 Old 07-21-2018, 07:54 AM   #1
Topfli8979's Avatar
Posts: 1   (View Stats)
Topfli8979 is an unknown quantity at this point
Default 2.3 turbo oil leak
I recently replaced my timing chain and valvecover gasket on my 2.3. everything went well. Runs good no more rattle. But noticed oil leaking in between the valve cover and the cam cap that connects to the hpfp. Is there supposed to be a gasket that sits under the cap or rtv there? Oil is starting to pool under the hpfp.
Topfli8979 is offline   Reply With Quote
 Old 07-21-2018, 09:49 AM   #2
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
I believe in the FSM there is an area around there that needs a bead of sealant.
MECP
2012 BM
Rfinkle tune in progress
Turbo Leak? Parker-Ms3 2010 MS3 - Turbo Induction 0 10-23-2015 11:31 PM
How to do leak test PRE-TURBO mrQQ MazdaSpeed 3/6 - Turbo Induction 12 08-14-2014 11:15 AM
Oil Leak from Turbo ohhryan MazdaSpeed 3 - Engine, Transmission & Driveline 1 06-18-2014 02:41 PM
Turbo beginning to let go? Or bpv leak? Speed3eak MazdaSpeed 3/6 - Turbo Induction 5 05-17-2011 12:06 PM
Turbo Leak? How to tell - no F'n boost gauge raterry MazdaSpeed 3/6 - Turbo Induction 32 09-10-2009 06:28 AM
Page generated in 0.24023 seconds with 22 queries
