 Old 11-22-2017, 06:54 AM   #1
KamloopsDan's Avatar
Posts: 64   (View Stats)
KamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to all
Default 3.5" intake question
Hey,
I have a 2007 MSP6 and am planning to go big turbo with a HTP 3.5" intake. I have been told by HTP that I would also need this battery tray HTP Mazdaspeed6 51R Battery Tray - Hi-Tuned Performance Products
Stupid question, but does having a smaller battery tray also mean I need to buy a smaller battery? I'm just worried that going from a group 35 to a 51R up here in the Canadian North is not a great idea for cold winter starts.
Any thoughts?
KamloopsDan is offline   Reply With Quote
 Old 11-22-2017, 07:16 AM   #2
GroceryGtr's Avatar
Posts: 472   (View Stats)
if you got the tray, yes you would need the smaller battery to fit in it as well. that being said several people have simply modified their stock tray to make room for the intake. the 6s have a bit more wiggle room than the 3s do. You can trim it down and then redrill the bottom mounting holes to move it out of the way a bit. I know this will work for 3", not 100% positive it will be enough room for the 3.5"
For the price though you could just relocate your battery to your trunk. You'd then have a ton of space and help balance out the weight distribution a tad more. You'd still come out cheaper than the price of the battery tray.
The Following User Says Thank You to GroceryGtr For This Useful Post:
KamloopsDan (11-22-2017)
 Old 11-22-2017, 07:46 AM   #3
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
htp 3.5" intake on my car, stock battery box trimmed, smaller battery 100 percent necessary to fit this intake.
if you want to keep your big battery you have to move it to the trunk.
94 M
MS6
IS350
The Following User Says Thank You to Pu Manchu For This Useful Post:
 Old 11-22-2017, 07:56 AM   #4
GroceryGtr's Avatar
to pu's point I should have clarified either trimming or new tray you need the smaller battery either way. Hey that rhymed!
CCAs are a big deal the colder you get. You're going to lose around 100-150 CCAs going to a 51R series. Just make sure you go with a good quality battery to minimize the cca loss.
 Old 11-22-2017, 08:18 AM   #5
shamie's Avatar
Posts: 952   (View Stats)
I went with an Optima Yellowtop 51R and its CCAs is pretty equivalent to the 35 batteries. Not as much CCAs as the best 35 batteries but as good as your average (OEM) 35s.
The Following User Says Thank You to shamie For This Useful Post:
 Old 11-22-2017, 12:02 PM   #6
Thanks for the advice everyone, another thing to add to my wish list.
 Old 11-23-2017, 08:11 AM   #7
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
I'm running a silicone 3.5".
Most definitely need to go 51r.
I trimmed are redrilled exactly as @GroceryGtr; said.
Will eventually relocate to trunk.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
New Product Release!! TRU-3.0" and 3.5" Full Aluminum Wide Path Intake Systems JBR JAMES BARONE RACING 28 04-30-2015 12:25 PM
3" Intake Question Spring24 2010 MS3 - Turbo Induction 11 07-16-2014 07:40 PM
Questions before ordering a "Path Stage II Power Intake" levon.mark JAMES BARONE RACING 37 03-26-2013 05:01 PM
Page generated in 0.28382 seconds with 24 queries
