05:01 PM   #1851
irissanen's Avatar
CS turbo with 21 psi boost. E45 blend and 2x1000cc aux injectors. Still some room to improve.
edit: tire diameter is wrong there, with correct diameter figures are 415 whp / 393 lbft
 Old 07-24-2017, 09:06 PM   #1852
nindoja's Avatar
Posts: 2,395   (View Stats)
Post up a log. That's some crazy power there.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
 Old 07-24-2017, 09:24 PM   #1853
everton99's Avatar
Posts: 1,044   (View Stats)
everton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the world
Groaned at 8 Times in 7 Posts
Built block I'm assuming?
Sent from my SM-G955U using Tapatalk
everton99 is offline   Reply With Quote
 Old 07-24-2017, 09:33 PM   #1854
davychronic's Avatar
Posts: 1,155   (View Stats)
davychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the world
Default So, about the new Corksport turbo...
Thats good numbers for 21psi be careful with that lean spike right after 4k, i bent a rod in the same area with e30 and meth. With that much aux fuel you should be able to push that turbo all the way. I could only get it to spin up around 32psi and it would drop to 28 by redline. Its a good little turbo but passed 21psi it starts just blowing hot air so meth really helps.
Its on 1.01 cf probably closer to 400 on 1.09 cf
Edit: im backwards here, my build has taken too long,i havent played with vd for a while
06 MS6 GT Titanium Gray II Metallic
Last edited by davychronic; 07-25-2017 at 04:21 AM. Reason: MSF Database - Automerged Doublepost
davychronic is offline   Reply With Quote
 Old 07-25-2017, 02:20 AM   #1855
irissanen's Avatar
Log attached. As I am running aux fueling, load and MAF will be affected by it.
Bone stock, see signature for my mods.
Yes, the tune isn't finished yet. It gets a bit lean right after the throttle plate opens fully as I have disabled STFT enrichment at WOT. Have to figure out how to make the fueling react faster on those transients.
Cooling effect of aux fuel and e45 helps a lot. BATs were only 13C/55F at the end of that pull, and it isn't winter here yet.
Isn't that just the other way around? Higher CF yields in higher numbers.
davychronic likes this.
The Following User Says Thank You to irissanen For This Useful Post:
mituc (07-25-2017)
 Old 07-25-2017, 04:18 AM   #1856
Yea you are right im backwards, late night got me but either way those are good numbers for such low boost on that turbo.
 Old 07-25-2017, 07:56 AM   #1857
Jonb82's Avatar
Posts: 416   (View Stats)
Hey guys. I need a fact check please. I'm at the point where BT is the next thing where I piss the wife off. Again. I was considering BNR S3/S4 or the CS. But I read in one thread that if I have the CS divorced DP I might be limited to the CS due to interference from the waste gate on the BNR's.
Sent while probably pooping
 Old 07-25-2017, 08:02 AM   #1858
Xxblinddzxx's Avatar
Posts: 126   (View Stats)
Xxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud of
Groaned at 26 Times in 11 Posts
Woa... 450hp 0.o I'm at 411whp / 26psi with a 1250cc meth injection. I was told that arround 26psi the turbo is maxed out ?
Xxblinddzxx is offline   Reply With Quote
 Old 07-25-2017, 01:38 PM   #1859
irissanen's Avatar
Took a second look at Virtual Dyno today and noticed that my tire diameter was set wrong, no idea why. When set correctly according to my 225/40R18 wheels (25" dia), figures come out little more realistically at 415 whp / 393 ftlb. Sorry about this error.
 Old 08-01-2017, 01:32 AM   #1860
irissanen's Avatar
Participated to a one mile race event last weekend with 266.66 km/h or 165.69 mph end speed.
More info and log in my thread:
http://www.mazdaspeedforum.org/forum/foru...4/#post3123691
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f500/so-about-new-corksport-turbo-185527/
??????????? ????? ????? ?????????? ????????? ?????? ? ?? ?????? :( This thread Refback 10-05-2015 03:33 PM
?????????? - ??????? (??????????, ???????, ??????) This thread Refback 05-14-2015 02:18 AM
corksport DP to garrett turbo? Swinger13 MazdaSpeed 3/6 - Turbo Induction 14 10-05-2012 08:29 PM
Corksport turbo inlet pipe fit my ms6? arnobg MazdaSpeed 3/6 - Turbo Induction 16 01-19-2012 10:00 PM
Corksport Turbo Inlet not fitting... HELP xl1200r 2010 MS3 - Turbo Induction 8 04-09-2010 02:28 PM
Page generated in 0.41073 seconds with 33 queries
