![]() Join Date: Mar 2012 Location: Eagle River, Alaska
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 469
Groaned at 9 Times in 6 Posts
(Thread Starter) | Not Ranked : 0 score image-610358609.png Shooting this ISH from my iPhone using forCUMrunner
__________________ 08' MS3 ESK-EMO Tuned!!! GT3076r EWG Manley rods, cp-e stage 2 pistons, arp studs, fullRace exhaust mani,PNP stock IM, TurboXS catless DP/TP/CBE, TurboXS FMIC, hybrid boost control setup using MBC/EBCS, HTP 4" intake system w/MAF block off plate, 3.5" blow thru system fabbed by me,3 bar map, SNOW Stage 2 W/Direct port meth, HKS SSQV4 full vta, JBR 80duro RMM/TMM/PMM, JBR Stage2 OCC, EGR delete, TWM Full Replacement, perm butt plug knob, JBR SB, KMD V2, NGK's, perm pcv plate. shout outs to -Rob, DJ, Nishan, William, John. couldn't have done it with out your guys advice and assistance. thanks. |
![]() Join Date: Jul 2010 Location: Leesburg, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,641
Groaned at 56 Times in 37 Posts
__________________ cobb ap v3 // RICHTUNE // autotech fpi // sp63 afc // cp-e nano // htp tip // nator dc fmic // nator dc PnP intake mani // hks ssqv *vta* // cs dp // su tp jbr rmm(88duro) // jbr pmm(80duro) // cpe tm(75duro) // act 6-puck // act streetlite fw // jbr egr delete // md occ // sure ssb // nator dc sts // jbr hw shift knob ebc red // rx-8s wrapped in conti dws 235/40s (winter) evo Xs wrapped in conti dw 235/40s (summer) www.sonictuning.com 311 whp - 345 lb/ft : Dynojet @ Moore Automotive *93 pump [4/13/13 MNM] 12.94 @ 109.00 @ Capitol Raceway *18' ASL [11/07/14] |
![]() Join Date: Sep 2011 Location: Stockholm Sweden
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,687
Groans: 33
| Not Ranked : 0 score You need to read your post again, i didnt get half of what you said
__________________ Mazdaspeed6 -06 Tuned with by Alex@StratifiedCP-E Atmosphere Kit GTX3076 Tial 0.82AR / EWG / 3,25" MAF / Catless DP Simons 3" Catback CP-E Diff Mount HDI FMIC HTP Battery Relocation Corksport: Rear Brace Bar - Front Strut Bar - Stubby Antenna - Interior + Underhood LED Kit JBR: TMM+PMM+RMM - Short Shift Kit /w Bushings - TIG Throttle - Coolant Bypass - EGR Delete - JBR OCC Stage 2 Whiteline Rear Swaybar SPC Camber Joints Turbosmart BPV Autotech Internals SURE Juggernaught Stratified Guardian Angel & Boost Dial NGK IX @ 0.025 Bosch 3 bar MAP w/ PNP Harness Block8Head Dual Gauge Pod Defi Racer Boost & Oil Pressure & Oil Temp Techna-Fit Clutch Line + Brake Lines ATE Super Blue Racing ProSport Oil Filter Adapter Mazda Spin-On Conversion + NPT/BSPT adapter Not installed yet: SP63 longblock, FreekTune 4" Intake, JBR TIG IM, DM Meth Spacer 290 AWHP / K04 370 AWHP / GTX3076 @ 23 psi |
![]() Join Date: Jul 2011 Location: Glendale Heights, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 507
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score Ok so from what I understand of the gibberish in your op I say test fit it and see how you like it. And as long as its not to expensive go for it. However I would test fit and drive with it to make sure it works better.
