![]() Join Date: Oct 2011 Location: brooklyn, ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 240
(Thread Starter) | Not Ranked : 0 score I'm looking for feed back from those on Here running a port injection setup. How reliable has it been? That's what I really want to know. Seems like a good option for more fueling, but not sure on how reliable it would be with a daily driver. I'm thinking to upgrade to bnr s4 next summer and port injection crossed my mind. |
| The Following User Says Thank You to maddocx240 For This Useful Post: | BuddySpeed3 (12-30-2017) |
![]() Join Date: Jan 2015 Location: Lincoln, NE
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 93
__________________ 07 Black Mica MS3: Built motor- SP63 Pro Series 88mm 9.5CR pistons, Manley H-beam rods, Clevite Main/Rod bearings, ARP main studs, L19 head studs, ACT 6-puck sprung clutch w/ Prolite Flywheel, AP V3, Stratified E85 tune/EBCS, NGK plugs, Autotech internals, Corksport injector seals/short shift plate/shifter bushings/LED kit, Cp-e FMIC/catless down pipe, Damond RMM/TMM, Mazdaspeed CBE, JBR SRI/TIP/recirc hose/BSD/oil pan baffle/EGR delete/51r battery box, Forge V2 BPV, Koni yellows, and Cobb springs, Gold Enkei RPF1 w/ 245/45/17 sport comp 2's |
![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
__________________ 3rd rebuild on the way...maybe... | |
| Approved MSF Vendor ![]() Join Date: Mar 2014
Rep Power: 2489 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,022
http://www.freektune.com/collections...port-injection
__________________ Custom Tuning for Mazdaspeed, Ford, and Subaru ![]() Website- http://www.freektune.com/ PTE 6062 633HP/523TQ First gen2 in 10's- 10.93@137 Atco NJ 11/14/15 ![]() Quickest/Fastest Mazdaspeed First Gen 1 in the 9's 9.94@149.5 4/22/2017 New England Dragway | |
| The Following 3 Users Say Thank You to Justin@Freektune For This Useful Post: |
![]() Join Date: Jun 2011 Location: Beach Park Illinois
Rep Power: 2610 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46,278
| Not Ranked : 0 score I use 6th port on my speed 6 and it is awesome. Actually getting the balls and parts together to run 2000 CC injectors in mine. *shrug* Whats the worst that can happen? |
| The Following 4 Users Say Thank You to Micha For This Useful Post: | BuddySpeed3 (12-30-2017), Justin@Freektune (11-19-2015), maisonvi (11-19-2015), WetzMS3 (11-19-2015) |
(Thread Starter) | Not Ranked : 0 score im looking to see if anyone had the fuel controller fail, or you know issues that some have with meth like the injector not spraying. |
| Not Ranked : 0 score wont hurt to run an afr failsafe.
