Like Tree642Likes
 Old 03-10-2015, 07:08 PM   #1
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Neutral  +1 score
Default So, about the new Corksport turbo...
You guys are never shy about sharing information early on, so I was surprised to almost step right over this in facebook. Usually there is like a 2 month long 4 stage whitepaper release of upcoming products on your blog.
Was this the new beta test item?
MINI H1 6.0 - CAR LED TAILS
ALPINEST4RS (03-10-2015), Easter Bunny (03-10-2015)
 Old 03-10-2015, 07:30 PM   #2
ALPINEST4RS's Avatar
Posts: 905   (View Stats)
Groaned at 8 Times in 3 Posts
Saw this too. Similar to a BNR S1???
 Old 03-10-2015, 07:43 PM   #3
cshunter's Avatar
Posts: 1,312   (View Stats)
I'd venture to say about the same as the BNR S3, works with their downpipe, but with a slightly higher price tag because of it being a zero modification, drop in product.
IndianOutlaw likes this.
2013 CWP That's slow
Previous: MILTUNED E85 K04
The Following User Says Thank You to cshunter For This Useful Post:
 Old 03-10-2015, 07:50 PM   #4
I vote twin scroll setup with included header. Cuz that would be cool!
aromig likes this.
cshunter (03-11-2015), WetzMS3 (03-13-2015)
 Old 03-10-2015, 08:19 PM   #5
Oni
Oni's Avatar
Posts: 565   (View Stats)
They had a prototype for fitting a mitsubishi 16g into a stock flange turbo posted on FB a while back. I'd still like to know some more details on it though.
Sent from my iPad using Tapatalk HD
'12 Velocity Red Mica MS3
Cobb AP V3 // Autotech Fuel Pump Internals // HTP 3" // UR Catted V2 DP // UR Resonated TP // UR Resonated CBE // GrimmSpeed EBCS // CP-E TMIC // GFB Respons BPV // JBR Trilogy 88/80/80 // Corksport Hood Struts // Prosport EVO Boost Gauge w/ block8head vent pod // E30 Freektune
Installing Soon : Stratified GA // Bosch 3 Bar Map w/ PNP Harness
Oni is offline   Reply With Quote
 Old 03-10-2015, 08:53 PM   #6
England15j's Avatar
Posts: 1,910   (View Stats)
@Turbo_Steve; was working on this exact thing
Mitsubishi turbochargers & the mazdaspeed....
The Following 3 Users Say Thank You to England15j For This Useful Post:
ASHMS3 (03-11-2015), btstarcher (03-17-2015), jack_hammer (03-10-2015)
 Old 03-10-2015, 09:16 PM   #7
I dgaf as long as they change their downpipe to work with non stock iwg turbos.
England15j (03-10-2015)
 Old 03-11-2015, 09:07 AM   #8
CorkSport's Avatar
Posts: 3,416   (View Stats)
Not a 16g, 18g
-Derrick
WWW.CORKSPORT.COM
btstarcher (03-17-2015), silvapain (03-18-2015)
 Old 03-11-2015, 09:30 AM   #9
Oni
Oni's Avatar
Not a 16g, 18g
-Derrick
I was close!
 Old 03-12-2015, 11:43 AM   #10
getemslough's Avatar
Posts: 163   (View Stats)
getemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the world
I'm running the cs dp on a 2867 with no issues...