__________________ Ultimate Racing // testpipe, catback // TWM // Full Replacement Shifter, Short Shift Boot // Cobb// AP // Sure aeros, sidewinder, shortcut, ags SS knob, return, chargetubes, countershift // Corksport // License Plate Relocate, Fog Light LED's, Interior LED's, Poly Exhaust Hangers, Oil Catch Can // PTP// HPFP Upgrade, 2150 rail valve // H&R // SS Coilovers // SPC// Adjustable Camber Arms // Hawk// HPS Brake Pads // Ebay Chargespeed Lip 06-07 STI Lip // DDM 8K 55W HIDs // JBR// Rear Sway Bar, 88D RMM, AP Mount //WHITELINE// Front End Links // ETS// TMIC// |
| Not Ranked : 0 score Your boost (more specifically, the ambient temps where you live and your catless pipe) on the k04 may be very difficult to control with this manifold. You go through portions of your map where I can hardly control it with the throttle plate. Not saying it isn't worth a try, but if you install that mani, in combo with your mods and atmosphic temp, you need to be utlra careful until you know how your car will react. |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | helmetface (06-05-2013), Jh8909 (01-16-2013) |
(Thread Starter) | Not Ranked : 0 score I passed on it. Just too sketchy. Oh and sorry for the gibberish. I will just post a vid with speaking and colorful pictures of unicorns with magical fairy dust. Shooting this ISH from my iPhone using forCUMrunner
| The Following 2 Users Say Thank You to superdave2335 For This Useful Post: | helmetface (06-05-2013), rfinkle2 (01-16-2013) |
(Thread Starter) | Not Ranked : 0 score Anyone seen the new afi manifolds on their website? http://www.afiturbo.com/2012/09/mazd...urbo-manifold/ Shooting this ISH from my iPhone using forCUMrunner
__________________ 08' MS3 ESK-EMO Tuned!!! GT3076r EWG Manley rods, cp-e stage 2 pistons, arp studs, fullRace exhaust mani,PNP stock IM, TurboXS catless DP/TP/CBE, TurboXS FMIC, hybrid boost control setup using MBC/EBCS, HTP 4" intake system w/MAF block off plate, 3.5" blow thru system fabbed by me,3 bar map, SNOW Stage 2 W/Direct port meth, HKS SSQV4 full vta, JBR 80duro RMM/TMM/PMM, JBR Stage2 OCC, EGR delete, TWM Full Replacement, perm butt plug knob, JBR SB, KMD V2, NGK's, perm pcv plate. shout outs to -Rob, DJ, Nishan, William, John. couldn't have done it with out your guys advice and assistance. thanks. Last edited by superdave2335; 06-05-2013 at 06:55 PM. |
![]() Join Date: Jun 2013 Location: Anchorage, AK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 164
Groaned at 27 Times in 14 Posts
| Not Ranked : 0 score Funny I find ur post. If I can't get a mani with ewg v band from john then I may try getting the afi. |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
![]() Join Date: Dec 2013 Location: Plainfield, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,712
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor | |
![]() Join Date: Oct 2011 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 601
Groans: 106
| Not Ranked : 0 score |
![]() Join Date: Sep 2019 Location: Зоссия
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Привет всем участникам! прикольный у вас сайт! Нашел прикольную базу кино: ютуб смотреть лучшие мелодрамы онлайн Здесь: фильмы 2018 смотреть хорошем качестве боевики http://kinofanonline.net/boevik/ список 2019 Тут: летучий корабль мультфильм смотреть в хорошем босс молокосос мультфильм 2019 смотреть хорошем качестве список 2018 Здесь: http://kinofanonline.net/5422-gazgolder-film-2014.html Газгольдер: Фильм (2014) смотреть онлайн бесплатно Тут: http://kinofanonline.net/17108-rober...-betmenom.html
__________________ кино онлайн 2019 бесплатно в хорошем боевик http://kinofanonline.net/boevik/ рейтинг 2018 |
| NEW Turbo Manifold | zspeed3 | MazdaSpeed 3/6 - Turbo Induction | 25 | 05-19-2011 07:32 PM |
| High strength studs for turbo (manifold to head and manifold to turbo) | bnoon | MazdaSpeed 3/6 - Turbo Induction | 4 | 03-11-2009 10:26 PM |
| Externally Wastegated Turbo Manifold vs Tubular Turbo Manifold | nobmood | Mazdaspeed3/6 General Discussion | 18 | 03-01-2009 08:14 PM |
