![]() Join Date: May 2012 Location: Las vegas, Nevada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
Groaned at 8 Times in 7 Posts
(Thread Starter) | Not Ranked : 0 score here's the how to I followed..takes takes some time and attention to detail! How-To: Home Depot (HD) Lip
__________________ sure test pipe, both resonators deleted, RL coilovers, XXR 521's machined silver, muteki gold lug nuts |
| The Following 3 Users Say Thank You to Vegasspeeed For This Useful Post: |
![]() Join Date: May 2012 Location: fontana, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 893
Groans: 68
Groaned at 62 Times in 29 Posts
__________________ [SIGPIC][/SIGPIC]2012 Black Mica JBR WP intake// JBR RMM 80 duro// JBR Heavy knob// JBR Boost tubes + Recirc Hose// JBR Spacers// ETS Tmic// UR catless Dp// UR catless Tp// Custom 3in Catback// Go Fast Bits BOV 50/50// Autotechs// NGK one step colder// Megan Coilovers 324whp 368tq Vdyno CF 1.01 268whp 300tq AWD Mustang Dyno 3 GAL. E85 mix STRATIFIED 13.10 @ 108.1 (Nt05's) Auto Club Speedway | |
![]() Join Date: Aug 2013 Location: Japan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 51
| Not Ranked : 0 score Looks good!
__________________ 2013 GenPu - There are no obstacles only opportunities for excellence. Installed: CS TIP, SRI, Boost Tubes ¤ Cobb AP ¤ Cp-E RMM ¤ Block8Head Dual vent pod ¤ JBR SSP, SSB ¤ AT Internals ¤ GlowShift Boost/OP Gauges ¤ EGR Delete ¤ M2 DP ¤ Synapse DV In the mail/awaiting install: NGK Plugs ¤ DM OCC ¤ Grimmspeed EBCS ¤ Bosch 3Bar ¤ Bitwise PNP ¤ TR6 FMIC core w/ CXracing pipe ![]() |
Thank you sir!
__________________ sure test pipe, both resonators deleted, RL coilovers, XXR 521's machined silver, muteki gold lug nuts Last edited by Vegasspeeed; 10-09-2013 at 09:03 PM. Reason: MSF Database - Automerged Doublepost | |
![]() Join Date: Oct 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,593
| Not Ranked : 0 score I like it, well done! I may have to do that as well.
__________________ 2009 Mazdaspeed3 Bolted, Mounted, Hypnotic Tuned 2000 Mazda Miata MX-5 NASA TTE build ongoing |
![]() Join Date: Mar 2013 Location: Huntsville, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,402
| Not Ranked : 0 score I paid $30 for something very similar if not the same from ezlip, and it's held on at 120+ mph just fine so far. I didn't use any fasteners because I didn't want the holes, just the pre-applied adhesive strip.
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) |
![]() Join Date: Feb 2010 Location: Seattle, WA
Rep Power: 2233 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 142
| Not Ranked : 0 score Can you post some shots from above?
__________________ Zoom-Zoom-Coons on 05/10/16 ![]() 2011 Mazdaspeed3 Celestial Blue Mica BUILT BY CORKSPORT CP-e Catted Downpipe || CP-e HPFP || Corksport Turbo || Corksport 3-bar Map Sensor || Corksport EBCS|| Corksport SRI || Corksport TIP || Corksport CBE || Corksport Boost Cut Killer || Corksport FMIC || Corksport SSP || Corksport MM Inserts || Corksport Blue Shift Knob || Corksport Injector Seals || DM Full EGR Delete Kit || Corksport License Plate Relocation Kit || Snyapse Engineering Synchronic BOV || Cobb V3 Accessport (PD Tune in progress) |
![]() Join Date: Nov 2010 Location: York/Philly, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 777
that being said i had garage door weather strip on my car until snow drifts took it off and have one on my other car now. good stuff. | |
(Thread Starter) | Not Ranked : 0 score ya I didnt want to either but the 3m tape I got wasnt working at all so I just did it
| The Following 2 Users Say Thank You to Quigs For This Useful Post: | pstpolamalu43 (10-14-2013), Vegasspeeed (10-14-2013) |
(Thread Starter) | Not Ranked : 0 score not bad! I would have had it stick out a little further but it still looks good man
| Not Ranked : 0 score Thanks! I originally had it out a little further, but then I decided that I wanted it to be more downward and a little less outward if you know what I mean. Yours looks nice and aggressive, so instead of copying you directly I tried to make it slightly more subtle.
![]() Join Date: Apr 2012 Location: Rhode Island
Rep Power: 133 ![]() Thanks: 154
| Not Ranked : 0 score i've had mine on my pu for about 3 months now, its just starting to look like hell lol. good job though, looks good for 9$
__________________ -ETS tmic -Autotech HPFP internals -SURE sri -SURE tip -Forge V1 bpv -Ultimate Racing downpipe -Corksport racepipe -Ultimate Racing cat-back exhaust -Corksport exhaust hangars -Corksport short shift plate -Corksport race RMM -Corksport OCC -Denso ITV22 spark plugs -10mm spacers-Continental DW 235/40-Eibach Pro-kit springs -Akebono Euro ceramic brake pads -OEM mazda window visors -Rally Armor mud flaps -20% tint TUNED BY: ![]() |
![]() Join Date: Jul 2012 Location: Tampa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,432
| Not Ranked : 0 score How about some $9 side skirts and rear bumper lip?
