  • 1 Post By SpeedRebirth
  • 1 Post By rfinkle2
 Old 01-15-2013, 12:25 AM   #1
superdave2335's Avatar
Posts: 924   (View Stats)
superdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the world
Groaned at 9 Times in 6 Posts
Default Afi turbo manifold
Alright I know this was covered in another thread and afi went to hang with the crickets. Well ol boy from Fairbanks has this manifold. According to afi it's the first one released that actually fits. Brandon sent I back twice before fitment was good. Well they ended up changing minds and went with a cp-e setup as I mentions in the other thread. Well the offer was made to me if I wanted to buy then to make an offer. What are your guys opinions on this? Here's Brandon with the mani. Thanks for the help guys. Also it would e out on and test fitted before any cash is traded as I have a hard time trusting non MSF'ers.
Shooting this ISH from my iPhone using forCUMrunner
08' MS3 ESK-EMO Tuned!!!
GT3076r EWG
Manley rods, cp-e stage 2 pistons, arp studs, fullRace exhaust mani,PNP stock IM, TurboXS catless DP/TP/CBE, TurboXS FMIC, hybrid boost control setup using MBC/EBCS, HTP 4" intake system w/MAF block off plate, 3.5" blow thru system fabbed by me,3 bar map, SNOW Stage 2 W/Direct port meth, HKS SSQV4 full vta, JBR 80duro RMM/TMM/PMM, JBR Stage2 OCC, EGR delete, TWM Full Replacement, perm butt plug knob, JBR SB, KMD V2, NGK's, perm pcv plate.
shout outs to -Rob, DJ, Nishan, William, John. couldn't have done it with out your guys advice and assistance. thanks.
superdave2335 is offline   Reply With Quote
 Old 01-16-2013, 10:14 AM   #2
MS3inDC's Avatar
Posts: 3,070   (View Stats)
MS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the world
Groaned at 56 Times in 37 Posts
cobb ap v3 // RICHTUNE // autotech fpi // sp63 afc // cp-e nano // htp tip // nator dc fmic // nator dc PnP intake mani // hks ssqv *vta* // cs dp // su tp
jbr rmm(88duro) // jbr pmm(80duro) // cpe tm(75duro) // act 6-puck // act streetlite fw // jbr egr delete // md occ // sure ssb // nator dc sts // jbr hw shift knob
ebc red // rx-8s wrapped in conti dws 235/40s (winter) evo Xs wrapped in conti dw 235/40s (summer) www.sonictuning.com
311 whp - 345 lb/ft : Dynojet @ Moore Automotive *93 pump [4/13/13 MNM]
12.94 @ 109.00 @ Capitol Raceway *18' ASL [11/07/14]
I would wear a pink unicorn shirt, and still call someone a faggot. Since when did MSFers begin to give fucks?...
MS3inDC is offline   Reply With Quote
 Old 01-16-2013, 10:32 AM   #3
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
You need to read your post again, i didnt get half of what you said
MS6/CX-9 likes this.
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 01-16-2013, 10:46 AM   #4
Jhornbrook's Avatar
Posts: 708   (View Stats)
Jhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the world
Groaned at 6 Times in 4 Posts
Ok so from what I understand of the gibberish in your op I say test fit it and see how you like it. And as long as its not to expensive go for it. However I would test fit and drive with it to make sure it works better.
Ultimate Racing // testpipe, catback // TWM // Full Replacement Shifter, Short Shift Boot // Cobb// AP // Sure aeros, sidewinder, shortcut, ags SS knob, return, chargetubes, countershift // Corksport // License Plate Relocate, Fog Light LED's, Interior LED's, Poly Exhaust Hangers, Oil Catch Can // PTP// HPFP Upgrade, 2150 rail valve // H&R // SS Coilovers // SPC// Adjustable Camber Arms // Hawk// HPS Brake Pads // Ebay Chargespeed Lip 06-07 STI Lip // DDM 8K 55W HIDs // JBR// Rear Sway Bar, 88D RMM, AP Mount //WHITELINE// Front End Links // ETS// TMIC//
Jhornbrook is offline   Reply With Quote
 Old 01-16-2013, 10:54 AM   #5
Your boost (more specifically, the ambient temps where you live and your catless pipe) on the k04 may be very difficult to control with this manifold.
