 Old 03-16-2019, 11:55 AM   #1
th3_heis3nberg's Avatar
Posts: 7   (View Stats)
th3_heis3nberg is an unknown quantity at this point
Default 3" turbo back UR exhaust with no tune
Whats up everyone? i just bought an UR exhaust with a 3" DP that has no high flow cat and a 3" exhaust that has a straight mid pipe. My car is a 2008 speed with Autotech HPFP internals, Corksport TMM, and a Cobb intake and high flow air filter. I was wondering if there was a proper tune for this or if i could just run the car with some basic maps?
th3_heis3nberg is offline   Reply With Quote
 Old 04-02-2019, 06:31 AM   #2
Posts: 2,826   (View Stats)
3” catless downpipe and midpipe will require a tune. You have the hpfp upgrade that is necessary, but that is not enough. You will get really nasty boost spikes as high as 22 psi or more trying to run the stock tune. Fueling under load will not be right, either. Your long term trims will be off and AFR too lean when going wide open throttle. It is not safe.
It will make power, run like a raped ape, right up until you quickly lean out and go boom. You need a stage 2 compatible tune.
Vansquish (04-02-2019)
OBX racing sports 3" Turbo Back Exhaust System DiggityDan123 Gen2 MS3 General Discussion 15 06-08-2014 02:23 PM
CORKSPORT "Power Series Mazdaspeed 3 Turbo Back Exhaust System molejao43 CorkSport 11 04-24-2013 10:28 AM
Cobb AP "stock" tune Turbo PSI tc0308 Gen2 MS3 General Discussion 10 03-07-2013 05:09 PM
Page generated in 0.22874 seconds with 21 queries
