  • 2 Post By charlesfist
 Old 06-05-2012, 08:19 AM   #1
electric101's Avatar
Posts: 10   (View Stats)
electric101 will become famous soon enough
Default #4 misfire after driving through deep water
on my way to work yesterday during a pretty bad storm drove through what looked like shallow water running across the road... turned out to be deep.
car was dying at idle and running like crap unless i was at a high rpm... (had to get it home)
changed plugs and wires... took off coil pack and #4 was corroded. tried to clean it out as best i could but issue persists.... maybe not quite as bad but still dies at idle sometimes and is missing like crazy.
gonna replace the pack but wondering if anything worse could be causing it?? hoping not a cracked head or anything...
electric101 is offline   Reply With Quote
 Old 06-05-2012, 09:04 AM   #2
dturboman's Avatar
Posts: 1,174   (View Stats)
dturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the world
cracked head? you better hope you dont need a motor.
dturboman is offline   Reply With Quote
 Old 06-05-2012, 09:15 AM   #3
it gives a #4 misfire code at autozone... i think its more likely that its the coil but i guess its still possible its a cracked head...
 Old 06-05-2012, 09:17 AM   #4
dturboman's Avatar
lol, and my misfire was a bent rod... best of luck.
you better donate and start to search
water doesn't compress so if you sucked up water your fucked.
Last edited by dturboman; 06-05-2012 at 09:26 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-05-2012, 09:24 AM   #5
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
Does your clutch vibrate?
Could be a bent rod...hydrolock
 Old 06-05-2012, 09:26 AM   #6
alphasaur's Avatar
Posts: 2,847   (View Stats)
Groans: 235
eek, still don't see why people do cai on this car
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/lol nator.
 Old 06-05-2012, 09:27 AM   #7
dturboman's Avatar
becaz Honda Duh
 Old 06-05-2012, 09:29 AM   #8
the contact on the coil where the plug wire connects was totally full of corrosion... cleaned it with alcohol pads but its still really dull looking where the others are shiny copper... and should there be some kind of spring in there? (i've seen springs referenced on here) alot of junk fell out of the hole when i turned it upside down dumping the corrosion out...
 Old 06-05-2012, 09:31 AM   #9
dturboman's Avatar
Search, dont expect us to give you all the answers... I mean you just joined and I assume you joined because you have a problem.
Dontate
Search
troubleshoot
ask questions
 Old 06-05-2012, 09:36 AM   #10
figured i'd get some knocking if it was a rod... dont really hear anything like that.
been searching... only thing close to this problem that i've found is people spraying their engines off with water hose and having a similar problem... but not exactly the same...
Last edited by electric101; 06-05-2012 at 09:36 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-05-2012, 09:45 AM   #11
DiGi Faggot's Avatar
Posts: 1,212   (View Stats)
Groans: 148
You might not get knocking. Normally people spray their engines with the car on and at temperature so it doesn't stay on the engine but burns off. If they dont theres a chance water can destroy many things.
Sounds like your coil might be fubar though. Yes there is a spring inside the coil.
 Old 06-05-2012, 09:47 AM   #12
wouldnt it have died if it hydrolocked? i dont have CAI
thanks digi
Last edited by electric101; 06-05-2012 at 09:47 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-05-2012, 09:51 AM   #13
alphasaur's Avatar
Groans: 235
thanks digi
jesus how deep was the water
/speed 3- bye
/lol nator.
 Old 06-05-2012, 10:00 AM   #14
well i'd say it was about 2 or 3 carlengths long and about 2/3 up my wheel... but thats just an estimate... i had hit something the other night which i think broke some of the plastic scrub plate on the bottom and when it hit the water it bent it under the car thus letting water shoot up into the engine some... although when i looked under the hood i couldnt tell that water had really been in there... I did take off my air filter and check to see if it was damp and it wasnt.
 Old 06-05-2012, 10:05 AM   #15
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Think happy thoughts
swap coil pack with different cylinder
see if problem follows coil pack
340hp / 371tq
charlesfist (06-05-2012), meicalnissyen (06-05-2012)
 Old 06-05-2012, 10:11 AM   #16
so just swap plug wires 3 & 4 and run it and see if it pops a code for #3 instead of #4... and think happy thoughts... i'll try it this afternoon
 Old 06-05-2012, 10:12 AM   #17
charlesfist's Avatar
Posts: 281   (View Stats)
charlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the world
Its probably just the coil gone bad.
Another way is you can check the resistance on the terminals to see if its bad.
Its in the workshop manual. Resistance should be something like in the infinite range between the two end terminals and somewhere in the K-ohm range between any other of the two (dont quote me on this).