You go through portions of your map where I can hardly control it with the throttle plate.
Not saying it isn't worth a try, but if you install that mani, in combo with your mods and atmosphic temp, you need to be utlra careful until you know how your car will react.
helmetface likes this.
helmetface (06-05-2013), Jh8909 (01-16-2013)
 Old 01-16-2013, 05:51 PM   #6
I passed on it. Just too sketchy. Oh and sorry for the gibberish. I will just post a vid with speaking and colorful pictures of unicorns with magical fairy dust.
GT3076r EWG
The Following 2 Users Say Thank You to superdave2335 For This Useful Post:
helmetface (06-05-2013), rfinkle2 (01-16-2013)
 Old 06-05-2013, 02:59 PM   #7
Anyone seen the new afi manifolds on their website?
http://www.afiturbo.com/2012/09/mazd...urbo-manifold/
GT3076r EWG
 Old 01-30-2014, 01:13 AM   #8
xTRELLx's Avatar
Posts: 396   (View Stats)
xTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the world
Groaned at 27 Times in 14 Posts
Funny I find ur post. If I can't get a mani with ewg v band from john then I may try getting the afi.
xTRELLx is offline   Reply With Quote
 Old 06-02-2018, 07:08 AM   #9
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
@MS3Shadow;
MECP
2012 BM
Rfinkle tune in progress
 Old 06-02-2018, 09:02 AM   #10
Djohns's Avatar
Posts: 3,944   (View Stats)
A thread bump homes? I’m so confused by this action from you.
2010 black mica speed3
Soon:built motor
 Old 06-02-2018, 09:04 AM   #11
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
There were spam bot posts in here before.
 Old 10-30-2019, 05:42 PM   #12
HenryMen's Avatar
Posts: 2   (View Stats)
HenryMen is an unknown quantity at this point
Default новые комедии онлайн беÑ?платно в хорошем качеÑ?тве
Привет вÑ?ем учаÑ?тникам! прикольный у ваÑ? Ñ?айт!
Ð?ашел прикольную базу кино: ютуб Ñ?мотреть лучшие мелодрамы онлайн
ЗдеÑ?ÑŒ: фильмы 2018 Ñ?мотреть хорошем качеÑ?тве боевики http://kinofanonline.net/boevik/ Ñ?пиÑ?ок 2019
Тут: летучий корабль мультфильм Ñ?мотреть в хорошем боÑ?Ñ? молокоÑ?оÑ? мультфильм 2019 Ñ?мотреть хорошем качеÑ?тве Ñ?пиÑ?ок 2018
ЗдеÑ?ÑŒ: http://kinofanonline.net/5422-gazgolder-film-2014.html Газгольдер: Фильм (2014) Ñ?мотреть онлайн беÑ?платно
Тут: http://kinofanonline.net/17108-rober...-betmenom.html
кино онлайн 2019 беÑ?платно в хорошем боевик http://kinofanonline.net/boevik/ рейтинг 2018
HenryMen is offline   Reply With Quote
NEW Turbo Manifold zspeed3 MazdaSpeed 3/6 - Turbo Induction 25 05-19-2011 07:32 PM
High strength studs for turbo (manifold to head and manifold to turbo) bnoon MazdaSpeed 3/6 - Turbo Induction 4 03-11-2009 10:26 PM
Externally Wastegated Turbo Manifold vs Tubular Turbo Manifold nobmood Mazdaspeed3/6 General Discussion 18 03-01-2009 08:14 PM
Page generated in 0.32377 seconds with 30 queries
