 Old 11-20-2014, 07:22 AM   #1
grade247's Avatar
Posts: 58   (View Stats)
grade247 has a spectacular aura aboutgrade247 has a spectacular aura about
Default $850 spent on a......vacuum leak?!
Haha so you may all get a laugh out of this. My car died on my about a month and a half ago. My brother and I were certain it was the clutcha because of the way it was running/driving. So I bought a fidanza flywheel and oem luk clutch tear it all apart and find out my dual mass flywheel had failed so we were pretty certain that was the issue. Put it all back together with the new parts fire it up and it STILL wasn't running. At that point were both pissed/confused. We start checking EVERYTHING and my brother checked under the car for tools for clean up and he saw a NEW hose hanging down that wasn't before. Traced it and yea was the line to my OCC off the pcv MASSIVE boost/vacuum issue. It must have blown off when I went to start it after I parked at target in concord. We checked it then and it seemed solid but might have just been caught. So we reconnected the line to the pc and it fired right up now problem. So yes I dropped $850 on something as simple as a leak BUT my flywheel was dying/dead and could have caused MASSIVE damage to my rear main if the springs let go. On a good note the fidanza is freakin AWESOME!!!
Please feel free to flame and make fun made me laugh a bit. Least now I know how to drop the tranny and such out now.
On a side note anyone know the part number for the driver side axel shaft seal out the tranny. Putting my axel back in I think I beat mine up so its leaking a bit now.
grade247 is offline   Reply With Quote
 Old 11-20-2014, 07:36 AM   #2
Spec's Avatar
Posts: 4,472   (View Stats)
Lemme guess, you beat the seal up on the cross member?
I could use that part number too, lol.
 Old 11-20-2014, 07:38 AM   #3
KyleMS32010's Avatar
Posts: 694   (View Stats)
KyleMS32010 is the leader of the worldKyleMS32010 is the leader of the worldKyleMS32010 is the leader of the worldKyleMS32010 is the leader of the worldKyleMS32010 is the leader of the worldKyleMS32010 is the leader of the worldKyleMS32010 is the leader of the worldKyleMS32010 is the leader of the worldKyleMS32010 is the leader of the worldKyleMS32010 is the leader of the worldKyleMS32010 is the leader of the world
At least it wasn't a complete waste, and you learned something in the process. Glad it's all good now.
KyleMS32010 is offline   Reply With Quote
 Old 11-20-2014, 07:45 AM   #4
grade247's Avatar
Its the seal where the half shaft for the driver sode axel goes into the tranny. The driver side didn't want to go it so I kinda "hulk smashed" it in
 Old 11-20-2014, 08:02 AM   #5
spals's Avatar
Posts: 305   (View Stats)
spals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the world
You did replace the axle circlips, right?
Sent from my HTC6525LVW using Tapatalk
CP Pistons 88mm, Manley H-Beams, Balanced Crank
BNRS3V2, Cobb Catted DP, ETS TMIC, 3.5" JBR Alum Intake, AT HPFP
GS EBCS, 3 Bar Map, JBR 88 RMM, DM OCC, TIGs, BSD+Baffle
SBC Stage 2 Daily, JBR RSB, Koni Yellow, Konig Miligrams 18x8.5, Nitto NT-05 245/45
Spalsbuilt-Freektuned
spals is offline   Reply With Quote
 Old 11-20-2014, 08:03 AM   #6
grade247's Avatar
Yes replaced those as well
Weird Vacuum leak msfastashell MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 10-22-2014 06:46 AM
Vacuum Leak? Spring24 2010 MS3 - Turbo Induction 13 10-17-2014 02:09 PM
Bov vacuum leak? CleanMS3 2010 MS3 - Turbo Induction 1 07-10-2014 12:50 AM
Vacuum leak, but no boost leak? vbt101 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 04-18-2010 01:06 PM
Page generated in 0.27031 seconds with 23 queries