---2009 CWP---ATP GTX2867r---COBB AP V3---CS HPFP---CS BERYLLIUM/COPPER INJECTOR SEALS---SELF PORTED INTAKE MANIFOLD---CS 3.5 SRI---
---PROTOTYPE XSPOWER V3 IWG MANIFOLD (BETA TESTER)---CS CATTED DP---CNT CATBACK---RPM/CX FMIC PIPING---TREADSTONE TR8---
---GRIMMSPEED 3 PORT EBCS---3BAR MAP/RPM HARNESS---NGK 6510---JBR 51R TRAY---3P/HKS SSQV IV---CS RECIRC TUBE---KOZMIC OIL DRAIN---KOZMIC EGR DELETES---
---JBR TB/IM TIGS---CS PMM---CS RMM---CS OCC---CS SKID PLATE---
---CS STEERING WHEEL---CS SHIFTER BUSHINGS---SURE SHORTCUT---JBR SHORT SHIFT LEVER---SURE AGS 621g---SURE AGS EXTENDER---
---KONI STR.T---H&R SPRINGS---PROGRESS RSB---MOOG ENDLINKS---17X9+45 RPF1---5MMSPACERS---255/40/17 NITTO NT555---JBR FLAPS---
--GTX BUILD COMPLETE--
--FREEKTUNE 383/404 ON PUMP--
--METH COMING SOON--
getemslough is offline   Reply With Quote
 Old 03-12-2015, 12:04 PM   #11
Have you confirmed by operating the wastegate manually that it does not interfere? If so this makes a lot of decisions for me.
riflex likes this.
 Old 03-12-2015, 01:50 PM   #12
acemanz's Avatar
Posts: 224   (View Stats)
acemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the world
more info plox, i have plans to buy a BNRs3....change my mind!
acemanz is offline   Reply With Quote
 Old 03-12-2015, 02:09 PM   #13
No, but i looked at it a lot pre-install because i was thinking he same thing. i took quite a few measurements and it didnt look like there would be any problems. all i can say is it must be fine because Justin said my numbers looked pristine and i have absolutely zero creep. if there were a problem it would have showed up somewhere.
The Nut likes this.
The Following 3 Users Say Thank You to getemslough For This Useful Post:
silvapain (03-18-2015), SpencerC (03-12-2015), stanley0910 (03-13-2015)
 Old 03-12-2015, 02:31 PM   #14
SpencerC's Avatar
Posts: 2,159   (View Stats)
Stay tuned. Info will come. Just not for awhile.
Raider (03-13-2015), volcomcinematic (04-08-2015)
 Old 03-12-2015, 02:36 PM   #15
England15j's Avatar
I'll check back in 2 weeks for an update
The Following User Says Thank You to England15j For This Useful Post:
GARRETHEXTREME (03-12-2015)
 Old 03-12-2015, 03:05 PM   #16
CorkSport's Avatar
They are being run on cars with our downpipes currently.
Derrick
WWW.CORKSPORT.COM
 Old 03-12-2015, 03:16 PM   #17
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
I have no issues with my cs downpipe and my turbo. I got lucky I guess
Mods: stock
 Old 03-12-2015, 06:15 PM   #18
Bnr s3 correct?
Derrick
Your new turbo or atp?
Last edited by Easter Bunny; 03-12-2015 at 06:15 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-12-2015, 06:16 PM   #19
faeker's Avatar
Groans: 731
Bnr yes
Mods: stock
 Old 03-12-2015, 06:17 PM   #20
Thanks for confirming. I thought I had read where people had wastegates hitting on replacement turbos. Maybe it was just the atp 30 series. @rfinkle2; pretty sure we talked about this before Maybe you can straighten me out.
lolwrx likes this.
 Old 03-13-2015, 08:52 AM   #21
CorkSport's Avatar
Bnr s3 correct?
I thought this thread was about the CS turbo.....
Arnie1229 likes this.
WWW.CORKSPORT.COM
Worbit (12-28-2016)
 Old 03-13-2015, 09:56 AM   #22
Putin 2.3T's Avatar
Posts: 1,040   (View Stats)
We have very short attention spans.
2011 Mazdaspeed 3 [Sold]
The Following 3 Users Say Thank You to Putin 2.3T For This Useful Post:
dagrimey1 (03-17-2015), MD1032 (03-14-2015), WetzMS3 (03-13-2015)
 Old 03-13-2015, 10:03 AM   #23
ASHMS3's Avatar
Posts: 1,362   (View Stats)
Groans: 126
@CorkSport; give us some pictures, logs, and dyno plots to talk about.