__________________ 2006 MS6 WWP Sport - 340whp/350wtq JBR 3"- BNRS3V2 - GS EBCS - CUSTOM FMIC - CS IM - LTR7IX - CMGS WMI & D07 GA - TURBOXS HEADER - FIDANZA FW - CP-E CATTED DP - 3" CATBACK BILSTEIN - H&R SPRINGS - 18x8.5 +48 ROTA SVN - 265/35R18 HTR ZIII MINI H1 6.0 - CAR LED TAILS SEE MORE USING !SHOUTTAG.COM - ENTER: !6SPEED6 |
| The Following 4 Users Say Thank You to dale_gribble For This Useful Post: |
![]() Join Date: Aug 2012 Location: Toronto, Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 165
Groaned at 7 Times in 4 Posts
![]() I'm thinking of going with the AEM AFR fail safe, along with the Speed Perf6rmanc3 Secondary Injection kit because it comes with the in tank pump and high quality hoses. That kit looks like it comes with more stuff, but for less as compared to the other kits. Anyone have any reviews on this kit? Just like the OP mentioned reliability is important, hence the fail safe. But aside from all that, I like the idea that a cooling effect can be had in the intake manifold (similar to WMI) which will reduce the probability of knock, along with the fact that high Injector Duty Cycles can be brought way down, which will improve in cylinder atomizing (basically taking some load off of the stock injectors). Now with 6th port we have two 1000 cc injectors before the throttle body, and only one injector with 5th port. So obviously 2 injectors will provide more fueling. Since I plan on going this route soon, I'm reading as much as possible and want to make sure I'm understanding it. From what I've read the Split Second Controller gets inputs from all 4 ignition coils to determine when to fire the injector(s), and uses a Maf voltage input to determine how long to keep them open in milliseconds (Injector Pulse Width - IPW). The injector(s) should be configured to fire every 180* of crank rotation in the R4 software, which is why we use 4 ignition coil inputs (180* x 4 = 720* which is a 4 stroke cycle). The fuel map is adjusted using the R4 software and uploaded to the controller. Once primary R4 settings are set to fire every 180*, we only modify the Injector Pulse Width at a given RPM vs Maf voltage cell. The higher the IPW, the more fuel that is delivered. But as RPM's increase the injection window becomes smaller, and the IPW needs to be reduced (correct me if I'm wrong on that). Of course since low side fuel pressure may vary, modifications to the Fuel Map may be required if AFR targets are slightly off. That's what I understand so far about 5th/6th port setups but I still have questions ![]() The in tank fuel pump in the kit is a DW65c (265LPH). Is that pump sufficient for maxing out both 1000 cc/min injectors along with the 4 Direct Injectors without issue? (I don't plan on maxing out either but I'm curious). Also when using both injectors as compared to one, are they fired simultaneously, or do they alternate between injections? If they fire at the same time, I'd assume that each IPW would be half the IPW of using only one injector. Please enlighten me!
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) | |
Groans: 60
The injectors are batch fired, all injectors will spray at the same time, for whatever IPW you program. One thing to remember with the kits that do not use a pressure regulator is that the fuel pressure will not increase as boost increases so the effective max flow rate of your 5th/6th port setup will decrease as your boost increases.
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | |
So does that mean if low side fuel pressure is about 50 psi and I'm targeting 25 pounds of boost, when the injectors open there would be 25 psi acting on that 50 psi of fuel pressure hindering a good spray pattern? How much pressure do these injectors need to spray correctly? Can a regulator be fitted to that small fuel rail and tapped into the return on the hpfp? I noticed that on the Kozmic kits, fuel to the aux rail is tee'd off of the feed to the hpfp, but with the SP63 kit fuel is passes through the aux rail first, and then out to the hpfp. So idk if a fuel pressure regulator would work on the SP63 kit because that would essentially starve the hpfp. What do people do to combat that issue? And which in tank pump is good? Thanks a lot eh
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) Last edited by BuddySpeed3; 12-30-2017 at 11:43 PM. | |
Groans: 60
Boost in the manifold effectively lowers the fuel pressure at the nozzle. The minimum operating pressure will vary, but most are rated for flow at 43.5psi. You could install a regulator with either companies kit, but the regulator needs to be installed so your 5th port setup and the oem hpfp see the higher fuel pressure, with the regulators return running back to the tank. Plenty of people have done the 6th port kits without using a regulator. With 1000cc injectors even at 25psi of boost you'll have effectively 35-40psi of fuel pressure, which is still over 90% of the injectors rated output. All the brands have bad batches, pick a pump that will fit and flow what you need.
| The Following User Says Thank You to SSinstaller For This Useful Post: | BuddySpeed3 (12-31-2017) |
| My Port Injection Set Up | SilverDemon | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 121 | 02-28-2019 09:14 AM |
| Port Injection for 2012 | Realgib3 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 29 | 12-19-2011 03:11 PM |
| Port Injection Question | 6-Speed-6 | MazdaSpeed 3 - Engine, Transmission & Driveline | 9 | 07-16-2009 08:02 PM |
| port injection head | cbspeed3 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 54 | 06-28-2009 10:39 AM |
