| CorkSport To say that CorkSport is passionate about Mazda Performance is understatement. It is the essence of what we do. Our mission to offer unparalleled customer service and support, an uncompromising commitment to the community, and deliver top quality performance parts is demonstrated with each product we develop to help fulfill your vehicles performance potential. At CorkSport we believe it doesn’t have to come in a fancy package or be the most expensive product on the market to be the best. |
![]() | | #41 | ![]() |
| Not Ranked : 0 score
| The Following User Says Thank You to Lex For This Useful Post: | Pointless (05-01-2013) |
![]() | | #42 | ![]() |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
![]() Sent via stockish Black Mica Pu
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress | |
![]() | | #43 | ![]() |
![]() Join Date: Jul 2010 Location: Riverside,CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 917
| Not Ranked : 0 score Im so in for this! I love my CS TIP. I wanna go to a big intake though. Are you guys going to have an option for us VTA guys? JW
__________________ [SIGPIC][/SIGPIC] 2008.5 CWP Speed3 GT - SOLD / ![]() 1991 Ford Mustang LX 5.0 SSP 331 Stroker 9:1 compression - AFR 185 Heads ported to 205 specs - 1.6 Roller Rockers - Comp Turbo Cam - Edelbrock RPM Performer II Upper and Lower intake mani - 24# injectors - 70mm throttle body and EGR spacer - C&L Intake - BBK Headers - MSD Billet Distributor - MSD Coil - Ford Racing Wires - MSD Ignition - A/C delete - Built 3 spd With reverse manual valve body - B&M Shifter - Aluminum driveshaft - 3.55 gears - Moser 31 spline Axles - Nitrous Express 125 shot - 5 lug conversion With SN95 Brakes |
![]() | | #44 | ![]() |
Groans: 793
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals | |
| The Following 4 Users Say Thank You to Tokay444 For This Useful Post: | CamSpeed360 (05-01-2013), Easter Bunny (05-01-2013), MS6 Sanchez (05-01-2013), SLOWHATCH (05-01-2013) |
![]() | | #45 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
| Not Ranked : 0 score The flow in the intake is turbulent, not laminar. Zigatapatalka
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
| The Following 4 Users Say Thank You to Ziggo For This Useful Post: |
![]() | | #46 | ![]() |
![]() Join Date: Sep 2011 Location: Birmingham AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 251
| Not Ranked : 0 score |
![]() | | #47 | ![]() |
| Not Ranked : 0 score Please check the calculations in the following spreadsheet. Not sure where your Reynolds number equation came from but it looks wrong to me because it doesn't include a viscosity term, but it may be a different form I am not aware of. Reynolds numbers over 2300 are transitional IIRC with numbers over 4000 being turbulent. MAF sensors are designed to operate in fully developed, turbulent flow. https://docs.google.com/spreadsheet/...&usp=drive_web Zigatapatalka
| The Following 10 Users Say Thank You to Ziggo For This Useful Post: | atvfreek (05-05-2013), charlesfist (05-01-2013), Easter Bunny (05-01-2013), El_Diablo (05-03-2013), Lex (05-01-2013), MechEnix (05-30-2013), Micha (05-04-2013), mize13 (02-13-2014), ms3blackmica (05-01-2013), SpeedNess (05-01-2013) |
![]() | | #48 | ![]() |
![]() Join Date: Jan 2011 Location: Midlothian, Va
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,042
Groans: 274
| Not Ranked : 0 score Coksport's Dolphin penis? Last edited by SLOWHATCH; 05-04-2013 at 01:45 PM. |