__________________ '08 Speed3 - Cobb sri/cp-e rmm/18x8 RX-8 rims (DynoJet @ 254 whp/295 wtq) '99 Miata - Ground Control coilovers/Bilstein Sports/Racing Beat F&R sway bars/Go Miata strut tower brace/Jackson Racing header/MSM muffler/15x7 Kudo Racing wheels |
| The Following User Says Thank You to 3Gee Tee For This Useful Post: | TheRoyceWay (10-18-2013) |
![]() Join Date: Sep 2012 Location: Los Angeles, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21
| Not Ranked : 0 score I wonder how it would look on a gen pu Sent from my Galaxy S4
__________________ Black Vue Dash Cam- Cobb AP V3 (Stratified tune 4 gal E85 mix) - M2 Downpipe - Swift Springs - HKS SSQV4 - Sure V2 SRI - JBR TIP - ACDelco Rear Camber Arms - West-End Custom Alignment - White Line Bump Steer - KMD Internals - Hankook Evo V12 245-40-17 - |
| Not Ranked : 0 score After reading this I went out that night or the next night and bought everything to do it on my silver genpu. Didn't look good with silver so I took it off. Probably just going to get the nextmod one or fiberglass my own.
![]() Join Date: Apr 2012 Location: port orchard, w.a
Rep Power: 501 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
| Not Ranked : 0 score cant you just paint it black? I know its rubber but as long as you don't scrape it or get it hit on a crub it should be fine no? this way it would be a deeper black to almost match the black ms3
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned |
![]() Join Date: Apr 2013 Location: Prosper, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
| Not Ranked : 0 score I did this on my ms6 today. Then drove it for about 40min. There was nothing left of it. |
![]() Join Date: Dec 2009 Location: San Antonio, TX
Rep Power: 5050 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,143
Groans: 146
| Not Ranked : 0 score |
![]() Join Date: Nov 2010 Location: San Diego, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25
| Not Ranked : 0 score Looks good. Nice job.
__________________ 2011 LSM w/ Tech Pkg Cobb AP - OTS Stage 2 | Ultragauge | Autotech HPFP Internals | DENSO ITV22s | Forge BPV v2 | CS TMIC | CS Boost and BPV Tubes | CPE Nano SRI w/ Amsoil filter | CS TIP | OBX race pipe | CPE Stage 2 RMM | JBR PSMM 80 | JBR TMM 80 | JBR Shift knob, weight, bushings | JBR RSB | JBR Rear camber arms | Sure SSP | MD OCC | Corksport Springs | Bilstein Sports | FCM Rear Bumpstops | FoMoCo tranny fluid | CS Tow Plate | CS LED Kit | CS Fog LEDs |
| Not Ranked : 0 score just did this to my gen one. I think its okay for now. I plan on getting the sti lip tho
![]() Join Date: Dec 2008 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score Looks good! I just bought a lip from a local guy for $75 for the gen1 and now its in the autobody shop with my front bumper getting painted and installed for $300. Little more then I wanted to spend but its a high end shop and they will make it look great. For $9.00 damn, cost me more in gas to drive to this shop then it did you to buy this lip.
__________________ Eric Schlaht - Arizona Phoenix Photographer http://www.esimaging.net - http://www.facebook.com/esimaging [SIGPIC][/SIGPIC] 2007 MS3 Sport, gtx3071r, Full-Race Exhaust Manifold, SP PNP Intake Manifold, SP 88mm Pistons 9:5:1, Manley H Beam Rods, 10mm H11 Head Studs, ARP Main Studs, 4" HTP TIP + Small Battery Tray, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E Nexus CBE, Tokay Injector Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DIY Perm Plate with dual OCC, Corksport Radiator Shroud, Southbend Stage 3 Clutch, DO Stage 2 Meth D10, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **463whp/409lb-ft via Mustang Dyno as of 3/28/14** **9/19/13** Zoom Zoom Boom ** Currently Rebuilding with goal of 475whp **11/19/13** Forged engine built and started up the car for the first time, success! **3/28/14** Dyno results from build 463whp / 409lb-ft Mustang Dyno **6/24/15** Sold the Mazdaspeed 3 **7/4/15** Purchased 2015 F150 Ecoboost Lariat FX4 with Sport Package |
![]() | | #24 | ![]() |
![]() Join Date: May 2012 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
Groaned at 17 Times in 8 Posts
| Not Ranked : 0 score I did this a few weeks ago before the motor went ZZB. I used multiple screws. Id say one every 6 inches and I didn't have it stick out a ton. For under $25 I am super happy with it.
__________________ Fuck MSF |
![]() | | #25 | ![]() |
![]() Join Date: Sep 2012 Location: West Hartford, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 68
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score Legit post
__________________ 2008.5 Metro Grey MS3 Performance:HTP 3.5" Intake | Autotech HPFP Internals | SU TMIC | EBay Catless DP | Stratified Tuned | JBR 88a Dogbone - Short shift plate | Eibach Pro-Kit | 18x8 MB Interline wheels | Conti DW's 235/40R18 | JBR Rear Sway Bar Other fun: Dashhawk | Single res delete | Corksport Interior LED light kit - Bypass valve hose | Vent pod boost gage | Custom Heated driver and passenger seats | Leather shift boot |
