![]() Join Date: May 2013 Location: Toledo Ohio
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
![]() Join Date: Sep 2012 Location: Elizabeth, NJ
Rep Power: 3180 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,265
Groans: 665
| Not Ranked : 0 score Obviously your cylinder temps/EGTs are above normal levels if your repeatedly cooking valves. Any CELs? Any way to monitor your AFRs? What is the state of your EGR system? |
| The Following User Says Thank You to Agent_Orange For This Useful Post: | Easter Bunny (10-19-2014) |
![]() Join Date: Jun 2012 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,963
Groans: 47
| Not Ranked : 0 score Has the timing chain ever been replaced? Have you adjusted the valves?
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() |
| The Following User Says Thank You to sidekick For This Useful Post: | Easter Bunny (10-19-2014) |
(Thread Starter) | Not Ranked : 0 score no cel prior to it happening. i have a wideband but no place on the factory pipe to put it. egr was cleaned this past winter when the head was off. timing chain and vvt were done also. valves clearance was checked last time head was off all were in spec. it does use alot of oil say quart ever 150 miles. |
Groans: 47
| Not Ranked : 0 score If you're using a quart of oil every 150 miles, I'd say you have much bigger issues... But bad injector? Or injector stuck open? Major detonation in cylinder 3? Did they re-machine the valve seat when replacing the bad valve last time? If the valve is not making good contact with the seat, you can get major hot spots, which could then lead to a burnt valve.
| The Following 2 Users Say Thank You to sidekick For This Useful Post: | Agent_Orange (10-19-2014), Easter Bunny (10-19-2014) |
(Thread Starter) | Not Ranked : 0 score yea the shop re machined the seat into the head. as far as the oil what would you think? the turbo just got a new chra installed. |
![]() Join Date: Aug 2013 Location: Manitowoc, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,312
| Not Ranked : 0 score Who tuned it?
__________________ https://www.youtube.com/user/JustinBieberVEVO |
| The Following User Says Thank You to thebestdj07 For This Useful Post: | Gr8Speed (10-19-2014) |
Groans: 189
| Not Ranked : 0 score Let it burn another one and lemon law (if applicable) that car.
__________________ |
![]() Join Date: Aug 2012 Location: Mundelein, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 322
| Not Ranked : 0 score If you are going to fix it I would replace the injector on that cylinder for sure. Also replace your primary o2 sensor if it's never been changed. Clean or replace the maf sensor too. 140k is probably a good idea to change all 4 injectors. But 1 quart every 150 miles tells me you need a complete rebuild.
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! |
![]() Join Date: Mar 2011 Location: Dallas, Texas
| Not Ranked : 0 score That's your problem, being stock - JK. You just need some E85 or Meth to cool down the combustion |
| clutch slipping or burnt up? | MImarine | MazdaSpeed 6 - Engine, Transmission & Driveline | 5 | 07-09-2013 08:54 AM |
| Burnt Clutch? | jeffreyj | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 0 | 10-19-2012 08:44 PM |
| Burnt my seat | Snotrocket | Interior | 38 | 04-04-2011 06:50 AM |
| Oil smells burnt? | SRTie4k | MazdaSpeed 3 - Engine, Transmission & Driveline | 13 | 11-16-2009 08:17 AM |
| Image burnt onto screen | Death-From-A-Mile | Cobb Access Port/Maps | 3 | 09-16-2008 01:43 PM |