| The Following 3 Users Say Thank You to SLOWHATCH For This Useful Post: |
![]() | | #49 | ![]() |
![]() Join Date: Jul 2011 Location: VACAVILLE, CALI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 219
| Not Ranked : 0 score Joel@corksport; CARB legal for the Cali inmates?!?!?! |
| The Following User Says Thank You to 3dpilot For This Useful Post: | dot584 (09-13-2013) |
![]() | | #50 | ![]() |
![]() Join Date: Dec 2008 Location: Flint, MI
Rep Power: 206 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 955
| Not Ranked : 0 score Ziggo is right, air density=1.2 (kg/m^3) @ 20 celcius Q=Flow=VA Q=0.300 (kg/s)*(1.2 (kg/m^3)=0.25 (m^3/s) V=velocity= Q/A=(( 0.25 m^3/s)*4)/(pi*0.076m)=55.11 (m/s) Re=(density*V*Diameter)/dynamic viscosity dynamic viscosity @ 300 k approx 27 celcius = 1.983 E -5 (kg/m-s) Re= ((1.2 kg/m^3) * 55.11 (m/s) * (0.076 m))/(1.983E-5 Kg/m-s) = 253,451.6 So the flow is very much turbulent at 300 g/s
__________________ HKS Intake l Cobb TIP l CorkSport TMIC l Cobb AP l AT Internals l SU Test Pipe Turbosmart Dual Port l Stratified Shift Extension/Knob l CPE RMM l Dashawk Last edited by SpeedNess; 05-01-2013 at 12:07 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following 9 Users Say Thank You to SpeedNess For This Useful Post: | ABolewski (05-01-2013), atvfreek (05-05-2013), BigRedSpecial (05-01-2013), charlesfist (05-01-2013), El_Diablo (05-03-2013), Jeremy3eb (05-01-2013), Lex (05-01-2013), mize13 (02-13-2014), ms3blackmica (05-01-2013) |
![]() | | #51 | ![]() |
| The Following 8 Users Say Thank You to Lex For This Useful Post: | ABolewski (05-01-2013), Easter Bunny (05-01-2013), El_Diablo (05-03-2013), MechEnix (05-30-2013), Micha (05-04-2013), ms3blackmica (05-01-2013), SLOWHATCH (05-02-2013), SpeedNess (05-01-2013) |
![]() | | #52 | ![]() |
| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
(Thread Starter) | Not Ranked : 0 score Probably not.... CARB is very VERY expensive and we would have to pass that cost on to each intake and it would make them too expensive, especially considering this won't be a high volume part. Sorry... |
| The Following User Says Thank You to CorkSport For This Useful Post: | 3dpilot (05-03-2013) |
![]() | | #53 | ![]() |
Groans: 793
| The Following 5 Users Say Thank You to Tokay444 For This Useful Post: | Easter Bunny (05-01-2013), El_Diablo (05-03-2013), H3R3TIC (05-16-2013), SLOWHATCH (05-01-2013), snailD (05-01-2013) |
![]() | | #54 | ![]() |
![]() Join Date: Oct 2012 Location: NSW Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 86
| Not Ranked : 0 score Correct. This is an awesome thread learning this exact stuff at UNI right now. Changing the boundary flow to turbulent from laminar soon as possible will reduce the drag, allowing greater flow, yes? Also, can you see a possibility of designing an air box for this if it won't be possible to modify the existing corksport air box for the stage 2 intake..? Sent from my LG-P880 using Tapatalk 2 |
![]() | | #55 | ![]() |
![]() Join Date: Nov 2010 Location: Chatsworth, CA.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 49
![]() | | #56 | ![]() |
![]() Join Date: Dec 2012 Location: Portland, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 800
| Not Ranked : 0 score will this work for MS6 guys keeping the battery in OEM location? |
![]() | | #57 | ![]() |
![]() Join Date: Mar 2011 Location: Bethlehem, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,167
Groans: 70
| Not Ranked : 0 score Interested for the MS6...
