 Old 06-14-2016, 10:13 PM   #1
mariosalguero's Avatar
Posts: 30   (View Stats)
mariosalguero will become famous soon enough
Default AFR STUCK!
A couple days ago my CEL came on. My AP reads P2177 and P2187. Driving regular speed, the AFR gets stuck at 14.85. Ive been reading around and looks light it might be a bad o2 sensor or an air leak. Any suggestions?
mariosalguero is offline   Reply With Quote
 Old 06-14-2016, 11:16 PM   #2
Bob-o's Avatar
Posts: 1,312   (View Stats)
Primary o2 sensor died
EWG GTX3071 | PERM 3.5" intake | COBB FMIC | CP-e injector seals | UR downpipe | CS testpipe | HKS catback | KW V1's | Blahblahblah
The Following 2 Users Say Thank You to Bob-o For This Useful Post:
MD1032 (06-30-2016), Vansquish (06-25-2016)
 Old 06-14-2016, 11:58 PM   #3
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
most likely ^^^^agree.
mine was stuck at one afr almost all the time when mine died.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 06-24-2016, 01:15 PM   #4
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Before you do that. Check your fuses. Specifically the one labeled ENGINE BAR.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 06-24-2016, 08:45 PM   #5
sheston's Avatar
Posts: 1,847   (View Stats)
Leak shouldn't be stuck at one value.....
 Old 06-25-2016, 06:06 AM   #6
SyntheticAtmosphere's Avatar
Posts: 193   (View Stats)
SyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond repute
I just replaced mine. I had no CEL, but thankfully I play with my AP regularly and noticed my AFR & LTFT were static. (14.8 & 0.2 respectively). Noticed better acceleration and a bump in fuel economy with the repair.
SyntheticAtmosphere
'06 Speed6 Whitewater Pearl (COBB AP v2, CS s2 SRI/TIP, Autotech HPFP, Cp-e RMM&RDM, Fidanza/LuK, homebrew Testpipe&OCC) next...meth habit
If it feels good, do it...Even if you shouldn't!
SyntheticAtmosphere is offline   Reply With Quote
 Old 06-25-2016, 10:28 PM   #7
i took apart my tmic and found a 1/4 inch crack in on of my couplers. I used some good ol' duck tape while i wait for my new ones. Still noticed my apr is still at 14.8 when driving. The CEL turned off but not i have a p0401. Read around the forums and every one says to clean out the egr valve?
AFR stuck at 14.85 maisonvi MazdaSpeed 3/6 - Troubleshoot/Diagnostics 29 03-06-2016 06:19 PM
HU stuck sega_rt MazdaSpeed 3/6 - Car Audio & Electronics 0 06-14-2013 11:32 AM
stuck shifter Jake_MS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 12-13-2009 09:08 AM
Page generated in 0.25925 seconds with 25 queries