The Following 2 Users Say Thank You to ASHMS3 For This Useful Post:
dale_gribble (03-13-2015), rob ms6gt (03-18-2015)
 Old 03-13-2015, 10:20 AM   #24
the first post was, but you know how it goes around here, within 25 posts it will be gay.
CorkSport likes this.
CorkSport (03-13-2015), Jackis (05-08-2015), Thepedigree13 (03-13-2015), WetzMS3 (03-13-2015)
 Old 03-13-2015, 10:29 AM   #25
I'll straighten you out!
Arnie1229 (03-25-2015), Easter Bunny (03-13-2015), SpencerC (03-17-2015)
 Old 03-13-2015, 10:32 AM   #26
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
I think it's just the gt(X)30 turbos. I tried it with a gtx3071; no beuno, had flapper to dp contact.
 Old 03-13-2015, 11:48 AM   #27
X 10,000
Show us the dyno sheet from that MS3 pull video you posted and let us talk amongst ourselves.
ASHMS3 (03-13-2015), JgamB (03-13-2015)
 Old 03-13-2015, 02:16 PM   #28
JgamB's Avatar
Posts: 2,566   (View Stats)
Beeners are on back order for two weeks™, so they have a lil time to produce the goods. A compressor map would be a nice teaser though...
 Old 03-17-2015, 10:26 AM   #29
slw97's Avatar
Posts: 147   (View Stats)
slw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond repute
Found this in the Q&A
aromig and RogerSpeed3 like this.
Originally Posted by Ckmazdaspeed3 View Post
I don't know about you, but most of my races are impromptu. I'm not like, "hey dude, pull over so I can switch to my super special meth map" lol.
Originally Posted by TRex
"i don't care if it is a soccer mom in a mini van, if that whore launches on me im going at it like i'm racing a supra....just so i can bask in the sweet sweet tears of their defeat.
Originally Posted by rodrigo View Post
couple things to say...... first off the immaturity to be driving at those......ahhhhh shut up woman!!!!
2013 CWP MS3- CS 3" SRI, CS Catted DP, CS 80 Duro Race RMM, GFB BPV, CS STS, AutoTech FP Internals, CS FMIC piping w/TR-6 Core, Res Delete
304 Whp 371 Wtq DYNOJET 3 Gal E85
Purple Drank Tuned
2007 Ms3- Mazda speed CAI, gutted 2nd CAT, AccessPORT (SnailTooned), CorkSport RMM Inserts, flat black gen 1 wheels. 298 WHP 320 WTQ Sold but not forgotten
slw97 is offline   Reply With Quote
The Following 16 Users Say Thank You to slw97 For This Useful Post:
ArmanRus (03-17-2015), Arnie1229 (03-25-2015), aromig (04-08-2015), btstarcher (03-17-2015), CaptainCode (03-17-2015), chaser27 (04-08-2015), chrono996 (04-27-2015), CorkSport (03-26-2015), dinoxor (03-17-2015), Easter Bunny (03-17-2015), Ingle (03-17-2015), JgamB (03-17-2015), Jtaylor (03-17-2015), sadak (07-07-2015), silvapain (03-18-2015), SpencerC (03-17-2015)
 Old 03-17-2015, 10:48 AM   #30
CaptainCode's Avatar
Posts: 81   (View Stats)
CaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond repute
Groaned at 6 Times in 2 Posts
Ooh sounds good
JBR SRI+TIP, Autotech internals, Stratified stage 2 flash tune, Corksport BPV, UR test pipe, Damond Motorsports RMM
CaptainCode is offline   Reply With Quote
 Old 03-17-2015, 11:54 AM   #31
SpencerC's Avatar
Lol. Surprised no one has posted the turbo photo yet.
Or billet compressor wheel:
slw97 likes this.