There is a guy selling coils here in our marketplace in you need em (donating will get you access)
TiGraySpeed6 and rfinkle2 like this.
charlesfist is offline   Reply With Quote
The Following 2 Users Say Thank You to charlesfist For This Useful Post:
rfinkle2 (06-14-2012), TiGraySpeed6 (06-05-2012)
 Old 06-05-2012, 10:17 AM   #18
That's the jist of it...
You're driving a Speed, right? Just wanted to be sure.
If yes, stop using the phrase "plug wires", you don't have plug wires. Not meaning to be a dick, just double-checking since you're not using a sig.
Anyway, unplug and remove coil packs from 4 and any other cylinder, 3 is as good as any, and switch just the coil packs around. If you were to move wires, not coil packs, bad things happen.
340hp / 371tq
 Old 06-05-2012, 10:47 AM   #19
ehhh, no mine isnt a speed... its the one in the avatar. regular 4 cyl. and yeah i guess it just has wires... saw what are i guess coil packs in a pic while researching the issue... definitely not what i have. mine are just standard wires... which is why i ran that last question/statement by you because i thought it wouldnt run correctly crossing wires.
 Old 06-05-2012, 10:57 AM   #20
trf5000's Avatar
Posts: 2,290   (View Stats)
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
The Following 2 Users Say Thank You to trf5000 For This Useful Post:
dantes5823 (06-06-2012), GTISPEED3 (06-05-2012)
 Old 06-05-2012, 11:04 AM   #21
Gotchya. Wow, going old school-
same theory, pull #4 wire at both ends
pull another wire and place in #4 holes, both ends
put the #4 wire where you pulled the test wire
make sure wire length will be sufficient to reach
insert standard bitching about this being a speed forum
340hp / 371tq
 Old 06-05-2012, 12:18 PM   #22
alphasaur's Avatar
Groans: 235
you're missing a turbo
and direct injection
and other things.
/speed 3- bye
/lol nator.
The Following User Says Thank You to alphasaur For This Useful Post:
 Old 06-05-2012, 12:22 PM   #23
oh, and swapping plug wires is no where near as exciting as swapping CP's, since plug wires cost less than the gas needed to drive to the parts store & buy new plug wires.
& that's likely all you'll learn is if the wire is good or not.
At least it's quick.
340hp / 371tq
 Old 06-05-2012, 12:41 PM   #24
the wires are brand new, just got em yesterday... but the ignition coil had one of the points really corroded... it was the one that connects to the plug closest to driver side. like i said i cleaned it out as best i could but it still looks dirty compared to the others.
 Old 06-05-2012, 12:56 PM   #25
Since not coil pack, and since only one of four in same place effected, likely not from water crossing. I don't have any service manuals or other reference to pull diagnostic testing info for your 4in1 coil pack system.
Such diagnostic info would be readily available on a site that more catered to the standard 6 rather than the speed6 & speed3. We do have substantially different engines.
Might want to register over on mazda6club.com and pass the question around over there as they have a HUGE user base of standard 6's.
340hp / 371tq
 Old 06-05-2012, 01:05 PM   #26
yeah i just did but thanks for all the info... figured i'd get it from the people who take mazda's to the next level first lol
The Following User Says Thank You to electric101 For This Useful Post:
alphasaur (06-10-2012)
 Old 06-05-2012, 01:11 PM   #27
the public enemy's Avatar
Posts: 1,133   (View Stats)
the public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the world
Yeah!
2006 Mazdaspeed6 GT Pearl Whitewater
"A life lived at half throttle is a life half lived."
Pulling like a freight train whilst sounding like a tractor.
the public enemy is offline   Reply With Quote
 Old 06-06-2012, 01:12 PM   #28
Krylos225's Avatar
Posts: 149   (View Stats)
Krylos225 is a splendid one to beholdKrylos225 is a splendid one to beholdKrylos225 is a splendid one to beholdKrylos225 is a splendid one to beholdKrylos225 is a splendid one to beholdKrylos225 is a splendid one to beholdKrylos225 is a splendid one to beholdKrylos225 is a splendid one to behold
We take better mazdas to the next level, not yours. Therefor, as u may have learned, not the best place to ask.
2009 mgm Ms3. corksport catless turboback exhaust (dp,rp,cbe), autotech hpfp internals, injen cai, hks ssqv bov, Cobb AP (stage 2 tune).
Krylos225 is offline   Reply With Quote
The Following User Says Thank You to Krylos225 For This Useful Post:
Importance of Water Cooling on Water-Cooled Cener Sections XRJoe MazdaSpeed 3/6 - Big Turbo Builds 3 03-04-2015 11:28 AM
Deep Discount Coupon Code (Buy 2 Get 1 FREE on 450+ DVD Movies) at Deep Discount Haltech Hot Deals Section 0 04-14-2008 11:20 AM
Page generated in 0.45596 seconds with 29 queries