__________________ 07' Speed6 Velocity Red Mica Go Faster: CorkSport SRI/TIP, SU Test Pipe, SU TMIC, Autotech Internals, ITV22's, Cobb AP Anti break stuff: Upper Rear Diff Brace, RMM Appearence: STRI DSD Boost Guage/Blockhead 60mm Guage Pod |
![]() | | #58 | ![]() |
![]() | | #59 | ![]() |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score 4'' would be tuff with stock batt
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
![]() | | #60 | ![]() |
(Thread Starter) | Not Ranked : 0 score I think we could do 4" fine with the ECU relocated and the battery pushed back the way Brydon did it but like Brydon said, 4" is neat but the stock head wouldn't be able to handle anything near 4" flow. |
| The Following User Says Thank You to CorkSport For This Useful Post: | rigor (05-02-2013) |
![]() | | #61 | ![]() |
![]() | | #62 | ![]() |
Groans: 40
| Not Ranked : 0 score moving ecu is cheating looks good! i may have to do the same the little battery sucks on cold mornings
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan Last edited by rigor; 05-03-2013 at 05:49 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 2 Users Say Thank You to rigor For This Useful Post: | atvfreek (05-05-2013), helmetface (05-03-2013) |
![]() | | #63 | ![]() |
| MSF's Punishing Member ![]() Join Date: Apr 2011
Rep Power: 2794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,165
Groans: 546
__________________ 94 M MS6 IS350 |
| The Following User Says Thank You to Pu Manchu For This Useful Post: | rigor (05-03-2013) |
![]() | | #64 | ![]() |
![]() Join Date: Jun 2010 Location: Rahway Prison, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 221
Training at a Tsa secret location. Sequestration is here!
__________________ If you need military police, do not call me. [SIGPIC][/SIGPIC] | |
| The Following User Says NO Thank You to Juice For This Un-useful Post: | Easter Bunny (05-04-2013) |
![]() | | #65 | ![]() |
![]() Join Date: Jul 2012 Location: Seminole, FL
Rep Power: 1270 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,116
Groans: 55
| Not Ranked : 0 score They make reference to a new battery box they are making for the stock battery. A little tapa tapa taparoo...
__________________ |
![]() | | #66 | ![]() |
| Banned ![]() Join Date: Jul 2012 Location: Tampa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score Can't wait to see the bigger intake! |
| The Following 3 Users Say NO Thank You to TexanMS3 For This Un-useful Post: |
![]() | | #67 | ![]() |
Groans: 793
| Not Ranked : 0 score If you have problems with your silicone intake/tip deforming, your problem is pressure ratio. Your intake is just plain too small. There shouldn't be enough vacuum there to distort its shape.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals Last edited by Tokay444; 05-15-2013 at 10:14 AM. |
![]() | | #68 | ![]() |
| Banned ![]() Join Date: Jan 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 125
| Not Ranked : 0 score Bringing the post filter large amount of air N/A logic into the turbo setups. I am very happy with this setup is looking. |
![]() | | #69 | ![]() |
![]() Join Date: Oct 2012 Location: Colorado Springs, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 757
| Not Ranked : 0 score rats nest... I like the shop light though... I'm waiting to see another way.
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// |
![]() | | #70 | ![]() |
Groans: 40
| The Following User Says Thank You to rigor For This Useful Post: | Yatta (05-14-2013) |
![]() | | #71 | ![]() |
| Not Ranked : 0 score The airflow gain in alum vs silicone isnt so much from the material itself as it is from the shape. If the aluminum is mandrel bent and the inside isnt clogged up with weld sugar/beads then for the same ID alum should out flow silicone because silicone will collapse slightly and it bends/ovals upon installation. Round always outflows other shapes. Heat transfer in a FI application is almost stupid, air is in the intake for a few thousanths of a second during boost and off boost it doesnt matter. If intake heat killed HP, no one would ever buy a SRI. A TIP isnt rocket science, make it round, reduce the bend radius(es), sell for a lower price. Its real simple. The best TIP is a massive air filter clamped to the turbo, anything else is splitting hairs.
| The Following 5 Users Say Thank You to 06Speed6 For This Useful Post: | ABolewski (05-16-2013), dot584 (05-16-2013), Easter Bunny (09-13-2013), jack_hammer (05-16-2013), ms3blackmica (05-16-2013) |
![]() | | #72 | ![]() |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
| Not Ranked : 0 score Agreed. There is not enough time for any drastic heat transfer to take place when moving air at high velocities such as the compressor wheel produces. That theory alone tends to drive tons of people away from metal intakes all the time.
