 Old 08-19-2014, 12:08 PM   #1
Mylifeiseasy's Avatar
Posts: 74   (View Stats)
Mylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud of
Groaned at 6 Times in 3 Posts
Default Abs speed sensor cel problems
So I got about 1k on a new clutch. I did my first hard launch. And my dash warning lights went off. Abs, brake,tpms, and tcs. I got a c1233,c1234,u2023, u2064.
I cleared the codes did another launch. Got the same codes again. I took my wheels off inspected everything it all looks good.car drives fine. I can floor to over 100mph and no problems. But I can not do a hard launch without all my dash warning lights comming on. Anyone have any ideas?
2008.5 gtx fmic dm pd Manley
Mylifeiseasy is offline   Reply With Quote
 Old 08-20-2014, 06:41 PM   #2
Tryintogofast's Avatar
Posts: 41   (View Stats)
Tryintogofast has much to be proud ofTryintogofast has much to be proud ofTryintogofast has much to be proud ofTryintogofast has much to be proud ofTryintogofast has much to be proud ofTryintogofast has much to be proud ofTryintogofast has much to be proud ofTryintogofast has much to be proud ofTryintogofast has much to be proud of
Groaned at 29 Times in 6 Posts
First the codes
C1233 Left Front Wheel Speed Sensor input signal fault
C1234 Right Front Wheel Speed Sensor input signal fault
U2023 Can Network Fault
U2064 MIL request by a module
Since you just did a clutch and those two input signal faults are standing out. There's a few things to look at.
1. Did you get both axles nuts locked down tight?
2. Do your wheel bearings have any play?
3. Look for any small cracks in the abs tone wheels
The first is the one I'm suspecting just because you said it comes on during a launch and if they aren't tight the tone rings could be pushed away from the wheel speed sensors causing really messed up signal.
Tryintogofast is offline   Reply With Quote
 Old 08-20-2014, 06:56 PM   #3
I did torque them to 210 lbs. I will check the rings and wheel bearings Saturday. I ordered new sensors they will be here in a day or two.
 Old 10-02-2015, 07:15 PM   #4
0nsp's Avatar
Posts: 143   (View Stats)
0nsp is a splendid one to behold0nsp is a splendid one to behold0nsp is a splendid one to behold0nsp is a splendid one to behold0nsp is a splendid one to behold0nsp is a splendid one to behold0nsp is a splendid one to behold
Groaned at 5 Times in 2 Posts
Sorry for Necro'ing an old thread, but did this ever get resolved? I threw c1233 after launching today...
07 BM MS3//
Power//MS CAI/COBB TIP/CP-e DP/CP-e TMIC/TS BPV/Greddy OCC/COBB AP/NGK plugs/Autotech FP
Handling//Hotchkis F+RSB/TRZ RMM + TMM/Enkei RPF1 on Continental Extremecontact DW/solid shifter bushings/custom weighted shift knob/JBR SSP/KW v3 coils
Cosmetic//Tinted tails + windows + side markers/blue led interior/EONON D5102/Heated seats/Speedline tinted+heated mirrors/2tone emblems/painted calipers
0nsp is offline   Reply With Quote
 Old 09-10-2017, 03:02 PM   #5
Doneschie's Avatar
Posts: 2   (View Stats)
Doneschie is an unknown quantity at this point
Hi guys, I am having the exact same problem as in the original post. Everything on the car operates as it should until I perform a hard launch (from 4300rpm). Has there been any resolution to this problem?
I had the car at Mazda and their PC checks out all 4 wheel speed sensors to be okay.
Any advice will be appreciated.
Doneschie is offline   Reply With Quote
 Old 09-10-2017, 03:15 PM   #6
I replaced my front wheel sensors, unplugged and plugged ecu back in, reloaded my map. And probably a few other things i for got. Problem didn't return. So I don't know what was my problem.
 Old 09-10-2017, 09:33 PM   #7
Doneschie's Avatar
Aha thank you for your response. I have not yet tried unplugging then reconnecting the ecu but I will now. I'll update this post with the results.
02 sensor problems RedBaran MazdaSpeed 3 - Engine, Transmission & Driveline 5 03-26-2014 05:00 PM
02 Sensor Problems OCspeed 2010 MS3 - ECU Computer Tuning 3 03-24-2014 04:30 PM
Problems after installation of new map sensor EmPeEs6 MazdaSpeed 3/6 - ECU Computer Tuning 3 04-12-2013 10:00 AM
New member/speed 6 owner and already problems almcbs Mazdaspeed3/6 General Discussion 13 03-03-2012 05:44 PM
speed 3 problems need advice and help reconbygod12 MazdaSpeed 3 - Engine, Transmission & Driveline 26 09-16-2011 03:52 AM
Page generated in 0.27565 seconds with 23 queries
