Like Tree3Likes
 Old 08-07-2014, 11:25 AM   #41
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Originally Posted by predapio View Post
As I have no axe to grind because I use the ambulette now, do you advise putting the Permatex on these seals too?
@Tokay444;
I do not.
Originally Posted by CaptainCode View Post
How do these aftermarket seals hold up in the Canadian winters?
No issue at all.
"Exclusivity" - CP-enis
Demodded.
The Seals
Last edited by Tokay444; 08-07-2014 at 11:25 AM. Reason: MSF Database - Automerged Doublepost
Easter Bunny (08-07-2014)
 Old 08-07-2014, 11:54 AM   #42
Dumbguy's Avatar
Posts: 130   (View Stats)
Dumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond repute
Im definitely a fan of the design of these as opposed to the cp-e ones. It makes sense to me that an intentional and designed deformation will create a better seal than just a little cup. Really interested to see what the price point is going to be.
2012 VRM Mazdaspeed 3 - “Claudia”
Cobb v3 AP | Autotech HPFP Internals | UR Catback | Cp-e TMIC | Cp-e Stage 2 RMM | Cp-e Catted DP | TWM Full Replacement | CS Occ | CS Bpv | CS Hood Struts | JBR EGR delete | JBR Boost tubes and Recirc hose | HTP 3.5” Intake | 1 Step colder plugs | Blox 490 | BC Coilovers | Drag dr-49
Waiting for install
CS Battery box
2008 Black Mica Mazdaspeed 3 - "April" (Totaled, may she rest in piece)
Dumbguy is offline   Reply With Quote
 Old 08-07-2014, 11:56 AM   #43
Tokay444's Avatar
Groans: 793
Originally Posted by dan7225 View Post
Injector removal tool, studs, nuts...?
Studs and nuts will not be an issue.
CS will need to speak for the removal tool, but I've never personally needed one, and I've pulled some crusty injectors.
Demodded.
The Seals
Mauro_Penguin (08-09-2014)
 Old 08-07-2014, 12:22 PM   #44
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Are these going to be the exact same spec as the Tokay V2 seals? (One day I will get off my lazy butt and get my v2 installed.......one day).
 Old 08-07-2014, 12:35 PM   #45
Tokay444's Avatar
Groans: 793
They are going to be identical save for the overall length.
All the distances from mating surfaces will remain the same.
I shortened up on them in the interest of maximizing material, and not have the open end flare out on the radius of the injector body.
Demodded.
The Seals
magicka (08-07-2014), Mauro_Penguin (08-09-2014)
 Old 08-08-2014, 09:56 AM   #46
dan7225's Avatar
Posts: 511   (View Stats)
@CorkSport; definitely need an injector removal tool, it just makes it easy
maybe even as a loaner/rental
i've had some that came out easy and some that are a bitch, the tool is just GREAT!
 Old 08-08-2014, 10:18 PM   #47
xliquidx's Avatar
Posts: 170   (View Stats)
xliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the world
Inj removal tool would be nice but so long as its not compulsory in the kit, I've done plenty with out it fine
xliquidx is offline   Reply With Quote
Injector seals - need to replace injector/fuel line O-rings? TheRealDefman 2010 MS3 - Engine, Transmission & Driveline 3 03-02-2014 09:35 PM
CPE or PTP Injector Seals? Matrix311 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 13 11-26-2011 03:12 PM
Injector seals... how do you know you need them? MS3 Ventura MazdaSpeed 3 - Engine, Transmission & Driveline 2 03-09-2011 01:29 PM
Injector Seals! ptperformance Mazdaspeed3/6 General Discussion 71 06-02-2010 10:13 PM
Page generated in 0.28925 seconds with 24 queries