__________________ www.tunedbynishan.com |
![]() | | #73 | ![]() |
Groans: 793
| Not Ranked : 0 score Spoon whale penis intake for the Honda fags isn't round. And that fucker flows. Fyhn
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals Last edited by Tokay444; 05-16-2013 at 06:04 AM. |
![]() | | #74 | ![]() |
Groans: 239
| Not Ranked : 0 score i am king whale peen |
| The Following 5 Users Say Thank You to dooderek For This Useful Post: | 06Speed6 (05-16-2013), ABolewski (05-16-2013), Mfinlay04 (05-16-2013), ms3blackmica (05-16-2013), Tokay444 (05-16-2013) |
![]() | | #75 | ![]() |
![]() Join Date: May 2009 Location: Memphis, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,249
| Not Ranked : 0 score Joel what's the word on this? Looking to buy a TIP the first week of June and looking for other options. Sent from my Galaxy Nexus using Tapatalk 2
__________________ 2006 MS6 Titanium Grey BSD, Custom 3" SRI, 3" HTP TIP, Custom 2.5" Single Exit Exhaust, Nator Sytle Downpipe, E40 Selftune, AutoTechs, Ghetto Mod'ed Stock BPV, VTCS Delete, IM PnP & AWR RMM3 Tuned with |
![]() | | #76 | ![]() |
Cheers, Joel | |
![]() | | #77 | ![]() |
Groans: 255
| Not Ranked : 0 score No black powdercoating? Sent via rental car
![]() | | #78 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm sure that will be an option. Black everything is very popular for our intakes. |
![]() | | #79 | ![]() |
| 5000lbs of voiceless fury ![]() Join Date: May 2012 Location: San Diego, CA
Rep Power: 2530 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,855
Groans: 185
Groaned at 124 Times in 81 Posts
| Not Ranked : 0 score "So.... do we still care about big intakes??" YES.
__________________ 2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN! SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs// |
![]() | | #80 | ![]() |
Sent from my Nexus 7 using Tapatalk 2
__________________ 2006 MS6 Titanium Grey BSD, Custom 3" SRI, 3" HTP TIP, Custom 2.5" Single Exit Exhaust, Nator Sytle Downpipe, E40 Selftune, AutoTechs, Ghetto Mod'ed Stock BPV, VTCS Delete, IM PnP & AWR RMM3 Tuned with | |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f500/so-do-we-still-care-about-big-144282/ | ||||
| CorkSport Mazda Performance ? Blog » Our Videos, Your Input | This thread | Refback | 05-02-2013 01:52 PM | |
| CorkSport Mazda Performance ? Blog » SkyActiv vs. The Traditional Fuel Injected Motor | This thread | Refback | 05-02-2013 08:29 AM | |
| CorkSport Mazda Performance ? Blog » Fuel Pump Comparison Part 2 | This thread | Refback | 05-01-2013 09:07 PM | |
| Intakes Now Available! | HTP | HTP (Hi-Tuned Performance) | 354 | 10-14-2014 08:21 AM |
| Intakes | finalems3 | CorkSport | 38 | 03-29-2013 11:16 PM |
| I'm confused about intakes | curiosul | 2010 MS3 - Engine, Transmission & Driveline | 1 | 08-29-2012 02:32 PM |
| Questions about TBE and Intakes | kingpin4534 | MazdaSpeed 3/6 - Turbo Induction | 14 | 05-04-2009 06:45 AM |
