 Old 07-15-2013, 03:25 PM   #1
AustinK's Avatar
Posts: 175   (View Stats)
AustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the world
Default There can't be that many stance fans out there
Have you lowered your car and have camber issues? We have camber kits for you MS6 owners. With +/- 5 degrees of camber adjustment and cross camber adjustment for fine tuning of your suspension. They Can be easily adjusted with a wrench while still installed in the vehicle. Check them out here Rear Camber Arms And give me a call at 360-260-2675 if you have any questions about them. We have 2 of these kits available.
Last edited by AustinK; 07-15-2013 at 04:25 PM. Reason: Speed 6 ones are available
AustinK is offline   Reply With Quote
The Following 2 Users Say Thank You to AustinK For This Useful Post:
13mazdaspeed3 (07-16-2013), jm211 (07-16-2013)
 Old 07-15-2013, 03:27 PM   #2
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
You misspelled fans....should be fags.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
The Following 7 Users Say Thank You to Boosted Beluga For This Useful Post:
BPASPEED (07-15-2013), Easter Bunny (07-15-2013), El_Diablo (07-15-2013), jm211 (07-16-2013), m4tic (07-15-2013), ms6_nate (07-15-2013), stevehuff (07-15-2013)
 Old 07-15-2013, 04:41 PM   #3
AustinK's Avatar
You can do whatever you want with them, correct camber, make it worse. For the most part Speed owners are not really into the "fitted" scene
The Following User Says Thank You to AustinK For This Useful Post:
Boosted Beluga (07-15-2013)
stance gr+ yaeger101 MazdaSpeed 3/6 - Suspension & Brakes 1 03-12-2012 07:15 PM
Need opinions on stance soaringeagle129 Appearance - BLACK 5 02-26-2012 07:52 AM
stance?? zoomzoom MazdaSpeed 3/6 - Suspension & Brakes 24 01-15-2011 10:09 PM
Page generated in 0.23891 seconds with 21 queries