The Following 13 Users Say Thank You to SpencerC For This Useful Post:
ALPINEST4RS (03-18-2015), Arnie1229 (03-25-2015), Castillo817 (04-16-2015), dale_gribble (03-26-2015), Easter Bunny (03-17-2015), Ingle (03-17-2015), jack_hammer (03-17-2015), JgamB (03-17-2015), mnms3 (03-22-2015), sadak (10-14-2015), silvapain (03-18-2015), slw97 (03-17-2015), WetzMS3 (03-17-2015)
 Old 03-17-2015, 12:05 PM   #32
Ingle's Avatar
Posts: 421   (View Stats)
In for acrylic turbo @350AWHP
Edit: Can't fool me into thinking it's not really made of plastic.
Ingle is offline   Reply With Quote
The Following 3 Users Say Thank You to Ingle For This Useful Post:
Easter Bunny (03-17-2015), hatchedspeed3 (03-17-2015), JgamB (03-17-2015)
 Old 03-17-2015, 01:00 PM   #33
hatchedspeed3's Avatar
Posts: 1,966   (View Stats)
@Code Monkey; plastic turbo, more weight savings for your 6 bruh! lolz
2009 CWP MS3 1-23-2014
The Following 6 Users Say Thank You to hatchedspeed3 For This Useful Post:
Code Monkey (03-17-2015), Easter Bunny (03-17-2015), JgamB (03-17-2015), SpencerC (03-17-2015), torquemaniac (03-18-2015), WA_MS6 (04-16-2015)
 Old 03-17-2015, 01:19 PM   #34
SpencerC's Avatar
Weight Savings. Added Lightness. Anti-Bent-Rod Material.... ya know... Better the Turbo than the Rods.
The Following 5 Users Say Thank You to SpencerC For This Useful Post:
Cheapspeed (04-16-2015), chrono996 (04-27-2015), hatchedspeed3 (03-17-2015), Ingle (03-17-2015), JgamB (03-17-2015)
 Old 03-17-2015, 01:24 PM   #35
slw97's Avatar
I really want to see a compressor map for this thing!!!
Purple Drank Tuned
 Old 03-17-2015, 01:37 PM   #36
@Spencer@CorkSport; thank you for indulging my dumb humor, it is much needed today lol. In all seriousness, when could we expect to see some more hard info on this new snail?
 Old 03-17-2015, 03:02 PM   #37
razerer's Avatar
Posts: 168   (View Stats)
razerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond repute
Groaned at 8 Times in 4 Posts
You guys made your own actuator? I guess you can start selling those too if you did
Cobb AP V3 // Cp-e HPFP // Cobb SRI TIP // Cobb DP // Cobb FMIC // Denso ITV22 // Cp-e Triton Cat-Back // Forge V2 BPV // JBR 88 Duro RMM
Cobb SoCal tuned
razerer is offline   Reply With Quote
 Old 03-17-2015, 05:10 PM   #38
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
What does @Spencer@CorkSport; think a new k04 costs?
Most I've seen are about $1000-1100
 Old 03-17-2015, 06:18 PM   #39
SpencerC's Avatar
Idk. New cost on a K04 from a dealership I have heard anywhere from $800-$1200. Used though... sub $500 easy.
 Old 03-17-2015, 06:23 PM   #40
Interesting that you mention the used price........
Arnie1229 (03-25-2015), Jtaylor (03-17-2015)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f500/so-about-new-corksport-turbo-185527/
??????????? ????? ????? ?????????? ????????? ?????? ? ?? ?????? :( This thread Refback 10-05-2015 03:33 PM
?????????? - ??????? (??????????, ???????, ??????) This thread Refback 05-14-2015 02:18 AM
corksport DP to garrett turbo? Swinger13 MazdaSpeed 3/6 - Turbo Induction 14 10-05-2012 08:29 PM
Corksport turbo inlet pipe fit my ms6? arnobg MazdaSpeed 3/6 - Turbo Induction 16 01-19-2012 10:00 PM
Corksport Turbo Inlet not fitting... HELP xl1200r 2010 MS3 - Turbo Induction 8 04-09-2010 02:28 PM
Page generated in 0.59531 seconds with 42 queries
